Précédent   Tlemcen Car electronics > Outils & Diag > Diagnostic automobile > Fiat, Alfaromeo, Lancia
Vieux 26/02/2024, 10h00   #1
kis2a
Avatar de kis2a
Par défaut Multiecuscan v5.1
Multiecuscan v5.1
MULTi WinALL
Envoyé par Multiecuscan 5.1
- Added information for more ISO codes from 2012-2023 vehicles
- Added support for new Fiat 500e
- Added support for Fiat 500 1.0 Hybrid
- Added support for Fiat Panda 1.0 Hybrid
- Added support for Lancia Ypsilon 1.0 Hybrid
- Added support for Fiat Ducato 290MCA (2021+)
- Added support for some Moto Guzzi bike models
- Added support for Vgate interfaces
- Support for Magneti Marelli IAW 11GF CF6D Injection (1.0N3 Hybrid) (Fiat 500, Panda, Lancia Ypsilon)
- Support for Parking control Bosch (Rear only) (Giulia/Stelvio)
- Support for Electronic Gear Shift Module (500e) (Fiat 500e US version)
- Support for Body Computer Marelli (290MCA) (Ducato 290MCA)
- Support for Tire Pressure Control (TPMS) Schrader (2/3 axle) (Ducato 290MCA)
- Support for Bosch ABS 9 ESP (Ducato 290MCA)
- Support for CAN Setup / PROXI Alignment Procedure (290MCA) (Ducato 290MCA)
- Support for Bosch ABS 9 ESP (Argo/Cronos)
- Support for Electric vehicle control Continental (New 500e, DTC codes only)
- Support for Battery pack control (New 500e, DTC codes only)
- Support for Integrated dual charger (New 500e, DTC codes only)
- Support for Continental ABS/iTPMS MK C1 (New 500e)
- Support for Magneti Marelli IAW 38MIUG Injection (Moto Guzzi)
un thanks , un mp = mot de passe
Type de fichier : txt Lien_Multiecuscan.v5.1.txt (195 octets, 57 affichages)
The Following 36 Users Say Thank You to kis2a For This Useful Post:
adiago (26/02/2024), alcap777 (04/03/2024), Alessiapia14 (28/02/2024), alfa-fiat (24/03/2024), autodiagauto (27/02/2024), BILAUTO (26/02/2024), Buzz (07/03/2024), chatgris08 (25/03/2024), curtis50 (26/02/2024), Ecom (26/05/2024), Galinette (11/02/2025), Honda (26/02/2024), ikbal031 (27/02/2024), jcb31100 (13/03/2024), jean-marc 10 (09/07/2024), julie.long (10/08/2024), Julien59820 (07/07/2024), K16S (13/03/2024), khalil84 (02/02/2025), KREUSTY (13/03/2024), KursMups (10/05/2025), marcodu45 (13/03/2024), masinisa (26/02/2024), Masterpwnd (19/04/2024), Melphistos (29/03/2024), mouaoued (19/01/2025), rrguillaume (26/02/2024), scottxsat (14/08/2024), selouan (03/05/2024), STEH1 (02/12/2024), taxi5114 (24/03/2024), transitions7 (01/10/2024), Truc (26/02/2024), virus97122 (30/05/2024), vortex (26/02/2024), zebulons (01/04/2024)
Vieux 25/03/2024, 12h26   #2
kis2a
Avatar de kis2a
version 5.1 : ajout du support de la vci : VGATE FS linker (celle optimiser pour forscan)
alfa-fiat (23/04/2024)
Vieux 29/03/2024, 09h55   #3
kis2a
Avatar de kis2a
il devais avoir un petit soucis avec le precedent , pourtant fonctionner ,
voici une nouvelle version avec correction ( CrackFix )
Type de fichier : txt Lien_Multiecuscan.v5.1.Version.CrackFix.txt (215 octets, 39 affichages)
The Following 6 Users Say Thank You to kis2a For This Useful Post:
alfa-fiat (23/04/2024), JTM (16/09/2024), ricou 81 (22/04/2024), xdols (29/03/2024), yahiadiag (05/04/2024), zebulons (01/04/2024)
Vieux 27/04/2024, 08h52   #4
kis2a
Avatar de kis2a
Version PROPER (amélioré):
Envoyé par GRP BLiZZARD
With multiecuscan always something happens
The exe from the crackfix still seems good
but the included keygenpatch fiddles around too much
So just use the included files
Type de fichier : txt Lien_Multiecuscan.v5.1.PROPER.CRACKFiX-BLiZZARD.txt (351 octets, 29 affichages)
