Vieux 22/10/2014, 20h01   #1
Yougataga
Avatar de Yougataga
Yougataga will become famous soon enough
Par défaut Besoin d'un dump airbag ds3
J'aurais besoin d'un dump pour boitier d'air bag ds3
Référence 9676209280
Autoliv 620 67 43 00
Eep 95160
Si quelqu'un aurait le clear sa serait simpa
Merci a tous
Yougataga est déconnecté   Réponse avec citation
Vieux 22/10/2014, 20h07   #2
diagprog
Avatar de diagprog
diagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond repute
Salut, poste ton original dump.
diagprog est déconnecté   Réponse avec citation
Vieux 22/10/2014, 20h31   #3
yvespapou
Avatar de yvespapou
Pouvoir de réputation: 37
yvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond repute
Envoyé par Yougataga Voir le message
Eep 95160
Merci a tous
salut voila un clear testé 100%
donne le retour mdp dans ta boite
il suffit de changer le vf tu met le tien
Type de fichier : rar DS3 620 67 43 00 CLEAR.rar (1,3 Ko, 10 affichages)
Dernière modification par cedrsan ; 02/11/2014 à 11h45.
yvespapou est déconnecté   Réponse avec citation
The Following User Says Thank You to yvespapou For This Useful Post:
perso69 (23/11/2014)
Vieux 22/10/2014, 20h35   #4
Yougataga
Avatar de Yougataga
voici le fichier crash
Type de fichier : bin ABEDS3CR.bin (4,0 Ko, 10 affichages)
Vieux 22/10/2014, 20h40   #5
yvespapou
Avatar de yvespapou
voila ton clear
Type de fichier : bin clear DS3.bin (4,0 Ko, 8 affichages)
The Following 2 Users Say Thank You to yvespapou For This Useful Post:
perso69 (23/11/2014), Yougataga (22/10/2014)
Vieux 22/10/2014, 20h43   #6
yvespapou
Avatar de yvespapou
Envoyé par yvespapou Voir le message
voila ton clear
non il est pas bon je me suis trompé ne te sert pas de lui
Vieux 22/10/2014, 21h00   #7
Yougataga
Avatar de Yougataga
Oui je vien de vérifier il n'est pas bon
The Following User Says Thank You to Yougataga For This Useful Post:
yvespapou (22/10/2014)
Vieux 22/10/2014, 21h01   #8
Yougataga
Avatar de Yougataga
Le premier est bon ou pas
Vieux 22/10/2014, 21h12   #9
yvespapou
Avatar de yvespapou
moi le problème que je trouve c que le fichier que tu poste ne contient pas de crash ou alors il est corrompu
Vieux 22/10/2014, 21h13   #10
Yougataga
Avatar de Yougataga
Dsl je me suis également trompé c pas une 95160 mais une 95320
Wai mais le souci c que Ken je l'ai brancher a la voiture les voyant son allumer et au diag il met erreur de téléchargement calibration un truc comme sa
Dernière modification par cedrsan ; 02/11/2014 à 11h46.
Vieux 22/10/2014, 21h16   #11
yvespapou
Avatar de yvespapou
oui le premier est bon 100% mais c mieux de mettre le tien car tu risque d'avoir des défaut si tu n'a pas le même nombre d'airbag donc il te faudra le configurer avec diagbox
Vieux 22/10/2014, 21h17   #12
yvespapou
Avatar de yvespapou
avec quoi tu a fait le diag
Vieux 22/10/2014, 21h18   #13
Yougataga
Avatar de Yougataga
La je vien encore de comparer ton premier fichier que tu ma envoyer et mon fichier il y a différence
Si il y a une différence entre celui que tu ma envoyer en premier et le mien
Avec diagbox je vais esseiller ton premier fichier et si sa marche pas tampis en tout cas merci de ton aide
Vieux 22/10/2014, 21h22   #14
yvespapou
Avatar de yvespapou
la difference vient de la configuration du nombre d'airbag que ta voiture a
avec quoi tu a lu ton eeprom??????????
Vieux 22/10/2014, 21h38   #15
diagprog
Avatar de diagprog
salut,essayer ce clear et tien moi au jus, pass dans ta boite
bonne chance.
Type de fichier : rar ABEDS3CR cleared.rar (1,2 Ko, 2 affichages)
The Following User Says Thank You to diagprog For This Useful Post:
besoin dump airbag technicien Airbag 2 24/10/2014 19h58
Besoin d'aide Dump airbag crash on DK tronic Engineering Airbag 1 15/01/2014 21h53
Besoin clear airbag 207 matt1781 Airbag 6 26/06/2013 09h22
Besoin dump origine Airbag 207 diagautoprog Airbag 17 04/11/2011 09h38
besoin d un clear airbag mx-5 solution auto Airbag 2 23/02/2011 23h28
Fuseau horaire GMT +1. Il est actuellement 17h38.
