Bonjour, je viens de changer de jantes sur ma Ford grand c-max de 2016 (jantes tôles pour jantes alliages d'origine Ford ) le souci c'est que j'ai un défaut de valve qui revient à chaque fois que me conseillez vous de faire et avec quel outil diagnostic. Merci
Supported adapters : OBDLink EX, recommended USB adapter for Windows version of FORScan, also for configuration and programming functions OBDLink MX+, recommended Bluetooth adapter for Lite versions of FORScan (iOS, Android) OBDLink SX/LX/MX ELS27 (STN1170/2120) ELM327-compatible (fully compatible with original ELM327, such as VeePeak, please also see important note below) J2534 Pass-Thru CANtieCAR (in "FORScan" mode) https://forscan.org/home.html CANtieCAR (in "FORScan" mode)
You can practically use Forscan. However, if you want to do the right thing, you must use Ford IDS. First of all, check your tire size settings from the basic settings of your vehicle.
| The Following User Says Thank You to songiden For This Useful Post: | jimm222 (01/09/2020) |
| Problème fap c4 grand picasso | jean-marc 10 | PSA Group Peugeot, Citroën | 18 | 26/09/2018 12h31 |
| Problème de démarrage Grand C4 Picasso | Bomowo | PSA Group Peugeot, Citroën | 49 | 16/09/2017 13h24 |
| Problème c4 grand picasso | JEAN-CLEM | Tableau de bord (Dashboard) | 10 | 27/08/2016 01h04 |
| probleme grand c4 1.6 hdi 110 fap | ludosoizicsarah | Mécanique générale | 35 | 22/06/2014 20h19 |
| Probleme valve | GARAGE.DUFOUR | PSA Group Peugeot, Citroën | 7 | 26/07/2013 08h12 |
