Pouvoir de réputation: 46 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Hello,
Renault Can Clip 193 Free! ![]() Pour les nouveaux membres, pour tous le monde et parce que j'en ai mare des disputes de maternelles!! ![]() Enjoys!!
| The Following 81 Users Say Thank You to kitty-hawk For This Useful Post: | 6535jp (01/01/2021), abdel77 (24/01/2021), abdel93 (30/12/2019), alexian (14/01/2020), alexteamktm (17/01/2020), arbreacames (02/02/2020), autodiagauto (29/12/2019), azzouz (16/01/2020), bibault (19/01/2020), car83 (16/01/2020), claude81 (18/01/2020), culbuto (08/01/2020), dart (19/01/2020), deltamike (13/01/2020), DIAGSYSTEM25 (08/01/2020), dj83 (24/05/2020), djamel30 (08/01/2020), dreamland (29/12/2019), ElTurco (08/01/2020), EMERIC (24/05/2020), Ext33 (10/01/2020), FABRICE56 (08/01/2020), falcoman33 (06/06/2022), farid42 (08/01/2020), formator2 (08/01/2020), gchx (29/12/2019), ggvaniou (29/12/2019), gunthaaar (03/01/2020), Haddoken7 (08/04/2020), hamiza (12/01/2020), hominel (19/02/2020), jah83 (29/12/2019), jardini (12/03/2020), jeanalitre (09/02/2023), jletier (23/01/2020), Jordan59 (18/01/2020), jphp (29/12/2019), kael (01/01/2020), lalens (30/07/2020), lazizouille (09/01/2020), lolo27 (02/01/2020), MAXYBOOM (30/01/2020), Med1387 (02/01/2020), michelméca (29/12/2019), mirage47 (03/01/2020), mitch4707 (08/01/2020), MrRorry (07/01/2020), multi290 (30/12/2019), nafan (14/05/2024), neoamtrixe (27/01/2020), nhsdany (17/01/2020), nounour10 (15/01/2020), pouettedu76 (29/12/2019), pp08 (16/01/2020), rapou30 (29/12/2019), Rimkus (03/01/2020), roilion007 (06/01/2020), ronan4982 (11/01/2020), sandy976 (29/12/2019), serval (09/08/2020), Silentmaxx (27/01/2020), Snatsh (02/01/2020), sparco123 (19/04/2020), supopo007 (20/01/2020), taxi5114 (11/01/2020), taz_13 (11/01/2020), teknada (05/02/2020), thierry du58 (29/12/2019), tof (17/04/2020), tolga07 (15/01/2020), toto014 (21/01/2020), ToTo076 (08/09/2020), turbo (31/01/2020), twisterelectro (04/01/2020), uncleseb (02/01/2020), Val_91 (14/01/2020), vortex (07/01/2020), Y.B tec (04/01/2020), youcef_trik (16/01/2020), zav_ze_best (06/01/2020), zhed (24/10/2021) |
C'est dommage car les gratteurs vont se faire plaisirs !! |
| The Following 9 Users Say Thank You to Pilouf For This Useful Post: | Alessiapia14 (02/01/2020), autodiagauto (02/01/2020), boukrama (29/12/2019), ggvaniou (02/01/2020), jah83 (29/12/2019), kitty-hawk (29/12/2019), Med1387 (02/01/2020), nimbus (29/12/2019), Y.B tec (04/01/2020) |
salut non c'est beau comme démarche en periode de fetes tourmentées je trouve ; les liens ne s'ont pas visibles aux non inscrits! on va voir une foule d'inscriptions du coup
bravo @ Dernière modification par jphp ; 29/12/2019 à 14h14. |
| The Following 5 Users Say Thank You to jphp For This Useful Post: | autodiagauto (02/01/2020), ggvaniou (29/12/2019), kitty-hawk (29/12/2019), Med1387 (02/01/2020), nimbus (29/12/2019) |
![]() Date d'inscription: mai 2014
Pouvoir de réputation: 16 ![]() ![]() ![]() ![]() ![]() |
bravo kitty-hawk , tu remonte le niveau du fofo , j aurais du le faire avant toi . |
| The Following User Says Thank You to michelméca For This Useful Post: | kitty-hawk (29/12/2019) |
merci pour ton partage
Pouvoir de réputation: 66 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Tiens en voila un ,justement, bonjour il connais pas
No clic thanks ,No clic Reputation ,pas d'aide! |
| The Following 3 Users Say Thank You to Alessiapia14 For This Useful Post: |
| The Following 3 Users Say Thank You to Pilouf For This Useful Post: |
bonsoir
