Précédent   Tlemcen Car electronics > Tableau de bord, Habitacle & securité conducteur > Airbag
Airbag Questions et réponse pour vos problèmes avec la sécurité passive airbag.
Vieux 06/02/2022, 11h27   #241
stephane
Avatar de stephane
Pouvoir de réputation: 120
stephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond repute
V32.0.271.427
- Nouveau firmware v1.75
- Prend en charge la famille Renesas R8C R5F2154xx
- R5F21546E
- R5F21547E
- R5F21548E
- R5F2154AE
- R5F2154CE
- R5F21546F
- R5F21547F
- R5F21548F
- R5F2154AF
- R5F2154CF
- R5F21546G
- R5F21547G
- R5F21548G
- R5F2154AG
- R5F2154CG
- R5F21546H
- R5F21547H
-R5F21548H
-R5F2154AH
- R5F2154CH
- Ajout de 6 ECU
-HONDA DENSO 77960-T5A-J411-M2 (TD150800-0252) R5F2194AE
-HONDA DENSO 77960-T5A-J512-M2 (TD150800-0583) R5F2154AE
- HONDA DENSO 77960-T5A-W512-M2 (TD150800-1402) R5F2154AE
- HONDA DENSO 77960-TSV-W012-M2 (TD150800-7521) R5F2154AE
- SUZUKI DENSO 38910-69R10 (TD150800-6301) R5F2154AE
- SUZUKI DENSO 38910-79M00 (TD150800-0621) R5F2154AE
- Ajout/modification de 13 images de câblage
-Fiat TRW 00052017547 M95640
-Fiat TRW 00052090727 M95640
-Fiat TRW 00052090728 M95640
-Renault CONTINENTAL 285589605R M95640
-Renault CONTINENTAL 985105478R M95640
-Renault CONTINENTAL 985101389R(A2C80613911) SPC560P50
-Renault CONTINENTAL 985105123R(A2C80613411) SPC560P50
-Volvo AUTOLIV P31406938 XC2361A-72F
Correction de 4 ECU*:
-Volvo AUTOLIV P31429510 XC2361A-72F
stephane est déconnecté   Réponse avec citation
Vieux 06/02/2022, 22h36   #242
REDZONE31
Avatar de REDZONE31
Pouvoir de réputation: 82
REDZONE31 has a reputation beyond reputeREDZONE31 has a reputation beyond reputeREDZONE31 has a reputation beyond reputeREDZONE31 has a reputation beyond reputeREDZONE31 has a reputation beyond reputeREDZONE31 has a reputation beyond reputeREDZONE31 has a reputation beyond reputeREDZONE31 has a reputation beyond reputeREDZONE31 has a reputation beyond reputeREDZONE31 has a reputation beyond reputeREDZONE31 has a reputation beyond repute
slt Stéphane es ce que tu as eu le problème pour le firmware v1.75 impossible pour installer merci
Allah se comportera avec toi comme tu te comportes avec autrui
REDZONE31 est déconnecté   Réponse avec citation
Vieux 07/02/2022, 03h03   #243
stephane
Avatar de stephane
Salut REDZONE31
Non pas de souci pour la mise à jour
Quel est ton problème ?
Tu suit bien la procédure ?
The Following 2 Users Say Thank You to stephane For This Useful Post:
Fileul (11/02/2022), REDZONE31 (07/02/2022)
Vieux 07/02/2022, 08h59   #244
REDZONE31
Avatar de REDZONE31
re slt j'ai bien suivi installation comme dab télécharger le soft v32 et après sa me demande mise a jour firmware v1.75 une fois fait sa recommence votre version 1.74 et la nouvelle v1.75 en boucle voila frangin
c'étais juste une question ou cas tu as eu ce problème
Vieux 07/02/2022, 10h59   #245
REDZONE31
Avatar de REDZONE31
je viens faire un essai sur un pc Windows Seven problème réglé
The Following 2 Users Say Thank You to REDZONE31 For This Useful Post:
electronico (07/02/2022), stephane (07/02/2022)
Vieux 07/02/2022, 22h14   #246
stephane
Avatar de stephane
Étonnant je suis sous windows 11 64 aucun problème
A tu fait les mises à jour Windows ??
The Following User Says Thank You to stephane For This Useful Post:
REDZONE31 (08/02/2022)
Vieux 08/02/2022, 08h49   #247
electronico
Avatar de electronico
Pouvoir de réputation: 23
Envoyé par REDZONE31 Voir le message
Hello,
Juste pour ceux qui l'ont pas (ultraprog) : y avait un bug dans le firmware, ca a été corrigé avec la dernière version.
Dear UltraProg Members!
In V32.0 the firware version indication to V1.75 is faulty, the software after update still shows V1.74.
Due to above reason please download v32.0.271.429 and update firmware again.
Sorry for inconvenience.
