Vieux 22/11/2022, 17h25   #1
seadoo831
Avatar de seadoo831
Pouvoir de réputation: 122
Par défaut Dpf off et lambda off
Salut a tous qui pourais me faire un dpf off et lambda off
plus dtc lambda code defaut : P0135-00
Opel astra J de 2010 boitier denso cdlt
Type de fichier : rar Ori-Astra.rar (408,1 Ko, 6 affichages)
Pas de Thank's plus d aides
seadoo831 est connecté maintenant   Réponse avec citation
Vieux 22/11/2022, 17h45   #2
abdel59100
Avatar de abdel59100
abdel59100 has a reputation beyond reputeabdel59100 has a reputation beyond reputeabdel59100 has a reputation beyond reputeabdel59100 has a reputation beyond reputeabdel59100 has a reputation beyond reputeabdel59100 has a reputation beyond reputeabdel59100 has a reputation beyond reputeabdel59100 has a reputation beyond reputeabdel59100 has a reputation beyond reputeabdel59100 has a reputation beyond reputeabdel59100 has a reputation beyond repute
tiens
Type de fichier : rar Dpf+dtc off Opel_Astra_1.7 CDTI_TDI.rar (407,0 Ko, 4 affichages)
Swiftec,WinOls.......
Stage1 Stage2 E85
https://abperformance.fr
abdel59100 est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to abdel59100 For This Useful Post:
Fastdiag (24/11/2022), seadoo831 (22/11/2022)
Vieux 22/11/2022, 17h52   #3
zouaoui mohamed
Avatar de zouaoui mohamed
Pouvoir de réputation: 22
zouaoui mohamed is a splendid one to beholdzouaoui mohamed is a splendid one to beholdzouaoui mohamed is a splendid one to beholdzouaoui mohamed is a splendid one to beholdzouaoui mohamed is a splendid one to beholdzouaoui mohamed is a splendid one to beholdzouaoui mohamed is a splendid one to beholdzouaoui mohamed is a splendid one to behold
slt,
voila cadeau pour toi
mes salutations
سُبْحَانَ اللَّهِ وَالْحَمْدُ لِلَّهِ وَلا إِلَهَ إِلا اللَّهُ وَاللَّهُ أَكْبَرُ
zouaoui mohamed est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to zouaoui mohamed For This Useful Post:
Vieux 22/11/2022, 18h30   #4
seadoo831
Avatar de seadoo831
salut merci les amis je vous tien au jus des que j ai remis le boitier cdlt
Dernière modification par seadoo831 ; 22/11/2022 à 21h18.
Vieux 24/11/2022, 11h46   #5
seadoo831
Avatar de seadoo831
Salut fichier impeccable merci Abdel59100
Cdlt
Vieux 24/11/2022, 20h12   #6
seadoo831
Avatar de seadoo831
Bon bas le fichier n est pas bon a priori abdel
le client vien de m appeler il a le message puissance moteur réduite qui vien de s afficher et cela correspondrais a priori au fap et pas de puissance je vais tester le fichier zouaoui mohamed et vous tiendrais au courant cdlt
Dernière modification par seadoo831 ; 24/11/2022 à 20h20.
WJon (25/11/2022)
Vieux 24/11/2022, 21h46   #7
DIAG.ECO.POWER
Avatar de DIAG.ECO.POWER
DIAG.ECO.POWER is a splendid one to beholdDIAG.ECO.POWER is a splendid one to beholdDIAG.ECO.POWER is a splendid one to beholdDIAG.ECO.POWER is a splendid one to beholdDIAG.ECO.POWER is a splendid one to beholdDIAG.ECO.POWER is a splendid one to beholdDIAG.ECO.POWER is a splendid one to behold
Y avait pas une option (fap non present) a mette avec opcom sur les astra J? Pour pas que le defaut revienne apres X klm
Envoyé de mon 21081111RG en utilisant Tapatalk
DIAG.ECO.POWER est déconnecté   Réponse avec citation
Vieux 24/11/2022, 21h58   #8
seadoo831
Avatar de seadoo831
Salut ça je ne sait pas du tout cdlt
Vieux 24/11/2022, 22h00   #9
DIAG.ECO.POWER
Allez dans IPC et mettre le fap sur not present
The Following 2 Users Say Thank You to DIAG.ECO.POWER For This Useful Post:
seadoo831 (24/11/2022), WJon (25/11/2022)
Vieux 24/11/2022, 22h18   #10
seadoo831
Avatar de seadoo831
Merci je vais regarder quand le client reviendras cdlt
DIAG.ECO.POWER (24/11/2022)
sonde lambda sur SUZUKI Liana (RH41*) 1.6 i 16V 107 cv sonde lambda sur dede83 Mécanique générale 19 16/10/2020 21h42
sonde lambda sur SUZUKI Liana (RH41*) 1.6 i 16V 107 cv sonde lambda sur dede83 Mécanique générale 23 20/09/2020 13h51
Lambda off Black gees Automobile en général 3 09/02/2019 20h47
lambda off mahfoud lichani Fichiers d'origine, carto, dump, fullbackup 14 10/02/2018 22h34
lambda off nizar Chiptuning 2 23/03/2016 07h31
Fuseau horaire GMT +1. Il est actuellement 13h51.
