Vieux 31/05/2019, 13h55   #1
Volik8
Avatar de Volik8
Volik8 is an unknown quantity at this point
Par défaut citroen
Hello, I need help, the car is Citroen Berlingo, sometimes the charging light comes on and the power consumption stops working, what could be the problem?
Volik8 est déconnecté   Réponse avec citation
Vieux 31/05/2019, 19h01   #2
many888
Avatar de many888
many888 is a splendid one to beholdmany888 is a splendid one to beholdmany888 is a splendid one to beholdmany888 is a splendid one to beholdmany888 is a splendid one to beholdmany888 is a splendid one to beholdmany888 is a splendid one to behold
hello it should control the charging voltage of your alternator when the problem appears again
la savoir est bon que si il est partagé ..
many888 est déconnecté   Réponse avec citation
Vieux 31/05/2019, 21h32   #3
sadna
Avatar de sadna
Pouvoir de réputation: 35
Envoyé par Volik8 Voir le message
like it is said,
you should check our accessory belt, then alternator.
if ok
check your maxi fuse.
Cle citroen DS3 petru2a Programmeur de clé 17 29/05/2018 08h47
Citroen dumps immo off tested for citroen 100/100 ok lassad Immobilizer dumps/solutions 0 14/01/2016 15h18
BSI citroen C5 eobd-scan92 Peugeot, Citroën 10 04/07/2013 23h37
Citroen C3 passion-auto Peugeot, Citroën 8 12/04/2013 01h17
Citroen Lexia 347.19 + Citroen C5 2001-2008 Multilingual TAGRART LEXIA, PP2000, DiagBox 0 16/11/2012 17h48
Fuseau horaire GMT +1. Il est actuellement 18h57.
