i made this thread for sharing my tested ECUs with a Fgtech V54 clone (with Rework) If someone has tested v54 with other ECUs. You can share your results in this threadKolo EDC16u34 (VAG) Read/Write ok (OBD) EDC16U1 (VAG) Read/Write ok (OBD) MED9.1 (VAG) Read/Write ok (ODB) edit: Quote: ALFA ROMEO edc15c7 ME 7.3.1 edc16c39 edc16c39 read time 40 MINUT! id Alfa 147 immo off (k line /boot mode) BMW edc16c31 obd BMW X5 2007 3.0TDI EDC16 OBD BMW 330d EDC15C4 read ok/write ok via OBD edc16c31/35 obd r/w ok edc17 in boot mode ok BMW E87 116D 2.0 EDC17C06 Bootmode r/w ok BMW E83 3.0d ODB r/w ok BMW X6 3.0D 2012 and 2013 (306 and 245hp)BOSCH EDC17CP45 read/write BOOT ok BMW e46 2.0D 150km EDC16c31- ok BMW E90 2.0D 163km EDC16c35- ok bmw e90 edc 17cp reading ok write fail. boot mode ok! Siemens BMW MSS54 BDM R/W OK OBD not tested (will probably work) Siemens BMW MSS54HP BDM R/W OK only with AMD Chip/Not ST EEPROM, WILL NOT READ PROPERLY/WRITE BMW E70 3.0D EDC16 (BDM) bmw. edc16c35 (BDM) BMW F10 2010y EDC17CP45 TPROT10 on the bench...boot SAK1797 only ecu data...can not read ee not read int. flash FIAT Grande Punto read 1_3 MJT 75 hp Grande Punto 1.4 T-jet r/w ok (bootmode) mjd 6f3 diesel read/write all ok fiat/iveco edc16c39 obd read/write ok Grande punto sport edc16c39 can write fails Fiat Edc15c7 r/w ok Iaw59f r/w ok Fiat Stilo 1.6 16v 2001y ecu 5NF.T1 via OBD2, on the bench via K line r/w EDC15C7 r/w via OBD2 Fiat Marea 1.9 JTD 2002god FORD EECV 1.8tddi read/write ok edc16c34 and delphi ECUs obd r/w ok Ford Focus 2.0D 136 PSA Simens 802 - ok MAZDA Mazda 5 2.0D 2005 Denso RF7K read/write OBD ok Mazda 6 2.0D 2006 Denso RF8J read/write OBD ok MERCEDES EDC15C5 edc5c2 delphi CRD2 Mercedes w211 2.2 cdi edc16c3 obd, ecu data ok read/write fail! Bdm read Mercedes GLK Delphi CRD2 r/w (OBD) ok Mercedes w212 crd 3.7 obd. OK Mercedes Viano EDC16 C2. OBD. Ok Mercedes W203 320CDI EDC16cp31 r/w ok (OBD) Mercedes B180CDI EDC15c32 - ok Mercedes vito 120 EDC16C31 read ok/write ok via OBD Mercedes Vito 2.2CDI 2012 Delphi CRD2.x (OBD) read / write ok Mercedes w212 delphi 2.10 solenoid r/w ok Mitsubishi edc16u31 obd r/w ok (Grandis) Mistubichi Pajero 3.2DID 2013 Denso 4M41 and 4D56 read/write JTAG RENESAS ok Nissan DDCR (Nissan Almera 1.5DCI) OBD read/write OK OPEL edc16c39 obd r/w ok edc16c39 bdm r/w ok edc16c9 bdm r/w ok astra J 2009 denso galletto jtag NOT ok (but ktag r/w same ecu ok with jtag) Opel Corsa-D CAN Opel EDC16c9 (BDM) Z10XE Opel Corsa 1.0 (ME1.5.5) on the bench r/w 18XE Opel Zafira Simtec 90 71.1 r/w (24kb file!!!) on the bench Astra G via obd read Delco 1.7 isuzu Porsche Porsche 2012 MY - VAG EDC17CP44 read\write in boot mode failed - could not disable TPROT PSA edc15c7 boot mode (ID problems) EDC 16C34 edc16c34 EDC15C13 (Renault) Read/Write ok (K-line on bench and boot mode) siemens s3000 read hitachi mcu/write ok ( renualt megane ) dcm 3.4 obd r/w ok Peugeot 207 EDC16C34 r/w (OBD) ok Peugeot 308 1.6 HDI 2013 Siemens SID807 EVO read/write BOOT ok Renault Trafic 2.5D EDC15 - ok SID-801A BOOT MODE r/w ok SID 803A r/w ok sirius 32n boot - r/w ok Delphy DCM3.4 Pezo 308 2.0 HDi 2007 via OBD2 (W not tested, just R) EDC15C2 Peugeot 406 restyl 