Vieux 19/03/2019, 19h41   #46
electro_bordeaux1
Avatar de electro_bordeaux1
Pouvoir de réputation: 31
electro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud of
la faute que j ai mis c est que je n ai pas fais de sauvgarde d eprom je l ai souder directement au calculateur d ocasion
l union fait la force
electro_bordeaux1 est déconnecté   Réponse avec citation
Vieux 19/03/2019, 20h08   #47
progdebutant
Avatar de progdebutant
progdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond repute
nouveau fichier lien en mp
progdebutant est déconnecté   Réponse avec citation
The Following User Says Thank You to progdebutant For This Useful Post:
electro_bordeaux1 (19/03/2019)
Vieux 19/03/2019, 21h21   #48
yann3
Avatar de yann3
Pouvoir de réputation: 74
Envoyé par electro_bordeaux1 Voir le message
yann3 ton fichier ne demare pas defaillance antidemarage
c'est un partiel,donc a coder en partie
yann3 est connecté maintenant   Réponse avec citation
Vieux 19/03/2019, 21h25   #49
electro_bordeaux1
Envoyé par progdebutant Voir le message
ça demare come d habitude en mode degrade je t ai envoye le vin en mp frere
---------- Post added at 01h25 ---------- Previous post was at 01h24 ----------
y a t il des adresse a changer pour suprimer defaut eeprom
Vieux 19/03/2019, 21h34   #50
progdebutant
Ok mais as tu essayer de coder le vin et injecteurs avec ce nouveau dump ?
Vieux 19/03/2019, 21h34   #51
bkprog13
Avatar de bkprog13
Pouvoir de réputation: 85
quand tu dis mode dégradé, c’est sur place ou tu roule avec la voiture ?
The Following User Says Thank You to bkprog13 For This Useful Post:
Vieux 19/03/2019, 21h35   #52
electro_bordeaux1
au premier coup accelere puis apres plus d acceleration
Vieux 19/03/2019, 21h37   #53
bkprog13
Avatar de bkprog13
dsl ça répond pas a la question, essaye de rouler avec
Vieux 19/03/2019, 21h38   #54
progdebutant
Et essaye si possible vin et codage injecteur pour voir ou si au moins Ca dialogue avec clip
electro_bordeaux1 (20/03/2019)
Vieux 19/03/2019, 21h40   #55
electro_bordeaux1
quand je demare le vehicule accelere jusqu a 3000tr par mn et quand tu accelere de nouveau tu trouve 1500tr par mn
Vieux 19/03/2019, 21h42   #56
bkprog13
Avatar de bkprog13
poste le dump que tu as maintenant dans ton boîtier et envoi moi ton vin en mp
Dernière modification par bkprog13 ; 19/03/2019 à 21h58.
Vieux 19/03/2019, 23h55   #57
hatem006
Avatar de hatem006
Pouvoir de réputation: 22
hatem006 has much to be proud ofhatem006 has much to be proud ofhatem006 has much to be proud ofhatem006 has much to be proud ofhatem006 has much to be proud ofhatem006 has much to be proud ofhatem006 has much to be proud ofhatem006 has much to be proud ofhatem006 has much to be proud of
voila pour toi un vierge testé ok n'oublie pas le thanks et le retour merci dans ta boite
Type de fichier : bin 95160 vierge testé ok 100%.bin (2,0 Ko, 8 affichages)
hatem006 est déconnecté   Réponse avec citation
The Following User Says Thank You to hatem006 For This Useful Post:
Vieux 20/03/2019, 09h50   #58
electro_bordeaux1
Envoyé par hatem006 Voir le message
ce vierge est deja teste _a donne defaut eeprom et code injecteurs
et avec delphie et lunch aussi il n accepte pas les code injecteurs
Vieux 20/03/2019, 11h46   #59
electro_bordeaux1
j ai reussi a demarer le vehicule avec son dump d origine
au diag defaut eeprom et toujours en mode degrade
Vieux 20/03/2019, 11h50   #60
bkprog13
Avatar de bkprog13
oui poste la lecture d’origine en dégradé
Calculateur delphy 3.4 vierge et bosch mexicain Vente, Achat, Echange 0 05/08/2017 18h31
Vierge calculateur laguna Bosch EDC16C3 matt1781 Immobilizer dumps/solutions 1 27/10/2014 08h29
Calculateur bosch mev 17.4.2 Meziane93 Electronique 0 12/01/2014 12h05
calculateur bosch zaouibachir Flasheur de calculateur 4 21/10/2012 20h00
Calculateur 7.40 i bosch beonce Immobilizer dumps/solutions 1 04/04/2012 00h04
Fuseau horaire GMT +1. Il est actuellement 17h13.