The Following User Says Thank You to electronico For This Useful Post:
Vieux 08/02/2022, 09h40   #248
REDZONE31
Avatar de REDZONE31
Envoyé par stephane Voir le message
slt non pas du tout je suis toujours sous Windows 10 64
Vieux 12/04/2022, 17h23   #249
DIAGAUTO33
Avatar de DIAGAUTO33
Pouvoir de réputation: 32
DIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant future
Salut les gars
si quelqu'un peut m'éclairer svp :
Je viens de recevoir mon ultraprog, j'ai installé le dernier setup dispo, branché le cable usb et alim, quand je lance le soft, je séléctionne manuellement le bon port com, il trouve mon ultraprog et quelques secondes après, j'ai un message erreur interface not found et une fenetre qui dit si j'ai un firmware inférieur à1.16, il faut mettre à jour, sauf que apparement, mon firm est 1.17 mais ça fonctionne pas...
Bien sûr, j'ai essayé déjà d'autre cable usb et d'autre port, redémarrer , etc...
Je suis sur W7 PRO 64bits
J'ai mis à jour les drivers avec ceux du site mais pareil.
Si quelqu'un à eu le cas et peut m'aider...
Merci d'avance.
DIAGAUTO33 est déconnecté   Réponse avec citation
Vieux 12/04/2022, 17h43   #250
duroi
Avatar de duroi
Pouvoir de réputation: 27
duroi has much to be proud ofduroi has much to be proud ofduroi has much to be proud ofduroi has much to be proud ofduroi has much to be proud ofduroi has much to be proud ofduroi has much to be proud ofduroi has much to be proud of
Salut.
Essaie de démarrer l'application en tant que administrateur.
duroi est déconnecté   Réponse avec citation
The Following User Says Thank You to duroi For This Useful Post:
DIAGAUTO33 (12/04/2022)
Vieux 12/04/2022, 18h34   #251
DIAGAUTO33
Salut, déjà fait. Installation également en mode admin...
Vieux 12/04/2022, 20h33   #252
zav_ze_best
Avatar de zav_ze_best
zav_ze_best has much to be proud ofzav_ze_best has much to be proud ofzav_ze_best has much to be proud ofzav_ze_best has much to be proud ofzav_ze_best has much to be proud ofzav_ze_best has much to be proud ofzav_ze_best has much to be proud ofzav_ze_best has much to be proud of
Envoyé par DIAGAUTO33 Voir le message
As tu regarder sur leur site s'il n'y a pas de dépendances pour utiliser leur logiciel ?
C'est bizarre quand même...
zav_ze_best est déconnecté   Réponse avec citation
The Following User Says Thank You to zav_ze_best For This Useful Post:
Vieux 12/04/2022, 20h50   #253
stephane
Avatar de stephane
Salutations une mise à jour n'est pas rétroactive si tu est en 1.74
C est que ton setup es trop vieux
Contact Ervin il fera le nécessaire
Vieux 12/04/2022, 21h04   #254
DIAGAUTO33
Salut j'ai contacter déjà Erwin et il va jetter un coup d'œil par TeamViewer demain normalement.
Un grand merci également à Nordax pour son aide ;)
Petite découverte dans mon problème :
Quand j'ouvre le soft avec internet ON, et que je click sur 'trouver interface sur tous les ports', le logiciel ne trouve pas l'interface et reste figé. Obligé de tout arrêter avec gestionnaire des tâches.
Si j'ouvre le soft avec internet ON et que je sélectionne le port COM manuellement, il trouve l'interface quelques secondes puis j'obtiens l'erreur interface not found.
Si je lance le soft avec internet OFF et que je click sur "trouver interface sur tous les ports", il trouve bien mon interface, mais par contre ça reste bloqué sur "loading please wait"...
Petite correction également, le firm de mon interface n'est pas 1.17 mais 1.77...
Merci a tous encore pour vos réponses les amis !
The Following 2 Users Say Thank You to DIAGAUTO33 For This Useful Post:
NORDAX (12/04/2022), zav_ze_best (12/04/2022)
Vieux 13/04/2022, 14h14   #255
DIAGAUTO33
Salut les gars,
c'est bon pour moi.
Ervin à résolu le problème.
Merci à tous pour vos conseils en tous cas !
The Following 3 Users Say Thank You to DIAGAUTO33 For This Useful Post:
electronico (14/04/2022), redpoker (13/04/2022), zefirin (13/04/2022)
ultraprog roilion007 Airbag 9 02/09/2019 11h53
Ultraprog 17.3.8 LA .rar muco4020 Autocom, Delphi, Actia, Bosch, SPC, BrainBee, Autel 6 07/11/2018 23h32
Ultraprog 17.3.8 k.emra Airbag 2 22/12/2017 08h34
info ultraprog stephane Airbag 5 07/02/2016 01h12
qui connait ultraprog samm Programmeur de chip 9 23/11/2012 16h52
Fuseau horaire GMT +1. Il est actuellement 17h47.
