Vieux 22/01/2019, 19h58   #1
tarik_electronic
Avatar de tarik_electronic
tarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond repute
Par défaut Vierge BSI 307 - 95128
SALUT à tous ,
j'aurais besoin d'un dump vierge pour ce BSI de 307 ( 95128 )
bsi 96 565 305 80 johnson controls BSI 2004 H05
Merci d'avance a ceux qui peuvent m'aider
oublié pas le petit " thanks "
tarik_electronic est déconnecté   Réponse avec citation
The Following User Says Thank You to tarik_electronic For This Useful Post:
Hestia (10/11/2019)
Vieux 22/01/2019, 20h10   #2
CHIKODIAG
Avatar de CHIKODIAG
CHIKODIAG is a jewel in the roughCHIKODIAG is a jewel in the roughCHIKODIAG is a jewel in the roughCHIKODIAG is a jewel in the rough
Hi your virgin you need the pin code and pp200/diagbox for finiching the job
good luck
Type de fichier : rar virgin.rar (1,2 Ko, 10 affichages)
CHIKODIAG est déconnecté   Réponse avec citation
The Following User Says Thank You to CHIKODIAG For This Useful Post:
tarik_electronic (22/01/2019)
Vieux 22/01/2019, 20h16   #3
tarik_electronic
je sais que le frequence telecommande central... enregistre dans la flash.
le question est ce que je peux programme
un cle vierge acev telecommande?
salutation
---------- Post added at 08:16 PM ---------- Previous post was at 08:15 PM ----------
bsi et crame impossible de l extrere la flash .
Vieux 22/01/2019, 20h36   #4
CHIKODIAG
Avatar de CHIKODIAG
HI yes you can program a new key but you need the chip coded to the remot b (you can not use a new chep46 from ebay and the remot from aliexp) for exampl it must be a complet key remot with chip46
good luck
The Following 2 Users Say Thank You to CHIKODIAG For This Useful Post:
rachid72 (22/01/2019), tarik_electronic (22/01/2019)
Vieux 22/01/2019, 20h49   #5
tarik_electronic
original remote key peugoet ?
Vieux 22/01/2019, 21h35   #6
CHIKODIAG
Avatar de CHIKODIAG
hi it will be very good
good luck
Vieux 23/01/2019, 10h19   #7
tarik_electronic
Envoyé par CHIKODIAG Voir le message
good luck
fichie corrompu ou mot de pass errone
j arrive pas a decompresse l archive
Vieux 23/01/2019, 10h37   #8
yann3
Avatar de yann3
Pouvoir de réputation: 74
tiens un virgin 95128
http://dl.free.fr/ka2jJ5aCz
pass dans ta boite
The Following 3 Users Say Thank You to yann3 For This Useful Post:
CHIKODIAG (23/01/2019), progdebutant (23/01/2019), tarik_electronic (23/01/2019)
Vieux 23/01/2019, 20h49   #9
tarik_electronic
merci a tous
j ai injecter le dump eprom de bsi ori dans bsi cas . il devient vierge quand je la branche automatique
et aussi le telecomonde a ete programme
j ai change quelque chose dans les parametre de bsi
Vierge BSI 307 - 95128 diagnosis29 Transponder, code pin 16 29/11/2021 23h52
Bsi 407 95128 vierge smt Immobilizer dumps/solutions 12 02/11/2017 21h40
vierge 95128 bsi k04 stephmargot Immobilizer dumps/solutions 2 17/05/2017 22h05
vierge bsi 407 95128 klif26 Immobilizer dumps/solutions 1 27/01/2016 23h50
vierge bsi 407 95128 nizar Immobilizer dumps/solutions 2 19/11/2014 15h34
Fuseau horaire GMT +1. Il est actuellement 13h11.
