Vieux 17/02/2017, 08h56   #16
doud77
Avatar de doud77
doud77 has a brilliant futuredoud77 has a brilliant futuredoud77 has a brilliant futuredoud77 has a brilliant futuredoud77 has a brilliant futuredoud77 has a brilliant futuredoud77 has a brilliant futuredoud77 has a brilliant futuredoud77 has a brilliant futuredoud77 has a brilliant futuredoud77 has a brilliant future
J'ai testé un immo vierge avec uid3.2...mais ca ne se fonctionne pas.
doud77 est déconnecté   Réponse avec citation
Vieux 17/02/2017, 10h15   #17
jpay2
Avatar de jpay2
jpay2 has a brilliant futurejpay2 has a brilliant futurejpay2 has a brilliant futurejpay2 has a brilliant futurejpay2 has a brilliant futurejpay2 has a brilliant futurejpay2 has a brilliant futurejpay2 has a brilliant futurejpay2 has a brilliant futurejpay2 has a brilliant futurejpay2 has a brilliant future
salut ,j'ai ouvert mes ecu en stock,
c2 =hybride
t1=hybride
les autre ete deja ouvert et je n'avais pas reperer la version ...
jpay2 est déconnecté   Réponse avec citation
Vieux 17/02/2017, 12h28   #18
dadal
Avatar de dadal
dadal will become famous soon enoughdadal will become famous soon enough
I have same problem with T4 version, iud3.2 doesnt works on this ecu
i dont have still no solution for T4,
you can try this tested immo off dump, may be this works also on T3
pass in PM
Type de fichier : rar Tested 5nr2.T1 immo off.rar (675 octets, 21 affichages)
dadal est déconnecté   Réponse avec citation
Vieux 17/02/2017, 12h43   #19
doud77
Avatar de doud77
Envoyé par dadal Voir le message
pass in PM
Thx my friend i will test in 2 or 3 hours when I switch back to this problem.
Vieux 17/02/2017, 12h44   #20
doud77
Avatar de doud77
Envoyé par jpay2 Voir le message
c2 =hybride
t1=hybride
Merci a toi Jpay2.
Vieux 17/02/2017, 18h14   #21
dadal
Avatar de dadal
Envoyé par doud77 Voir le message
sorry, J'oublié de dire, vous devez couper le fil +30 ( L4 in ecu harness)
Et relier la broche L4 à M4
https://s9.postimg.org/y09rhxc3z/5_NR2.jpg
The Following User Says Thank You to dadal For This Useful Post:
Mexanico1971 (04/08/2020)
Vieux 21/02/2017, 09h57   #22
doud77
Avatar de doud77
De ce que j'ai pu de retenir mon apprentissage sur ces boîtiers:
Premier point:
5NR.xx => calculateur hybride
5NR2.xx => calculateur full pcb
Second point:
5NR.Cx ou 5NR2.Cx => calculateur pour clio
5NR.Tx ou 5NR2.Tx => calculateur pour twingo
pin 95160 bsi C3 soustourou Transponder, code pin 5 29/12/2016 17h20
Bsi 307 95160 dell 66 Immobilizer dumps/solutions 5 11/06/2015 00h08
Pinout bsi valeo 307 95160 sofiane78 Réparation & Programmation des calculateurs 5 27/06/2014 19h08
pin 1 sur 95160 autodiag25 Electronique 14 08/12/2013 22h33
cherche PINOUT BSI 206 eeprom 95160 beka1975 Flasheur de calculateur 1 06/12/2013 19h20
Fuseau horaire GMT +1. Il est actuellement 13h44.
