Vieux 27/11/2018, 18h25   #1
tony60
Avatar de tony60
Pouvoir de réputation: 101
Par défaut Edc15c2 off
Salut à tous immo off 3 broche sans eprom sa demare ou pas ?
KKHALIL (28/11/2018)
Vieux 27/11/2018, 18h29   #2
CSYSTEME
Avatar de CSYSTEME
CSYSTEME has a reputation beyond reputeCSYSTEME has a reputation beyond reputeCSYSTEME has a reputation beyond reputeCSYSTEME has a reputation beyond reputeCSYSTEME has a reputation beyond reputeCSYSTEME has a reputation beyond reputeCSYSTEME has a reputation beyond reputeCSYSTEME has a reputation beyond reputeCSYSTEME has a reputation beyond reputeCSYSTEME has a reputation beyond reputeCSYSTEME has a reputation beyond repute
BONJOUR
non ca demarre pas tony
cordialement
The Following 3 Users Say Thank You to CSYSTEME For This Useful Post:
ggvaniou (27/11/2018), KKHALIL (28/11/2018), tony60 (27/11/2018)
Vieux 27/11/2018, 18h32   #3
ggvaniou
Avatar de ggvaniou
Pouvoir de réputation: 87
Slt tony
Je confirme ,ca démarre pas
The Following 3 Users Say Thank You to ggvaniou For This Useful Post:
KKHALIL (28/11/2018), tony60 (27/11/2018), Y.B tec (28/11/2018)
Vieux 27/11/2018, 18h47   #4
bkprog13
Avatar de bkprog13
Pouvoir de réputation: 84
salut, ça depend de la version, il y a des modeles 3 broches sans eeprom qui demarre comme ceux venant de jumpy par exemple...
Et c'est certain j'ai deja eu la cas...
bkprog13 est connecté maintenant   Réponse avec citation
The Following 4 Users Say Thank You to bkprog13 For This Useful Post:
Bigorno91 (27/11/2018), KKHALIL (28/11/2018), mnaouar (28/11/2018), tony60 (27/11/2018)
Vieux 27/11/2018, 19h05   #5
redou28
Avatar de redou28
redou28 is a splendid one to beholdredou28 is a splendid one to beholdredou28 is a splendid one to beholdredou28 is a splendid one to beholdredou28 is a splendid one to beholdredou28 is a splendid one to beholdredou28 is a splendid one to behold
salut les amis
les vehecules avec com2000 l'immo off est dans flash ca demare sans l'eprom et pas de brédage (le code pin est lisible dans l'eprom)
les vehecules sans com2000 l'immo off est dans l'eprom ca demare sans l'eprom mais avec mode dégradé ne depass pas 3000trmn (pas de code pin dans l'eprom)
par exemple ecu 1 pluge et immo dans flash 307 2001 c5 2001
ecu 3 plug immo dans l'eprom picasso 2002 expert 2001 607 2002
redou28 est déconnecté   Réponse avec citation
The Following 10 Users Say Thank You to redou28 For This Useful Post:
akasa67 (27/11/2018), bkprog13 (27/11/2018), kilm (27/11/2018), KKHALIL (28/11/2018), pouettedu76 (28/11/2018), RLL (28/11/2018), roilion007 (27/11/2018), tony60 (27/11/2018), vv58 (27/11/2018), Y.B tec (28/11/2018)
Vieux 27/11/2018, 19h08   #6
tony60
Avatar de tony60
0281011083 ecu 206
The Following 2 Users Say Thank You to tony60 For This Useful Post:
KKHALIL (28/11/2018), vv58 (27/11/2018)
Vieux 27/11/2018, 20h50   #7
redou28
Avatar de redou28
0281011083 ecu 206
oui ca demarré avec voyant obd allumé (defaut telecodage)
The Following 3 Users Say Thank You to redou28 For This Useful Post:
KKHALIL (28/11/2018), tony60 (27/11/2018), vv58 (27/11/2018)
Vieux 27/11/2018, 20h52   #8
tony60
Avatar de tony60
Envoyé par redou28 Voir le message
Sans eprom?
Vieux 27/11/2018, 20h59   #9
redou28
Avatar de redou28
Sans eprom?
immo off sur flash+ sans eprom
The Following 2 Users Say Thank You to redou28 For This Useful Post:
Vieux 27/11/2018, 20h59   #10
vv58
Avatar de vv58
Pouvoir de réputation: 26
salut redou28 sans com 2000 je suppose que c est du filaire (commande direct les divers elements et avec com2000 c est juste des infos sans puissance qui passe par bsi mais comment on reconnait le ysteme sans demontage ? et au passage un petit bonjour a toi tony
The Following 3 Users Say Thank You to vv58 For This Useful Post:
KKHALIL (28/11/2018), redou28 (27/11/2018), tony60 (27/11/2018)
Vieux 27/11/2018, 21h09   #11
Pouvoir de réputation: 276
Slt Tony off sur flash pour moi comme notre ami redou le dit y a certaine voiture en 3 broche ou l immo et dans l eeprom après si com 2000 sa veut dire que c'est en mux d après la réf que tu donne off dans la flash sûre..
Vieux 27/11/2018, 21h14   #12
redou28
Avatar de redou28
Envoyé par vv58 Voir le message
salut l'ami
just regardez sur le comodo eclairage
com2000
sans com2000 (meme avec bsi par ex 406 2000)
akasa67 (27/11/2018), vv58 (27/11/2018)
Vieux 27/11/2018, 21h15   #13
tony60
Avatar de tony60
Salut bon ba je vais lire la flash je déteste cette ecu de mer...
akasa67 (27/11/2018), KKHALIL (28/11/2018)
Vieux 27/11/2018, 21h18   #14
salut l'ami
com2000
Pas mal l ami y peu voir aussi avec la bsi sylea ancienne génération 3 plug eeprom si bsi siemens avec bsm ou com 2000 flash.. Etc à force ont connais merci à toi
---------- Post added at 21h18 ---------- Previous post was at 21h17 ----------
T sérieux tiny sa va tous seul j'ai planter un une fois impossible de récrire la flash pas d adaptateur sur mon gq4x j'ai souder et fais fais sur un autre calculateur..
Vieux 27/11/2018, 21h22   #15
bkprog13
Avatar de bkprog13
un petit boot mode au galletto sa passe tout seul en 5mn
The Following 3 Users Say Thank You to bkprog13 For This Useful Post:
akasa67 (27/11/2018), KKHALIL (28/11/2018), tony60 (27/11/2018)
Dpf egr off edc15c2 406 2.0 hdi azwa44 Chiptuning 6 06/07/2017 14h22
Edc15c2 mahfoud lichani Pinout calculateurs et bootmode 8 04/01/2016 23h45
Edc15c2 off bbert90 Immobilizer dumps/solutions 21 18/09/2015 20h30
206 2 hdi edc15c2 BELL Peugeot, Citroën 0 16/03/2014 15h48
FAP off edc15c2 Actif-Car Chiptuning 23 14/01/2014 08h27
Fuseau horaire GMT +1. Il est actuellement 08h39.
