Vieux 26/10/2023, 09h02   #16
CleAuto64
Avatar de CleAuto64
CleAuto64 is a name known to allCleAuto64 is a name known to allCleAuto64 is a name known to allCleAuto64 is a name known to allCleAuto64 is a name known to allCleAuto64 is a name known to all
Salut si besoin je dois avoir des ews 3. Envoi le fichier et je te le clone sur un des miens.
Envoyé de mon SM-S911B en utilisant Tapatalk
CleAuto64 est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to CleAuto64 For This Useful Post:
gary01 (26/10/2023), mawoussiboris (26/10/2023)
Vieux 26/10/2023, 09h29   #17
progdebutant
Avatar de progdebutant
progdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond repute
Envoyé par gary01 Voir le message
Salut greg,
Lire ca passe nikel c’est juste l’ecriture qui veux pas passer je comprend pas.j’y met tout mon poids dessus mais ca veux pas y allez je sais pas pk
Salut Gary
tu as quoi comme message d'erreur ?
J'ai un AK90 si tu veux je te l'envoi pour tester ou envoi ton ews je le fais avec carprog
progdebutant est déconnecté   Réponse avec citation
The Following User Says Thank You to progdebutant For This Useful Post:
gary01 (26/10/2023)
Vieux 26/10/2023, 10h02   #18
abdel93
Avatar de abdel93
Pouvoir de réputation: 31
abdel93 has a reputation beyond reputeabdel93 has a reputation beyond reputeabdel93 has a reputation beyond reputeabdel93 has a reputation beyond reputeabdel93 has a reputation beyond reputeabdel93 has a reputation beyond reputeabdel93 has a reputation beyond reputeabdel93 has a reputation beyond reputeabdel93 has a reputation beyond reputeabdel93 has a reputation beyond reputeabdel93 has a reputation beyond repute
slt personnelement jamais réussi a lire avec AK90 ,même en nettoyant bien et en appuyant comme un fou ,xprog est mieux
un petit thank ca fait pas de mal
abdel93 est déconnecté   Réponse avec citation
The Following User Says Thank You to abdel93 For This Useful Post:
gary01 (26/10/2023)
Vieux 26/10/2023, 16h20   #19
gary01
Avatar de gary01
Pouvoir de réputation: 102
En message j’ai write error.j’ai recommandé un autre ak90 sur amazon lui il ce deconnecte toute les 2 secondes decidement
Vieux 26/10/2023, 18h20   #20
POCOYO
Avatar de POCOYO
Pouvoir de réputation: 65
Tu as bien gratter les connexions du mcu et positionner le petit chapeau
Les couleurs nappes clair extérieur droit
Et rouge etc…à gauche sur le board
Comme sur cette photo
Entendre ou lire sans réfléchir est une occupation vaine
gary01 (26/10/2023)
Vieux 26/10/2023, 18h27   #21
gary01
Avatar de gary01
Oui tout est ok.ce qui est bizarre c’est qu’il y’a a peine 8 octets de difference avec le dump ori tout le reste s’ecrit bien c’est identique
Vieux 27/10/2023, 11h43   #22
gary01
Avatar de gary01
Bon a cloturer le mec etait un peu trop pressé je lui ai rendu ses boitiers
Vieux 27/10/2023, 21h49   #23
mecano13
Avatar de mecano13
Pouvoir de réputation: 23
mecano13 has much to be proud ofmecano13 has much to be proud ofmecano13 has much to be proud ofmecano13 has much to be proud ofmecano13 has much to be proud ofmecano13 has much to be proud ofmecano13 has much to be proud ofmecano13 has much to be proud of
Salut au ak90+ sa passe mes faut bien enlever le vernis au solvant et un petit coup de papier et vert et sa marche
mecano13 est déconnecté   Réponse avec citation
The Following User Says Thank You to mecano13 For This Useful Post:
gary01 (28/10/2023)
Vieux 27/10/2023, 23h03   #24
martinn
Avatar de martinn
martinn is a splendid one to beholdmartinn is a splendid one to beholdmartinn is a splendid one to beholdmartinn is a splendid one to beholdmartinn is a splendid one to beholdmartinn is a splendid one to beholdmartinn is a splendid one to beholdmartinn is a splendid one to behold
vous etes sur du clone avec AK90 parce que moi de memoire j avais deux ak90 et il te donne des dump bizzare il etait different. et j arrivais pas a les cloner avec.
