Précédent   Tlemcen Car electronics > Tableau de bord, Habitacle & securité conducteur > Tableau de bord en général
Tableau de bord en général soucis de language, ou toutes autres problemes, passez par ici
Vieux 22/03/2016, 21h31   #1
hugopinho
Avatar de hugopinho
hugopinho is on a distinguished road
Par défaut Clio III alternator problem
Hi friends
I have a problem with a Clio III, 1200 - 16 valves, 2007.
The car had problems with the alternator, it was charging irregularly, causing voltage spikes.
The alternator was repaired and it's OK.
Then, the car sometimes gives me the following error, by Clip:
DF046 (battery voltage)
and by Texa:
P0560
When this error appears, the car begins to fail, it doesn't accelerate.
I have allready checked connectors, contacts, battery, alternator... - everything OK.
I have also tryed with the alternator off, and it appears the same code error.
Could it be a problem with the Ecu?
Siemens SIM32
S120200105 A
820052357
8200510536
Regards and thanks in advanced
HugoPinho
hugopinho est déconnecté   Réponse avec citation
Vieux 22/03/2016, 22h14   #2
nowen
Avatar de nowen
Pouvoir de réputation: 65
hi HugoPinho,
At first change the UPC, Because it manages the charge
Vieux 23/03/2016, 15h53   #3
hugopinho
Avatar de hugopinho
Hi friends
I have another ecu
Siemens SIM32
S120200105 A
820052357
8200510536
To code it, is it just necessary to clone the eprom 95160?
Regards
problem demarrage clio 3 newfree Immobilizer dumps/solutions 23 16/02/2015 15h20
problem ralenti clio 3 1.2 ess desperado4ever Renault clip, DDT2000, Nissan consult 3 07/12/2014 17h22
Clio dci problem demarage memati Renault, Dacia, Nissan 1 19/11/2013 19h44
problem clio 1.9 dti diago2001 Renault, Dacia, Nissan 3 27/01/2012 21h30
Fuseau horaire GMT +1. Il est actuellement 02h06.
