Vieux 14/10/2016, 18h03   #16
RIMKACHIP
Avatar de RIMKACHIP
RIMKACHIP is a name known to allRIMKACHIP is a name known to allRIMKACHIP is a name known to allRIMKACHIP is a name known to allRIMKACHIP is a name known to allRIMKACHIP is a name known to all
Avec renault ecu tool ca passe comme une lettre a la poste mais a condition de dialoguer ou sur banc
RIMKACHIP est déconnecté   Réponse avec citation
Vieux 14/10/2016, 18h56   #17
kdo75
Avatar de kdo75
Pouvoir de réputation: 24
kdo75 has much to be proud ofkdo75 has much to be proud ofkdo75 has much to be proud ofkdo75 has much to be proud ofkdo75 has much to be proud ofkdo75 has much to be proud ofkdo75 has much to be proud ofkdo75 has much to be proud ofkdo75 has much to be proud of
Je vais regarder j ai fait une connerie tres dur a ouvrir le.tournevis a glisser sur un microprocesseur celle ou ya ecris dialoge je crois 4 patte abîmée degouter
Envoyé de mon HUAWEI CUN-L21 en utilisant Tapatalk
kdo75 est déconnecté   Réponse avec citation
Vieux 14/10/2016, 21h10   #18
Pouvoir de réputation: 277
Tu aurais du ouvrir comme edc16 moi je prend 4 vis btr diamètre 5 que je vis au fur a mesure en chauffant le tour avec ma station..
Vieux 14/10/2016, 21h43   #19
kdo75
Avatar de kdo75
Je connaissais pas la technique , voila mes connerie
Vieux 14/10/2016, 21h45   #20
kmtech
V.I.P
Avatar de kmtech
Pouvoir de réputation: 64
kmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond repute
Salut, c'est EDC15C13 : sur ce site tu trouves les détails des refs http://ecus.kmtech.fr/index.php?rech=0281011724
>> RocketDump << Logiciel Immo OFF/Immo vierge/Airbag reset/extraction code PIN, ...
kmtech est déconnecté   Réponse avec citation
Vieux 14/10/2016, 22h22   #21
doud77
Avatar de doud77
Pouvoir de réputation: 29
doud77 has a brilliant futuredoud77 has a brilliant futuredoud77 has a brilliant futuredoud77 has a brilliant futuredoud77 has a brilliant futuredoud77 has a brilliant futuredoud77 has a brilliant futuredoud77 has a brilliant futuredoud77 has a brilliant futuredoud77 has a brilliant futuredoud77 has a brilliant future
On voit même la trajectoire du tournevis!!
Tu répares les pattes cassees en pontant avec ptits fils gainés et cest bon!!
doud77 est déconnecté   Réponse avec citation
Vieux 14/10/2016, 22h59   #22
Smile
Envoyé par kdo75 Voir le message
Y doit y avoir moyen de redresser les pin et soudé... les contacte je pense enfin la c'est agrandi avec une bonne loupe tu peu essayé oui fallait l ouvrir comme un edc16 y a de la colle thermique sur un coter y sont pas mal dur a ouvrir mais une fois fais 2 trois fois c'est en 3 minutes c'est ouvert propres...
Vieux 14/10/2016, 23h03   #23
TAGADA
Avatar de TAGADA
TAGADA is a glorious beacon of lightTAGADA is a glorious beacon of lightTAGADA is a glorious beacon of lightTAGADA is a glorious beacon of lightTAGADA is a glorious beacon of light
duuuur!!!!! mais les piste sur le pcb n'ont pas l'air endomager
TAGADA est déconnecté   Réponse avec citation
Vieux 15/10/2016, 00h53   #24
kdo75
Avatar de kdo75
j ai dessoudr redresser mais je les ai casser , je suis bourrin lol demain j essayerai de reconnecter tout sa
si quelqu un en a 1 a vendre suis preneur
Vieux 15/10/2016, 11h18   #25
pouettedu76
Avatar de pouettedu76
Pouvoir de réputation: 76
Salut Kdo75 poste la photos que l'on puisse voir si c'est reparable ou pas
pouettedu76 est connecté maintenant   Réponse avec citation
kdo75 (15/10/2016)
Vieux 15/10/2016, 11h34   #26
kdo75
Avatar de kdo75
je vous poste sa ce soir
The Following User Says Thank You to kdo75 For This Useful Post:
pouettedu76 (15/10/2016)
Vieux 15/10/2016, 13h56   #27
kdo75
Avatar de kdo75
Voila mes conneries
Vieux 15/10/2016, 21h43   #28
pouettedu76
Bonsoir Kdo75 tu peut reparer les pins casser si tu a d'autres composant recupere 4pins que tu soude sur les 4 que tu a casser en fesant aussi la jonction sur le PCB regarde ta photos et essaye sa ne coute rien ou aussi peut etre en soudant un petit fil en cuivre sa va peut etre passer bon courage et c'est quoi se qu'il y a sur la photos on croirait de la soudure qui touche d'autre pin sa aussi se n'est pas bon et les fils c'est quoi sa ? merci pour ta reponce [IMG][/IMG]
Bonne soirée et bon week end @+
Vieux 15/10/2016, 22h52   #29
Slt kdo du même avis que pouette les pin du dessous sa devrais le faire mais sur le cotée que ces t'il passé??
Vieux 16/10/2016, 00h03   #30
kdo75
Avatar de kdo75
c est du coton j ai nettoyé a l alcool, llaisse tomber c trop chaud je suis pas minutieux
bosh me 7.4.4 freduj Transponder, code pin 2 01/10/2016 20h43
airbag 208 bosh TOUFIK 40 Airbag 0 30/07/2015 13h03
Dvd bosh esi 2013.3 bmpower30 Autres 1 19/06/2015 22h43
Immo off ecu bosh 0 261 204 076 geniehex Immobilizer dumps/solutions 7 17/12/2011 14h49
Fuseau horaire GMT +1. Il est actuellement 09h32.
