Vieux 19/02/2017, 15h12   #1
mnaouar
Avatar de mnaouar
mnaouar is on a distinguished road
Par défaut citroen c5 edc15c2 immoff correct?
suite un immo off sur le flash de deux edc15c2 3_broche
le system de suspension hydropneumatique et aiguille tourne minutes marche pas .
default present sur bsi et ecu suspension ;
défaut permanent communication avec ecu moteur
Type de fichier : rar citroen c5 edc15c2 0281010808 1037353818.rar (293,5 Ko, 30 affichages)
mnaouar est déconnecté   Réponse avec citation
Vieux 19/02/2017, 15h23   #2
belle-palestine
Avatar de belle-palestine
Pouvoir de réputation: 31
belle-palestine has a brilliant futurebelle-palestine has a brilliant futurebelle-palestine has a brilliant futurebelle-palestine has a brilliant futurebelle-palestine has a brilliant futurebelle-palestine has a brilliant futurebelle-palestine has a brilliant futurebelle-palestine has a brilliant futurebelle-palestine has a brilliant futurebelle-palestine has a brilliant futurebelle-palestine has a brilliant future
Salut, essaie avec ça...
Type de fichier : rar OFFC5 Chaw 0281010808 1037353818.rar (161,6 Ko, 18 affichages)
belle-palestine est déconnecté   Réponse avec citation
Vieux 19/02/2017, 15h27   #3
CSYSTEME
Avatar de CSYSTEME
CSYSTEME has a reputation beyond reputeCSYSTEME has a reputation beyond reputeCSYSTEME has a reputation beyond reputeCSYSTEME has a reputation beyond reputeCSYSTEME has a reputation beyond reputeCSYSTEME has a reputation beyond reputeCSYSTEME has a reputation beyond reputeCSYSTEME has a reputation beyond reputeCSYSTEME has a reputation beyond reputeCSYSTEME has a reputation beyond reputeCSYSTEME has a reputation beyond repute
off fonctionnel
pass dans ta boite
cordialement
Type de fichier : rar off c5 .rar (131,9 Ko, 11 affichages)
Vieux 19/02/2017, 15h28   #4
peug89
Avatar de peug89
peug89 is a name known to allpeug89 is a name known to allpeug89 is a name known to allpeug89 is a name known to allpeug89 is a name known to allpeug89 is a name known to all
vous avez comparé les fichiers ? il sont complètement différents... :/
ça devrait aller mieux ainsi ;)
Type de fichier : rar Mnaouar C5 immo off sur flash.rar (305,0 Ko, 50 affichages)
peug89 est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to peug89 For This Useful Post:
belle-palestine (21/02/2017), gervet95 (08/12/2025)
Vieux 19/02/2017, 15h41   #5
CSYSTEME
Avatar de CSYSTEME
re
bien vu
cordialement
Vieux 19/02/2017, 15h47   #6
mnaouar
Avatar de mnaouar
merci a vous
mon off au premier post le moteur demare mais le bsi au mode eco ..ect
jai un retour.
Vieux 19/02/2017, 16h29   #7
mnaouar
Avatar de mnaouar
apres chaque ecriture jai donné ecu
5vG........
je pense sa va pas demaré!
Type de fichier : jpg Sans titre.jpg (19,9 Ko, 32 affichages)
Vieux 19/02/2017, 18h54   #8
raed83300
Avatar de raed83300
Pouvoir de réputation: 36
Cest normal essaye sa va démarrer
Envoyé de mon SM-G920F en utilisant Tapatalk
Vieux 21/02/2017, 12h54   #9
mnaouar
Avatar de mnaouar
problème résolu avec le fichier de peug89 ,l'autre fichiers la meme chose défaut permanent communication avec ecu moteur.
merci beacuop.
Vieux 21/02/2017, 13h26   #10
peug89
Avatar de peug89
Envoyé par mnaouar Voir le message
merci beacuop.
Bonjour et bien content pour vous chef
pour le cheminent assez simple : je suis reparti de votre Ori car le dump off postez en premier est complétement différent du votre (ori) et j'ai appliqué la méthode célèbre de Jean22 = FF de 7CC5A à 7CCC5
Cdt
Vieux 21/02/2017, 13h36   #11
belle-palestine
Salut, content pour toi mais mon fichier est identique a celui de peug89, tu l' as essayé ? désolé mais j' aime bien comprendre mes erreurs...
Vieux 21/02/2017, 15h08   #12
mnaouar
Avatar de mnaouar
Envoyé par belle-palestine Voir le message
votre fichier demare le moteur mais aiguilles régime moteur et system de suspension hydropneumatique marche pas.
j'ai essayer plusieurs par ce que j'ai feux de croisement allume fixé apré le fichier de peug89.
Vieux 21/02/2017, 16h18   #13
peug89
Avatar de peug89
Mnaouar 2x questions :
êtes vous certain que la carto ori est bien l'ori de cette voiture ET 0281010808 1037353818 ces ref ?
et êtes vous en boite automatique ? (car j'ai été trouver un ori m^me ref que vous, remis l'immo de l'ori trouvé sur le votre puis cheksum même si zone pas couverte par le checksum et là ! il reste une différence en les 2 dump dans la zone 7xxxx
http://hpics.li/b0e04b4
on peu test de mettre les valeurs du dump ori trouvé si vous voulez et qu'un pro nous lisant soit OK
car si j'ai bien compris reste un soucis de feux
Cdt
The Following User Says Thank You to peug89 For This Useful Post:
mnaouar (21/02/2017)
Vieux 21/02/2017, 17h22   #14
mnaouar
Avatar de mnaouar
source info fgtech :
Bytes: 7FFFF
Checksum: 9937
Marca: Bosch
Num. HW: 0281010808
Num. SW: 1037353818
Vieux 21/02/2017, 17h28   #15
mnaouar
Avatar de mnaouar
boite vitesse manuel et pour les feux jai changé bsm et meme problem et
sur bsi feux de automatique jour desactivé ,Pensez-vous que le problème dans la
calculateur moteur?
immo off sur edc15c2 3 broches citroen c5 mike2a Immobilizer dumps/solutions 107 27/07/2024 22h15
tablette actia prix correct skikdi13 Automobile en général 3 08/10/2016 11h31
Fap OFF EDC15c2 citroen 2.2hdi kdo75 Tuning 2 10/07/2016 14h47
dump correct? skikdi13 Réparation & Programmation des calculateurs 2 15/04/2016 11h49
edc15c2-v2 citroen c4 immo off milerk Immobilizer dumps/solutions 10 04/09/2014 01h42
Fuseau horaire GMT +1. Il est actuellement 18h35.