j'ai téléchargé cette version et installée jusqu'à aujourd'hui, ras, je travaille avec sans soucis je viens de voir une Mégane 3 120000 km vin, type , reconnut sans problème, par contre, aucun calculateur détecté, voir PJ je suis le seul? un avis svp, bonne soirée |
#9 | |
Si tu en as la possibilité fait un essai sur une autre Mégane 3, c'est peut être la prise diag ou autre chose qui déconne, Elle est en panne? |
| The Following 2 Users Say Thank You to kitty-hawk For This Useful Post: | mahfoud lichani (08/01/2020), Y.B tec (14/01/2020) |
@kitty-hawk: il y a longtemps que je n'ai pas lut tes commentaires , comment vas tu? pour ce véhicule: il n'est pas en panne, c'était juste pour un controle après intervention mécanique: un injecteur qui "calquait" le propriétaire a récupérer sa voiture hier, il doit passer si il y a quelque chose à suivre !!! bonne journée |
| The Following User Says Thank You to mahfoud lichani For This Useful Post: | kitty-hawk (08/01/2020) |
RE
je viens de revoir ce véhicule, avant de brancher "CLIP", un coup de nettoyant composant électronique, et voir le résultat en pj par contre , hier aussi autre anomalie sur SANDERO voir pj merci encore bonne journée |
| The Following User Says Thank You to mahfoud lichani For This Useful Post: | kitty-hawk (11/01/2020) |
merci beaucoup |
Pouvoir de réputation: 16 ![]() ![]() ![]() ![]() ![]() ![]() |
Oui, ce Sandero est absent de la base de données des CLIP. JD190312;24.11.2018; JD190346;27.11.2018; JD190381;29.11.2018; JD190382;29.11.2018; JD190383;29.11.2018; JD190384;29.11.2018; JD190385;28.11.2018; JD190386;29.11.2018; JD190387;29.11.2018; JD190388;02.12.2018; JD190389;28.11.2018; JD190390;29.11.2018; JD190392;02.12.2018; JD190393;29.11.2018; JD190394;03.12.2018; JD190396;03.12.2018; JD190397;29.11.2018; JD190398;03.12.2018; |
| The Following 2 Users Say Thank You to sami55 For This Useful Post: | farid42 (11/01/2020), mahfoud lichani (09/01/2020) |
il me la faut pour la clio de ma fille ,il y a le voyant de l'anti démarrage qui fait des siennes ,panne aléatoire mais chiante, la dernierre est survenu il y a une semaine au bout de 1 mois entre la fois precedente. j'ai pourtant refait une clé elle est neuve, changé les relais qui se trouvent dans le boitier noir à coté de la batterie. ---------- Post added at 15h19 ---------- Previous post was at 15h18 ---------- slt il me la faut pour la clio de ma fille ,il y a le voyant de l'anti démarrage qui fait des siennes ,panne aléatoire mais chiante, la dernierre est survenu il y a une semaine au bout de 1 mois entre la fois precedente. j'ai pourtant refait une clé elle est neuve, changé les relais qui se trouvent dans le boitier noir à coté de la batterie. ---------- Post added at 15h20 ---------- Previous post was at 15h19 ---------- slt bon apparement je n'ai pas le droit de télécharger les pieces jointes .pas grave je vais tenter de le trouver ailleurs merci quand meme. |
#15 |
Pouvoir de réputation: 18 ![]() ![]() ![]() ![]() |
slt tout le monde,
je viens d'installer la version 193 mais je n'arrive pas a m'enregistrer avec RSRWin. ya t il un crack spécial pour cette version ?? merci
jedes Problem hat eine Lösung. |
| HELP: PROGRAMMATION CLE Renault CLIO III DCI avec CAN CLIP -Renault Pin Extractor 2 | BILAUTO | programmation & synchronisation de clé | 28 | 02/06/2018 23h47 |
| Renault can clip to do Renault Key Card programming | Pierre Shelly | Renault clip, DDT2000, Nissan consult | 1 | 19/12/2015 20h35 |
| Renault CAN-CLiP Update V144 To V145 + Clip V145 FULL | cedrsan | Renault clip, DDT2000, Nissan consult | 10 | 29/01/2015 21h35 |
| renault can clip 132 | carspeed | Renault clip, DDT2000, Nissan consult | 4 | 10/01/2014 00h35 |
| renault kangoo et clip renault | verdi | Renault, Dacia, Nissan | 7 | 10/11/2012 21h35 |
