Vieux 24/11/2022, 11h17   #1
gary01
Avatar de gary01
Pouvoir de réputation: 104
Par défaut Vp44
Est ce qu’il existe une solution pour adapter une pompe vp44 sur zafira a sans avoir le pin de la voiture sur laquelle la pompe a été prise?
Vieux 24/11/2022, 12h24   #2
karimus
Avatar de karimus
karimus has much to be proud ofkarimus has much to be proud ofkarimus has much to be proud ofkarimus has much to be proud ofkarimus has much to be proud ofkarimus has much to be proud ofkarimus has much to be proud ofkarimus has much to be proud of
Bonjour gary01,
Regarde ça : https://www.tlemcen-electronic.com/f...ad.php?t=68352
Salutations.
le savoir se cultive par le partage
karimus est déconnecté   Réponse avec citation
The Following User Says Thank You to karimus For This Useful Post:
gary01 (24/11/2022)
Vieux 24/11/2022, 12h26   #3
Pouvoir de réputation: 175
carprog
https://www.youtube.com/watch?v=dj6ku6xXTdY
https://www.youtube.com/watch?v=mrcCibFm_Q8
gary01 (24/11/2022), mahfoud lichani (24/11/2022)
Vieux 24/11/2022, 12h41   #4
https://www.youtube.com/watch?v=DZFzaN2-lO0
https://www.codecard.eu/index.php?ac...&productId=375
gary01 (24/11/2022), karimus (24/11/2022), mahfoud lichani (24/11/2022)
Vieux 24/11/2022, 15h00   #5
Maimeun
Avatar de Maimeun
Maimeun is a name known to allMaimeun is a name known to allMaimeun is a name known to allMaimeun is a name known to allMaimeun is a name known to allMaimeun is a name known to all
Salut je confirme carprog déjà fait [emoji6]
Envoyé de mon SM-G965F en utilisant Tapatalk
Maimeun est déconnecté   Réponse avec citation
The Following User Says Thank You to Maimeun For This Useful Post:
gary01 (24/11/2022)
Vieux 24/11/2022, 15h04   #6
mcmomo
Avatar de mcmomo
Pouvoir de réputation: 26
mcmomo has a brilliant futuremcmomo has a brilliant futuremcmomo has a brilliant futuremcmomo has a brilliant futuremcmomo has a brilliant futuremcmomo has a brilliant futuremcmomo has a brilliant futuremcmomo has a brilliant futuremcmomo has a brilliant futuremcmomo has a brilliant futuremcmomo has a brilliant future
Salut l ami
C est quel zafira 2l ou 2l2
mcmomo est déconnecté   Réponse avec citation
The Following User Says Thank You to mcmomo For This Useful Post:
gary01 (24/11/2022)
Vieux 24/11/2022, 15h30   #7
gary01
Avatar de gary01
Merci les gars.malheureusement j’ai pas le carprog
---------- Post added at 14h30 ---------- Previous post was at 14h26 ----------
Envoyé par mcmomo Voir le message
Salut l ami
C’est un 2L
mcmomo (24/11/2022)
Vieux 24/11/2022, 15h39   #8
karimus
Avatar de karimus
C’est un 2L
Apparemment celui-ci fait l'affaire aussi :
http://blog.eobdtool.co.uk/faq-mpps-...esel-pump-ecu/
Salutations.
gary01 (24/11/2022)
Vieux 24/11/2022, 16h09   #9
mcmomo
Avatar de mcmomo
2 l il son pas codée sur zafira
The Following 3 Users Say Thank You to mcmomo For This Useful Post:
gary01 (24/11/2022), MecaTech (24/11/2022), Quattro899 (24/11/2022)
Vieux 24/11/2022, 16h31   #10
MecaTech
Banned
Avatar de MecaTech
MecaTech has a reputation beyond reputeMecaTech has a reputation beyond reputeMecaTech has a reputation beyond reputeMecaTech has a reputation beyond reputeMecaTech has a reputation beyond reputeMecaTech has a reputation beyond reputeMecaTech has a reputation beyond reputeMecaTech has a reputation beyond reputeMecaTech has a reputation beyond reputeMecaTech has a reputation beyond reputeMecaTech has a reputation beyond repute
Slt,
Je confirme sur les 2.0L aucun codage
MecaTech est déconnecté   Réponse avec citation
The Following 4 Users Say Thank You to MecaTech For This Useful Post:
baccaraboss (26/11/2022), gary01 (24/11/2022), mcmomo (24/11/2022), S0LlDSNAKE (06/11/2024)
Vieux 24/11/2022, 16h58   #11
gary01
Avatar de gary01
Pourtant suite au changement moteur ca demarre pas
mcmomo (25/11/2022), Quattro899 (24/11/2022)
Vieux 24/11/2022, 17h45   #12
DAVID02620
Avatar de DAVID02620
Pouvoir de réputation: 43
salut l ami
le souci c est la purge la dessus c est une galere voir meme la tirer pendant plussieurs centaines de metres pour qu'elle se reamorce et demarre enfin
The Following 7 Users Say Thank You to DAVID02620 For This Useful Post:
baccaraboss (26/11/2022), gary01 (24/11/2022), Maimeun (25/11/2022), mcmomo (24/11/2022), Quattro899 (24/11/2022), thomas (24/11/2022), vortex (24/11/2022)
Vieux 24/11/2022, 17h53   #13
mcmomo
Avatar de mcmomo
Si c est la purge faut juste ouvrir légèrement les tuyaux injection et quand sa crache bien tu resserre...sinon une poire sur la pompe de gasoil...pas besoin de tirer....vérifier aussi le fusible de la pompe injection ...sinon opcom et un bon diagnostic pour voir les défauts
The Following 4 Users Say Thank You to mcmomo For This Useful Post:
CoLLosSe44 (25/11/2022), gary01 (24/11/2022), Quattro899 (24/11/2022), vortex (24/11/2022)
Vieux 24/11/2022, 17h55   #14
gary01
Avatar de gary01
Merci les gars.en fait pour tout vous dire j’ai meme pas vu le vehicule.il est assez loin de chez moi.je vais me renseigner
The Following 3 Users Say Thank You to gary01 For This Useful Post:
DAVID02620 (25/11/2022), mcmomo (24/11/2022), Quattro899 (24/11/2022)
Vieux 24/11/2022, 21h46   #15
mahfoud lichani
Avatar de mahfoud lichani
Pouvoir de réputation: 41
salem
il ya déjà un moment, un ami mécano qui connait bien cette pompe -VP44- m'a dit que la purge ne se faisait pas comme sur les pompes classiques, il y a un système de dépression
je vous conseille de prendre l'avis d'un pompiste
bonne soirée
The Following 3 Users Say Thank You to mahfoud lichani For This Useful Post:
DAVID02620 (25/11/2022), gary01 (25/11/2022), sasa (12/06/2023)
Vp44 psg5 Thomas_59 VAG group vw, audi, skoda, seat, bentley, lamborghini, porsche 14 20/08/2019 15h16
Codage vp44 Ecomouv Opel-Vauxhall, Saab 24 06/04/2016 10h16
vp44 tonyguitare cimetière de présentation 0 05/04/2016 18h50
vp44 bmw78 Transponder, code pin 24 14/01/2015 09h57
apprentissage vp44 BMW nicosz57 Mécanique générale 1 25/04/2014 00h04
Fuseau horaire GMT +1. Il est actuellement 17h32.