par contre xprog fait bien le boulot
martinn est déconnecté   Réponse avec citation
The Following User Says Thank You to martinn For This Useful Post:
gary01 (28/10/2023)
Vieux 28/10/2023, 08h44   #25
gary01
Avatar de gary01
Envoyé par mecano13 Voir le message
J’ai bien nettoyer au disolvant et gratter un peu avec un cutter de precision mais rien n’y fait
Vieux 28/10/2023, 09h32   #26
Pouvoir de réputation: 107
Tu as lu + écrit l EEP et Rom Area ?
Quel mask exactement ?
Quel taille de fichier ?
gary01 (28/10/2023)
Vieux 28/10/2023, 09h40   #27
NORDAX
Avatar de NORDAX
Pouvoir de réputation: 40
NORDAX has a reputation beyond reputeNORDAX has a reputation beyond reputeNORDAX has a reputation beyond reputeNORDAX has a reputation beyond reputeNORDAX has a reputation beyond reputeNORDAX has a reputation beyond reputeNORDAX has a reputation beyond reputeNORDAX has a reputation beyond reputeNORDAX has a reputation beyond reputeNORDAX has a reputation beyond reputeNORDAX has a reputation beyond repute
hello pourquoi tu na pas dessouder direct ! au moins sa fonctionne sur
NORDAX est déconnecté   Réponse avec citation
The Following User Says Thank You to NORDAX For This Useful Post:
gary01 (28/10/2023)
Vieux 28/10/2023, 09h50   #28
gary01
Avatar de gary01
0D46J pour un fichier de 512 octets donc full si je dit pas de connerie
---------- Post added at 07h50 ---------- Previous post was at 07h47 ----------
Envoyé par NORDAX Voir le message
Pourquoi j’ai pas dessouder,tout simplement parce que quand le mec ce ramene avec son boitier de rechange je prend pas de risque.si le boitier de rechange est defectueux ca va dire que c’est de ma faute.je voulais pas prendre le truc a la base le mec a fait diagnostiquer par un mec puis fait intervenir un autre pour au final me ramener le truc.
Donc dans ces conditions je vais pas me prendre la tete longtemps.pareil je sais qu’avec upa tu peux le faire mais il faut couper les pistes.hors de question aussi si le boitier marche pas et qu’il ce retourne contre le mec qui lui a vendu je sais tres bien comment ca va ce finir
The Following 2 Users Say Thank You to gary01 For This Useful Post:
NORDAX (28/10/2023), Quattro899 (28/10/2023)
Vieux 28/10/2023, 09h57   #29
Je vais vérifier mais full c est plus grand si j’me souviens bien
Tu peux poster ?
gary01 (28/10/2023)
Vieux 28/10/2023, 10h19   #30
yann3
Avatar de yann3
Pouvoir de réputation: 74
xprog pour lire et ecrire et AK90 pour generé la clé
http://www.armoreprog.fr
yann3 est connecté maintenant   Réponse avec citation
test fvdi clone du clone 2014 sans softgog fufounet Café du forum 22 02/09/2021 07h16
[VENDS]KessV2 clone et Ktag clone SaTouF Vente, Achat, Echange 11 30/03/2021 17h30
Vend Kess v2 5.017 clone, ktag 7,020,fgtech 4075 clone xdols Vente, Achat, Echange 1 01/03/2021 15h25
clone bsi 308 marikette Programmeur de chip 33 07/07/2020 21h41
Fuseau horaire GMT +1. Il est actuellement 11h49.
