#16 |
![]() Date d'inscription: décembre 2011
Pouvoir de réputation: 107 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Thanks apol very helpfull
#17 |
Update ok Nice
#18 |
Quelqu’un dispose t il du fichier pour décrypter les fichiers log service.Data
Suis curieux Merci |
#20 |
Hi apol
Want compare with vag imei data to have a manual api app Vag works but not with psa vci. Do you have previous FW exe for psa vci ? Seems one thing not working on new one... Many thanks |
#21 | |
Pouvoir de réputation: 14 ![]() ![]() ![]() ![]() |
SendGB | Send Large Files | Free file transfer |
#22 |
Perfect :-)
#24 |
The latest FW is fucked also downgraded to previous ... as VCI din't worked with other softwares only diagbox
#25 |
Yes same prefer previous
#26 |
Hello
J'ai installe un SW pour envoyer des commandes et pleins options sympa. Fonctionne au top sur la PSA Interface. Fourni en mp seulement au utilisateur ayant le tool pas la peine de m harceler :-) ---------- Post added at 10h38 ---------- Previous post was at 10h36 ---------- Et une version de diagbox deverouillee qui fonctionne impec egalement dessus j'ai fais des extractions log traces tout nickel |
| The Following 6 Users Say Thank You to fils For This Useful Post: | boris93600 (02/11/2024), Fastdiag (02/11/2024), jean-marc 10 (02/11/2024), jeremy72 (27/09/2025), NABILOV (02/11/2024), vortex (02/11/2024) |
#27 |
Update:-)
Read Cle inteligente Toy avec l app connue pour kline et can 29bits |
| The Following 3 Users Say Thank You to fils For This Useful Post: |
#28 |
| The Following 3 Users Say Thank You to apol For This Useful Post: |
#30 |
Thanks works perfectly with older you send
Will wait :-) |
| The Following User Says Thank You to fils For This Useful Post: | jeremy72 (27/09/2025) |
| Sponsored Link |
| Liens sociaux |
| Tags |
| faire, marche, qui, solution, topic |
| Outils de la discussion | |
| Probleme sur mon topic | desperadochti | Probleme des membres | 1 | 01/01/2021 12h21 |
| verrouiller ou suppromer mon topic | SaTouF | Probleme des membres | 0 | 10/09/2020 15h29 |
| topic | yann3 | LEXIA, PP2000, DiagBox | 6 | 20/09/2018 10h40 |
| Nouveau topic. | fred83 | Chiptuning | 21 | 25/11/2012 14h15 |
| Pdf sur un topic | samigravano | Probleme des membres | 4 | 18/11/2012 17h27 |