2.0 HDI 2004 via OBD2 r/w Peugeot 206+ 2010 1.4 8v 75cv Valeo-Johnson J34P : OBD R/W CHKS OK VAG AUDI ME 7.1.1 3.0 v6 read ok - awaiting flash edc15v EDC15-P edc15 Golf Plus 2006 2.0TDI EDC16U34 (03G 906 021 PD) via obd2 r/w caddy 2010 1.9tdi A4 2.0 tdi 2008 Skoda octavia vrs 2005 EDC15P K lINE VW crafter READ VW Golf5 1.9TDI Audi A6 V8 4.2l Petrol (over OBD fuse for dash fuse 11 or 15 , but it worked after pulling the fuse for dash and it went 100%) med9.1 EDC17CP14 03L906022G Read/Write ok (OBD and boot mode) EDC17 MED17.5.1 Boot mode r/w ok Edc17cp20, edc17cp44 ME 7.5 (VW 1.8T AWT) Read ok / Write ok (OBD) vag edc17cp14 read/write in boot mode ok, read in OBD ok vag pcr2.1 read/write OBD ok, PCR2.1 unlock via bootmode ok vag edc16cp34 obd read/write ok Audi A3 8P 1.9TDI EDC16U1 R/W obd ok Audi A3 8P 2.0TDI EDC16U1 R/W obd ok Audi A8 4.0TDI EDC16C2/4 Master + slave ecu R/W obd ok VW golf4 EDC15V R/W obd ok VW golf4 EDC15P R/W obd ok Skoda 1.6TDI PCR2.1 unlock boot mode ok Skoda 1.6TDI PCR2.1 after unlock R/W obd ok EDC17U05 VW POLO 1.4 TDI Boot mode without problem READ & WRITE EDC16U1 r/w via OBD2 Touran 1.9TDi, Seat Altea 1.9 tdi EDC16cp34 read worked but no write, i wrote with MPPS v13 EDC15 PD 1.9 passat via OBD2 r/w EDC17CP14 Audi A4 2.0 tdi 2009y (03L 906 019 AL, 03L 906 022 KC) r/w on the bench boot Golf G4 IAW4LV.H PV2 MY2 (036906034BB ) via OBD can not read even ecu data Volvo edc17 boot mode ok iveco edc16 BDM (BDM) SsangYong Korando 2.0 eXDI Delphi DCM3.7 read by OBD - ok\write - failed; read\write by BDM\JTAG - failed. Land Rover 2.0 td4 diesel DDE4 Bosch r/w via OBD2 sirius32N,EMS3132,EMS3134 in boot-mode read/write OK. Chevrolet Captiva 2.0D 150km - ok Landrover /jaguar EDC17CP11 read out in boot mode ok, not tried write yet. Me7.3.1 r/w ok Sirius 34 r/w ok Trionic8 (saab 9-3) READ/WRITE OK (OBD) Sagem S3000 on the bench read Jtag renesans EDC16C3 via OBD2 ok, full BDM on the bench r/w (suzuki grand vitara 1.9DDiS |
Pouvoir de réputation: 18 ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Salut à tous, pour mes manipulations avec Fgtech v54 Clone Tool 0386
Renault, Dacia megane 1.4 16V ess Sirius 32 R/W ok OBD et R/W ok Boot Clio 1.5dci Delphi DDCR R/W ok OBD et R/W Boot Logan 1.5dci Delphi DCM1.2 R/W Boot Peugeot: EDC15C2 3plugs R/W ok Boot EDC16C34 R/W ok BDM EDC17C10 R/W ok Boot VW: Marelli IAW 4HV polo 1.4 ess R/W ok Boot |
#3 | |
pour ca Delphi DDCR R/W ok OBD et R/W Boot tu as lu eeprom par obd ou seulement la flash ? merci d'avance |
Salut, Seulement la Flash sur DDCR
| The Following 2 Users Say Thank You to kaki02 For This Useful Post: | progdebutant (09/04/2019), rapou30 (25/10/2020) |
| delphi 2015.1 tested 100% | roilion007 | Autocom, Delphi, Actia, Bosch, SPC, BrainBee, Autel | 53 | 04/01/2023 21h06 |
| obd application list | zenata | programmation & synchronisation de clé | 0 | 28/04/2018 23h19 |
| s2000rpm clio 1.2 besoin off tested svp | auto perf | Immobilizer dumps/solutions | 11 | 08/12/2016 14h40 |
| immo off tested | drissdiag | Immobilizer dumps/solutions | 1 | 08/11/2016 18h15 |
| CITROEN xia 45 up******,,tested 100% | MAXIMUS1000 | LEXIA, PP2000, DiagBox | 0 | 15/03/2010 17h21 |
