Vieux 07/04/2022, 01h10   #1
Nour01100
Avatar de Nour01100
Nour01100 is a name known to allNour01100 is a name known to allNour01100 is a name known to allNour01100 is a name known to allNour01100 is a name known to allNour01100 is a name known to all
Par défaut Référence compatible Nissan qashqai
Bonjour les amis
Quelqu'un pourrait me donner les ref compatible avec celle là ?
0281031463
1.6dci .elle a un problème de régulateur et selon Nissan ce serait le écu moteur qui est en rupture de stock
Merci d'avance
Nour01100 est déconnecté   Réponse avec citation
Vieux 07/04/2022, 12h15   #2
karimus
Avatar de karimus
karimus has much to be proud ofkarimus has much to be proud ofkarimus has much to be proud ofkarimus has much to be proud ofkarimus has much to be proud ofkarimus has much to be proud ofkarimus has much to be proud ofkarimus has much to be proud of
Salam Nour,
Les références compatibles sont les suivantes :
0281030440, 0281030849, 0281030993, 0281031044, 0281031099, 0281031100, 0281031463, 0281031467, 0281031608, 0281031832, 0281031997, 0281032090, 0281032314, 0281032929
Salutations.
le savoir se cultive par le partage
karimus est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to karimus For This Useful Post:
Dav (07/04/2022), Nour01100 (07/04/2022)
Vieux 07/04/2022, 14h07   #3
Dav
Avatar de Dav
Pouvoir de réputation: 53
Dav has a reputation beyond reputeDav has a reputation beyond reputeDav has a reputation beyond reputeDav has a reputation beyond reputeDav has a reputation beyond reputeDav has a reputation beyond reputeDav has a reputation beyond reputeDav has a reputation beyond reputeDav has a reputation beyond reputeDav has a reputation beyond reputeDav has a reputation beyond repute
A ajouter a la liste précèdente :
0281032884 , 0281033165 , 0281033255 , 0281033360
La ref la moins cher et la plus disponible : 0281031099
Lien du moins cher sur ebay :
Ebay
Dav est déconnecté   Réponse avec citation
The Following 6 Users Say Thank You to Dav For This Useful Post:
boul27 (07/04/2022), jah83 (07/04/2022), karimus (07/04/2022), MOUS25 (08/04/2022), Nour01100 (07/04/2022), phil1 (07/04/2022)
Vieux 07/04/2022, 19h15   #4
Pelican
Avatar de Pelican
c'est un problème de régulateur de pression carburant?
si c'est le cas j'ai eu une aventure avec un scenic3.
tu peut me donner des infos sur ton probleme.
ainsi que les déjà pièce remplacer.
les dtc présent?
The Following User Says Thank You to Pelican For This Useful Post:
Vieux 07/04/2022, 21h04   #5
Nour01100
Avatar de Nour01100
Envoyé par JulienP Voir le message
les dtc présent?
Slt Julien non c'est le régulateur de vitesse qui fonctionne pas pas de DTC .le limiteur fonctionne parfaitement. .ils l'ont gardé pendant 3 jours pour qu'au final ils estiment que c'est le calculateur moteur
Vieux 07/04/2022, 21h25   #6
Pelican
Avatar de Pelican
Ha oui,
Tu me redira si avec un nouveau calculateur ça fonctionne alors,
Stp, merci
A mon avis si tu clone tu clone le problème.
Bonne soirée et bonne recherche.
Biz
Envoyé de mon PRA-LX1 en utilisant Tapatalk
Vieux 08/04/2022, 13h12   #7
Nour01100
Avatar de Nour01100
Ha oui,
Stp, merci
Biz
Pas de souci .mais si c'était un problème logiciels tu crois pas qu'ils auraient fait un recodage ou une mise à jour ?
C'était ça mon raisonnement au départ
Vieux 08/04/2022, 15h28   #8
Pelican
Avatar de Pelican
Chez Renault si to. Écu est à jour.
