Vieux 20/12/2024, 15h08   #1
tarik_electronic
Avatar de tarik_electronic
tarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond repute
Par défaut besoin immo off
j ai besoin d un immo 0ff
edc15c2 1 broche
Type de fichier : rar immo on 5PO8.rar (375 octets, 4 affichages)
oublié pas le petit " thanks "
tarik_electronic est déconnecté   Réponse avec citation
Vieux 20/12/2024, 15h25   #2
matt978
Avatar de matt978
Pouvoir de réputation: 8
matt978 is just really nicematt978 is just really nicematt978 is just really nicematt978 is just really nicematt978 is just really nice
Envoyé par tarik_electronic Voir le message
edc15c2 1 broche
c'est quoi comme auto?
Vieux 20/12/2024, 15h31   #3
matt978
Avatar de matt978
edc15c2 1 broche
je suis parti sur du bosch en dci renault
ECU - BOSCH with 5P08C3 memory e.g.
ECU - BOSCH 0 281 001 934 - 5P08C3 memory
ECU - BOSCH 0 281 010 437 - 5P08C3 memory
ECU - BOSCH 0 281 010 439 - 5P08C3 memory
ECU - BOSCH 0 281 010 632 - 5P08C3 memory
ECU - BOSCH 0 281 010 633 - 5P08C3 memory
ECU - BOSCH 0 281 010 637 - 5P08C3 memory
ECU - BOSCH 0 281 010 819 - 5P08C3 memory
ECU - BOSCH 0 281 011 325 - 5P08C3 memory
ECU - BOSCH 0 281 011 529 - 5P08C3 memory
si ca correspond a ta demande le "cleared" est la!
pass dans ta boite
Type de fichier : rar immo on 5PO8 ori and cleared.rar (891 octets, 2 affichages)
tarik_electronic (20/12/2024)
Vieux 20/12/2024, 16h19   #4
tarik_electronic
C5
0 281 010 365
Vieux 20/12/2024, 16h49   #5
matt978
Avatar de matt978
C5
0 281 010 365
tu es sur que ce n'est pas sur la flash 29F400 que l'imo se trouve??
Vieux 20/12/2024, 16h52   #6
tarik_electronic
J ai injecter le off de @ matt 978 mais il démarre pas . Off fonctionne pas
---------- Post added at 16h52 ---------- Previous post was at 16h49 ----------
Avec immokiller fonctionne pas
Vieux 20/12/2024, 16h57   #7
matt978
Avatar de matt978
sinon dessoude l'eeprom et essaye de la démarrer sans!
---------- Post added at 16h57 ---------- Previous post was at 16h53 ----------
Dans immo service tool
J'ai bien edc15c2 1 plug est c'est uniquement dans la flash.
Les 3 plugs c'est flash et 95080
Vieux 20/12/2024, 17h02   #8
tarik_electronic
L'avez-vous déjà essayé sans EEPROM ? Démarre en mode dégradé ??
Vieux 20/12/2024, 17h06   #9
matt978
Avatar de matt978
Moi non, mais j ai cru voir que ça fonctionne !!
Si tu peux essaye,
Mais sinon post le contenu de ta flash 29F400 et je te fait le off
Vieux 20/12/2024, 17h10   #10
matt978
Avatar de matt978
tient un vierge fait avec immo tool 1.5!!
tiens moi au jus
Type de fichier : rar immo on 5PO8 ori and cleared.rar (1,1 Ko, 1 affichages)
Vieux 20/12/2024, 17h46   #11
tarik_electronic
Envoyé par matt978 Voir le message
tiens moi au jus
Merci matt
Vierge ne résoudra pas le problème . Mon problème vien de transpodeur hs
Vieux 20/12/2024, 18h02   #12
matt978
Avatar de matt978
Ok,
Donc lit la flash et envoi moi son contenu et je te fait le off. Soit ce soir, soit demain
tarik_electronic (21/12/2024)
Vieux 20/12/2024, 18h17   #13
clemmmcm
Avatar de clemmmcm
clemmmcm is on a distinguished road
Essaye avec ça
Type de fichier : rar edc15c2 off.rar (160,2 Ko, 3 affichages)
clemmmcm est déconnecté   Réponse avec citation
The Following User Says Thank You to clemmmcm For This Useful Post:
Vieux 20/12/2024, 19h01   #14
ducla
Avatar de ducla
ducla is a jewel in the roughducla is a jewel in the roughducla is a jewel in the rough
Bonsoir.Si véhicule Peugeot l'immo est dans l'eprom et la voiture doit démarrer en enlevant l'eprom avec voyant moteur ou pas.Si ça ne démarre pas sans l'eprom tu as un autre problème.
ducla est déconnecté   Réponse avec citation
The Following User Says Thank You to ducla For This Useful Post:
Vieux 20/12/2024, 19h57   #15
tarik_electronic
Envoyé par ducla Voir le message
Citroen C5
0ff, besoin, edc15c2, immo, salut
besoin immo off sur mp7.2 madrid31 Flasheur de calculateur 7 01/10/2018 22h49
Besoin immo off Meziane93 Immobilizer dumps/solutions 28 04/03/2017 12h14
Besoin immo off 206 BOD69 Immobilizer dumps/solutions 13 22/10/2016 17h08
Besoin immo off 307 1.4 HDI jeronimo Immobilizer dumps/solutions 9 27/07/2016 17h34
Fuseau horaire GMT +1. Il est actuellement 07h32.
