| Flasheur de calculateur Aide concernant les flasher de calculateur d'injection, Kwp2000, Bdm, Ghaletto, MPPS ...etc |
![]() Date d'inscription: juin 2021
Pouvoir de réputation: 7 ![]() ![]() ![]() |
SALUT
Je viens vers vous car j'ai aucune autre alternative j'ai fait des recherche sur google et j'ai pas trouver la solution a mon probleme. j'essaye d'utiliser mon upa pour la 1ere fois pour une lecture NEC uPD780973. Mon probleme le voici: UPA-USB Device Programmer v12113 Licensed to: Kadir Kaleli System: Microsoft (build9200), 64-bit Detecting UUSP...Pease wailt! Device Description: ELRASOFT UPA-USB Driver (3.4.1.20) USB Driver Name: UPAUSB.sys, HS Mode 5V Tests. Close J1 and press a key to continue --------------------------------------------------------------------------------------------------------------- Test1: P1=0V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V Result: P1=0,00V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V Test Passed --------------------------------------------------------------------------------------------------------------- Test2: P1=8V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V Result: P1=8,15V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V Test Passed --------------------------------------------------------------------------------------------------------------- Test3: P1=9V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V Result: P1=9,23V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V Test Passed --------------------------------------------------------------------------------------------------------------- Test4: P1=10V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V Result: P1=10,15V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V Test Passed --------------------------------------------------------------------------------------------------------------- Test5: P1=11V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V Result: P1=11,15V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V Test Passed --------------------------------------------------------------------------------------------------------------- Test6: P1=12V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V Result: P1=12,13V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V Test Passed --------------------------------------------------------------------------------------------------------------- Test7: P1=13V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V Result: P1=13,29V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V Test Passed --------------------------------------------------------------------------------------------------------------- Test20: P1=0V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=5V Result: P1=0,00V, P2=4,08V (L), P3=0,00V (L), P4=0,00V (L),P6=4,09V (L), P7=0,00V (L), P8=0,00V (L), P9=4,95V P2(4,08V ) not in 3,00V - 4,00V P6(4,09V ) not in 3,00V - 4,00V Test Failed --------------------------------------------------------------------------------------------------------------- Test21: P1=0V, P2=L, P3=L, P4=L, P6=L, P7=L, P8=L, P9=5V Result: P1=0,00V, P2=0,05V (L), P3=0,00V (L), P4=0,00V (L),P6=0,05V (L), P7=0,00V (L), P8=0,00V (L), P9=4,93V Test Passed --------------------------------------------------------------------------------------------------------------- Test22: P1=0V, P2=H, P3=H, P4=H, P6=H, P7=H, P8=H, P9=5V Result: P1=0,00V, P2=4,96V (H), P3=5,01V (H), P4=4,95V (H),P6=4,98V (H), P7=5,00V (H), P8=4,93V (H), P9=4,95V Test Passed --------------------------------------------------------------------------------------------------------------- 3.3V Tests. Open J1 and press a key to continue --------------------------------------------------------------------------------------------------------------- Test40: P1=0V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=3.3V Result: P1=0,00V, P2=4,06V (H), P3=0,00V (H), P4=0,00V (H),P6=4,09V (H), P7=0,00V (H), P8=0,00V (H), P9=4,95V P2(4,06V ) not in 2,50V - 3,30V P6(4,09V ) not in 2,50V - 3,30V P9(4,95V ) not in 3,00V - 3,70V Test Failed --------------------------------------------------------------------------------------------------------------- Test41: P1=0V, P2=L, P3=L, P4=L, P6=L, P7=L, P8=L, P9=3.3V Result: P1=0,00V, P2=0,05V (L), P3=0,00V (L), P4=0,00V (L),P6=0,05V (L), P7=0,00V (L), P8=0,00V (L), P9=4,95V P9(4,95V ) not in 3,00V - 3,70V Test Failed --------------------------------------------------------------------------------------------------------------- Test42: P1=0V, P2=H, P3=H, P4=H, P6=H, P7=H, P8=H, P9=3.3V Result: P1=0,00V, P2=4,98V (H), P3=5,01V (H), P4=4,95V (H),P6=4,98V (H), P7=5,00V (H), P8=4,93V (H), P9=4,95V P2(4,98V ) not in 3,00V - 3,70V P3(5,01V ) not in 3,00V - 3,70V P4(4,95V ) not in 3,00V - 3,70V P6(4,98V ) not in 3,00V - 3,70V P7(5,00V ) not in 3,00V - 3,70V P8(4,93V ) not in 3,00V - 3,70V P9(4,95V ) not in 3,00V - 3,70V Test Failed --------------------------------------------------------------------------------------------------------------- Test60 9544961E0447E012 Test Passed --------------------------------------------------------------------------------------------------------------- 4 Tests failed y a t'il un reglage quelque par ? J'ai essayer les fusibles mais a regle pas le probleme. |
![]() Date d'inscription: mai 2015
Salut tu as déplacé le cavalier J1 quand il te le demande ?