Tu ne peu pas lancer la reprog.
Après si t'es ligne son bonne et que tes bouton aussi pourquoi pas.
Sur une Renault je ferai un reset batterie.
je lancerai une config auto.
Nour01100 (19/04/2022)
Vieux 08/04/2022, 17h20   #9
Pelican
Avatar de Pelican
Bas, si le problème n est pas connu et hors garantie,
Je craint que non.
Enfin je suppose.
Vieux 19/04/2022, 21h52   #10
Nour01100
Avatar de Nour01100
Slt Julien comme promis j'ai changé le calculateur et tu as eu raison c'est exactement la même chose je tiens à préciser que le limiteur fonctionne parfaitement le calculateur moteur détecte l'ppuie ou non sur la pédale de frein dans les paramètres en temps réel et au démarrage ( boîte auto ) je vais voir si j'ai un schéma sur Haynes pro même si je pense que chez nissan ils ont déjà fait leur test ( plastique autour du volant mal clipsé et trace de démontage des prise écu )
The Following User Says Thank You to Nour01100 For This Useful Post:
Pelican (20/04/2022)
Vieux 20/04/2022, 07h41   #11
Pelican
Avatar de Pelican
Pour la première chose à faire est de contrôler les lignes !
Dans les état ton régulateur est il présent ?
Dans les paramètres voi tu la position régulateur ?
Avec ddt ou quelque chose qui y ressemble peut tu voir la config actuel ?
Ça doit être une bricole !
Faut juste mettre le doigt dessus.
Nour01100 (22/04/2022)
Vieux 22/04/2022, 22h22   #12
Nour01100
Avatar de Nour01100
J'ai récupéré la voiture Aujourd'hui et avant de faire quoi que ce soit j'ai voulu jetter un œil sur le contacteur de pédale et il yen a 2 dont un qui était débranché quand je le branche les feux de stop restent allumé je l'ai démonté nettoyer il fonctionne bien mais j'ai l'impression que son fonctionnement est inversé car il allume les feux en appuyant dessus contrairement à ce que j'ai l'habitude de voir .or, on est obligé de le monter en position appuyé donc je sais pas si c'est la mauvaise pièce .
On peut diagnostiquer ça avec ddt4ll ?sinon je demande à Omar de m'installer le consult puis on verra bien.
Vieux 23/04/2022, 07h40   #13
Pelican
Avatar de Pelican
Peu être les connecteur entre les capteur son inverser ?
Avec un diag tu va dans les paramètres injection tu devrai avoir plusieurs infos.
Pedal de frein, embrayage, bouton +,- ect.
Il fait faire un bon diag.
Essay de récupérer des schéma.
Peu être un capteur à ete changer et ce n est pas le bon.
Au tableau de bord tu voi que tu active le régulateur ?
---------- Post added at 07h40 ---------- Previous post was at 07h38 ----------
Essay un scan avec dtt.
Et regarde tes paramètres
Vieux 08/05/2022, 09h53   #14
Pelican
Avatar de Pelican
Salut.
Alors des nouvelles ?
Vieux 08/05/2022, 12h31   #15
Nour01100
Avatar de Nour01100
Non j'ai récupéré un pc avec consult j'attends ma sonde pour faire un bon diag
Pelican (08/05/2022)
Référence compatible SID208 PSA progdebutant Réparation & Programmation des calculateurs 3 12/09/2020 21h40
boujour besoin clear crash airbag nissan Nissan Qashqai 98820 4EH0 everson29 Airbag 8 12/07/2018 18h49
Besoin reference calculo compatible. zefirin Réparation & Programmation des calculateurs 7 09/05/2018 11h01
compatible calculateur qashqai MUSTA11 Réparation & Programmation des calculateurs 0 07/09/2016 12h45
Moteur Compatible Nissan Qashqai bangreno Mécanique générale 3 15/09/2012 01h01
Fuseau horaire GMT +1. Il est actuellement 05h51.
