Vieux 20/03/2019, 11h52   #61
progdebutant
Avatar de progdebutant
progdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond repute
Envoyé par electro_bordeaux1 Voir le message
j ai reussi a demarer le vehicule avec son dump d origine
au diag defaut eeprom et toujours en mode degrade
salut l'ami
désolé je comprends plus rien.
dump d'origine ?
tu l'as encore ?
as tu essayé le vierge que je t'ai envoyé avec le vin dedans ?
t'as essayer d'effacer les défauts pour voir ?
progdebutant est déconnecté   Réponse avec citation
The Following User Says Thank You to progdebutant For This Useful Post:
electro_bordeaux1 (20/03/2019)
Vieux 20/03/2019, 12h03   #62
electro_bordeaux1
Avatar de electro_bordeaux1
Pouvoir de réputation: 31
electro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud of
Envoyé par progdebutant Voir le message
salut l'ami
dump d'origine ?
tu l'as encore ?
j ai essayer les deux fichiers toujours defaut eeprom et mode degrade
l union fait la force
electro_bordeaux1 est déconnecté   Réponse avec citation
Vieux 20/03/2019, 12h11   #63
electro_bordeaux1
le fichier qui demare le vehicule avec un seule defaut au diag
defaut eeprom
Type de fichier : rar 95160 rep.rar (670 octets, 6 affichages)
Vieux 20/03/2019, 12h24   #64
INVICTUS
Avatar de INVICTUS
Pouvoir de réputation: 96
Salut l'eeprom partage certains infos avec la flash d ou ton code erreur VIN code injecteur cest ok ???????
Envoyé de mon SM-G935U en utilisant Tapatalk
INVICTUS est déconnecté   Réponse avec citation
The Following User Says Thank You to INVICTUS For This Useful Post:
Vieux 20/03/2019, 12h27   #65
hatem006
Avatar de hatem006
Pouvoir de réputation: 22
hatem006 has much to be proud ofhatem006 has much to be proud ofhatem006 has much to be proud ofhatem006 has much to be proud ofhatem006 has much to be proud ofhatem006 has much to be proud ofhatem006 has much to be proud ofhatem006 has much to be proud ofhatem006 has much to be proud of
ce vierge est deja teste _a donne defaut eeprom et code injecteurs
et avec delphie et lunch aussi il n accepte pas les code injecteurs
Le dump que je t'ai donner je l'ai tester la semaine derniere sur la meme réference et et fonctionne nikel,c'est sur que ton problème est ailleur
hatem006 est déconnecté   Réponse avec citation
The Following User Says Thank You to hatem006 For This Useful Post:
Vieux 20/03/2019, 12h30   #66
electro_bordeaux1
Envoyé par AS2KER Voir le message
avec ce dump les codes injecteurs sont ok sauf defaut eeprom au diag
Vieux 20/03/2019, 12h32   #67
INVICTUS
Avatar de INVICTUS
Et le vin
Vieux 20/03/2019, 12h41   #68
progdebutant
Ton fichier qui démarre avec le vin mis manuellement
par contre soit plus claire parce que je t'avoue que je comprends plus rien lol
tu disai ne plus avoir le fichier ori, après tu dis l'avoir mais avec problème anti démarrage et maintenant tu dis fichier ori qui démarre
Type de fichier : bin 95160 rep.bin (2,0 Ko, 4 affichages)
Vieux 20/03/2019, 12h46   #69
electro_bordeaux1
le fichier original est corrompu apres avoir monte sur le calculateur d occasion je l ai reparer manuellement il demare maintenant avec changement de quelque adresse mais j ai le defaut eeprom avec diag et il est en mode degrade
Vieux 20/03/2019, 12h48   #70
progdebutant
l'ami tu las " réparer " comment ?
et as tu essayer de coder et injecteurs ?
essaye mon fichier dessus
Vieux 20/03/2019, 12h49   #71
bkprog13
Avatar de bkprog13
Pouvoir de réputation: 85
il faut comprendre que l'on ne peut pas "bricoler" par dessus tes essais, poste l'ORIGINE dans l'etat corrompu ou il se trouve.
PS: je comprend ta galere mais tu doit un peu ecouter si tu veux que ça marche
The Following 2 Users Say Thank You to bkprog13 For This Useful Post:
electro_bordeaux1 (20/03/2019), fenril68 (20/03/2019)
Vieux 20/03/2019, 13h02   #72
INVICTUS
Avatar de INVICTUS
TON vin ABSENT SUR TON DUMP QUI FAIT DEMARRE TU ECOUTE PAS
The Following 2 Users Say Thank You to INVICTUS For This Useful Post:
Vieux 20/03/2019, 13h42   #73
electro_bordeaux1
voici l eprom d origine
Type de fichier : rar 95160orig.rar (653 octets, 4 affichages)
Vieux 20/03/2019, 13h45   #74
progdebutant
L'ami tas essayer le fichier avec vin ou pa
Vieux 20/03/2019, 13h57   #75
bkprog13
Avatar de bkprog13
Les gars je sais pas pour vous mais moi j’arrête la, il vient de poster sois disant l'origine qui est en fait identique au premier dump du boitier d'occasion, il renomme les fichiers a sa guise, bye bye professeur electro bordeaux
hatem006 (20/03/2019), roilion007 (20/03/2019)
Calculateur delphy 3.4 vierge et bosch mexicain Vente, Achat, Echange 0 05/08/2017 18h31
Vierge calculateur laguna Bosch EDC16C3 matt1781 Immobilizer dumps/solutions 1 27/10/2014 08h29
Calculateur bosch mev 17.4.2 Meziane93 Electronique 0 12/01/2014 12h05
calculateur bosch zaouibachir Flasheur de calculateur 4 21/10/2012 20h00
Calculateur 7.40 i bosch beonce Immobilizer dumps/solutions 1 04/04/2012 00h04
Fuseau horaire GMT +1. Il est actuellement 14h06.