The Following 3 Users Say Thank You to kis2a For This Useful Post:
lemrid (27/04/2024), vortex (27/04/2024), yahiadiag (27/04/2024)
Vieux 27/04/2024, 21h12   #5
kis2a
Avatar de kis2a
voici un nouveau lien , mot de passe du précédent perdu ,
Type de fichier : txt Lien_Multiecuscan.v5.1.PROPER.CRACKFiX-BLiZZARD.txt (351 octets, 63 affichages)
The Following 10 Users Say Thank You to kis2a For This Useful Post:
Auto-Diag (24/05/2024), fastboy974 (29/10/2024), Loubat (20/08/2024), marcodu45 (14/06/2024), Mook31 (01/06/2024), pp08 (28/04/2024), rocachristophe (01/10/2024), selouan (03/05/2024), virus97122 (30/05/2024), zebulons (25/05/2024)
Vieux 02/05/2024, 21h05   #6
kis2a
Avatar de kis2a
Envoyé par Truc Voir le message
Hi
please link - Multiecuscan 5.2
https://www.multiecuscan.net/
Vieux 26/05/2024, 11h22   #7
zebulons
Avatar de zebulons
zebulons is a glorious beacon of lightzebulons is a glorious beacon of lightzebulons is a glorious beacon of lightzebulons is a glorious beacon of lightzebulons is a glorious beacon of light
Salut je fais un retour sur la dernière version que tu a partagé la Version PROPER. Elle a résolu le problème ( data file error) testé sur w10 pro 64bit merci a toi.
zebulons est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to zebulons For This Useful Post:
kis2a (30/05/2024), taxi5114 (30/11/2024)
Vieux 14/06/2024, 20h11   #8
kis2a
Avatar de kis2a
Envoyé par zebulons Voir le message
le proper du crack a donc etais ok ,
si tu pour nous faire un retour , sur quel vci tu a utiliser ;)
taxi5114 (30/11/2024), zebulons (15/06/2024)
Vieux 14/06/2024, 20h51   #9
marcodu45
Avatar de marcodu45
marcodu45 is a glorious beacon of lightmarcodu45 is a glorious beacon of lightmarcodu45 is a glorious beacon of lightmarcodu45 is a glorious beacon of lightmarcodu45 is a glorious beacon of light
Slt kis2a,
Dernièrement je n'ai pas réussi à communiquer avec la bsi sur un citroen némo à architecture FIAT malgré l'adaptateur S1279 avec la version 4.9 et également 5.1 avec une interface ELM327 + adaptateurs couleurs
J'ai pu me connecter à plusieurs calculateurs mais il y a un beug sur celui de la bsi, la page de configuration ne s'ouvre pas alors qu'en cas de problème de connection c'est écrit échec de communication
Impossible avec diagbox de modifier la configuration pour rajouter l'option vitre électrique, il précise que c'est manufacturé ou un message du genre "on les reçoit déjà configuré" et c'est pour ça que je pense que multiecuscan doit pouvoir le faire
Je voudrais bien tenter avec cette version proper et sinon je voulais tester avec une version 3 ou maxi 4.1
marcodu45 est déconnecté   Réponse avec citation
Vieux 15/06/2024, 01h09   #10
Mook31
Avatar de Mook31
Pouvoir de réputation: 40
Salut installation ok, obdlink SX détecté OK.
Merci à toi !
Vieux 15/06/2024, 10h06   #11
zebulons
Avatar de zebulons
Salut j ai essayé avec un elm 327 en bluetooth sur un Doblo 2020 j ai juste fait un test de connexion qui était ok .j ai essayé aussi avec un câble godiag mais j ai pas réussi à me connecter.
Multiecuscan 4.9 pidoux44680 Fiat, Alfaromeo, Lancia 3 30/04/2023 13h54
multiecuscan 4.0 MAXYBOOM Autres 18 29/04/2019 08h23
multiecuscan 4.3 MAXYBOOM Autres 1 15/01/2019 00h25
multiecuscan RALPH Autres 7 18/09/2018 15h27
multiecuscan v3.6 zenata Fiat, Alfaromeo, Lancia 1 07/03/2018 14h21
Fuseau horaire GMT +1. Il est actuellement 11h53.