| The Following User Says Thank You to Mook31 For This Useful Post: | CoLLosSe44 (26/09/2021) |
Nan quand e regarde j1 sur l'upa c'est un truc souder. j'urai bien pris une photo mais c'es ecrit en tout petit
---------- Post added at 08:32 PM ---------- Previous post was at 08:23 PM ---------- https://photos.app.goo.gl/8fk9xm3fhdHVmcaT6 Voici la photo j’ai reussi avec 12pro max lol |
La cavalier en plastique noir tu le soulève il se déplace. Il est branché pour faire contact entre 2 pin selon sa position.
on parle de celui que l'on voit sur la photo ?
![]() Date d'inscription: mars 2017
Non, Mook ne parle pas du J1 marqué en bas sur ta photo. Il parle du jumper en plastique noir pour switcher les contacts entre les pistes : > JUMPER .jpg |
| The Following 2 Users Say Thank You to boris93600 For This Useful Post: | CoLLosSe44 (26/09/2021), Mook31 (27/09/2021) |
#7 | |
je doit le retirer ou le deplacer ? |
C'est bon j'ai reussi avec un autre upa l'autre doit etre defectueu. par contre j'ai frame error lors de la lecture :/ J4AI DU FAIRE UNE ERREUR QUELQUE PAR
BON JE VIENS DE RESSAYER ET VOILA
ON DIRAI C'EST ALEATOIRE UPA-USB Device Programmer v12113 Licensed to: Kadir Kaleli System: Microsoft (build9200), 64-bit Detecting UUSP...Pease wailt! Device Description: ELRASOFT UPA-USB Driver (3.4.1.20) USB Driver Name: UPAUSB.sys, HS Mode 5V Tests. Close J1 and press a key to continue --------------------------------------------------------------------------------------------------------------- Test1: P1=0V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V Result: P1=0,00V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V Test Passed --------------------------------------------------------------------------------------------------------------- Test2: P1=8V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V Result: P1=15,05V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V P1(15,05V ) not in 7,70V - 8,30V Test Failed --------------------------------------------------------------------------------------------------------------- Test3: P1=9V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V Result: P1=10,76V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V P1(10,76V ) not in 8,70V - 9,30V Test Failed --------------------------------------------------------------------------------------------------------------- Test4: P1=10V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V Result: P1=9,96V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V Test Passed --------------------------------------------------------------------------------------------------------------- Test5: P1=11V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V Result: P1=10,78V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V Test Passed --------------------------------------------------------------------------------------------------------------- Test6: P1=12V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V Result: P1=11,86V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V Test Passed --------------------------------------------------------------------------------------------------------------- Test7: P1=13V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V Result: P1=12,91V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V Test Passed --------------------------------------------------------------------------------------------------------------- Test20: P1=0V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=5V Result: P1=0,00V, P2=3,92V (L), P3=0,00V (L), P4=0,00V (L),P6=3,95V (L), P7=0,00V (L), P8=0,00V (L), P9=4,79V Test Passed --------------------------------------------------------------------------------------------------------------- Test21: P1=0V, P2=L, P3=L, P4=L, P6=L, P7=L, P8=L, P9=5V Result: P1=0,00V, P2=0,05V (L), P3=0,00V (L), P4=0,00V (L),P6=0,05V (L), P7=0,00V (L), P8=0,00V (L), P9=4,80V Test Passed --------------------------------------------------------------------------------------------------------------- Test22: P1=0V, P2=H, P3=H, P4=H, P6=H, P7=H, P8=H, P9=5V Result: P1=0,00V, P2=4,77V (H), P3=4,80V (H), P4=4,79V (H),P6=4,80V (H), P7=4,82V (H), P8=4,79V (H), P9=4,80V Test Passed --------------------------------------------------------------------------------------------------------------- 3.3V Tests. Open J1 and press a key to continue --------------------------------------------------------------------------------------------------------------- Test40: P1=0V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=3.3V Result: P1=0,00V, P2=2,84V (H), P3=0,00V (H), P4=0,00V (H),P6=2,87V (H), P7=0,00V (H), P8=0,00V (H), P9=3,35V Test Passed --------------------------------------------------------------------------------------------------------------- Test41: P1=0V, P2=L, P3=L, P4=L, P6=L, P7=L, P8=L, P9=3.3V Result: P1=0,00V, P2=0,03V (L), P3=0,00V (L), P4=0,00V (L),P6=0,03V (L), P7=0,00V (L), P8=0,00V (L), P9=3,34V Test Passed --------------------------------------------------------------------------------------------------------------- Test42: P1=0V, P2=H, P3=H, P4=H, P6=H, P7=H, P8=H, P9=3.3V Result: P1=0,00V, P2=3,34V (H), P3=3,35V (H), P4=3,34V (H),P6=3,35V (H), P7=3,37V (H), P8=3,34V (H), P9=3,35V Test Passed --------------------------------------------------------------------------------------------------------------- Test60 9544961E0447E012 Test Passed --------------------------------------------------------------------------------------------------------------- 2 Tests failed |
Si tu as suivi les instructions du J1, change de câble usb, et selon la qualité de ton clone tu peux reprendre les soudures.
| The Following User Says Thank You to Mook31 For This Useful Post: | CoLLosSe44 (27/09/2021) |
j'ai posté pour le même problème j'ai essayé toues les solutions, en denier j'ai "sacrifié" un bsi en dessoudant cet UPD, et soudé sur la platine, avant, j'ai essayé 2 adaptateurs un jaune et un vert, avec et sans les modifications du coup le propriétaire du berlingo, accepte le off, le HIC !!!!!! ![]() ![]() j'ai des problèmes de communication avec le tableau de bord, tr/mn et température moteur, et la cerise sur le gâteau: alors que le véhicule démarrait normalement, hier pas de démarrage et aucun dtc bonne journée |
| The Following User Says Thank You to mahfoud lichani For This Useful Post: | CoLLosSe44 (29/09/2021) |
J'ai tout essayer soudure cable un vrai casse tete upa je vais surement investir dans l'original
#13 | |
J’ai tout essayé du moins je pense avoir avoir tout essayé https://photos.app.goo.gl/S12MNQKwTDujipDV8 https://photos.app.goo.gl/hMvGNHmVcnTjwT9g8 https://photos.app.goo.gl/empoJZhn1kyJFziN8 |
J’ai pas sa. J’ai sûrement tout sauf sa.
https://photos.app.goo.gl/YwuH94oqzgz92Cdk9 Ta un lien pour je l’achète ? |
#15 |
Du coup j’ai beaucoup de mal avec upa. Vous pensez avec nec programmer j’ai plus de chance ? Je vais sûrement l’acheter
