Vieux 22/11/2018, 18h20   #1
electro_bordeaux1
Avatar de electro_bordeaux1
Par défaut code pin dashboard vw bora magnetti marelli
bonsoir je cherche le code pin du dashboard bora magnetti marelli
AGD eprom 9S12H256
et merci
Type de fichier : rar 9S12H256.rar (868 octets, 18 affichages)
l union fait la force
Vieux 23/11/2018, 11h14   #2
electro_bordeaux1
est ce qu on peut pas extraire le code du dash vw?
Vieux 23/11/2018, 11h53   #3
foulques
Avatar de foulques
foulques has much to be proud offoulques has much to be proud offoulques has much to be proud offoulques has much to be proud offoulques has much to be proud offoulques has much to be proud offoulques has much to be proud offoulques has much to be proud of
salut ton dump correspond a une polo essai 42754
foulques est déconnecté   Réponse avec citation
The Following User Says Thank You to foulques For This Useful Post:
electro_bordeaux1 (23/11/2018)
Vieux 23/11/2018, 12h02   #4
electro_bordeaux1
je crois que le code comence avec 0XXXX
Vieux 23/11/2018, 13h50   #5
foulques
Avatar de foulques
tu as la reference de ton dash?
Vieux 23/11/2018, 15h51   #6
electro_bordeaux1
information du dash
megneti marelli
sw;V04
HW;H1.2
AGD
008VWZ5Z0H1181770
Vieux 23/11/2018, 17h45   #7
diagprog
Avatar de diagprog
diagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond reputediagprog has a reputation beyond repute
Envoyé par electro_bordeaux1 Voir le message
information du dash
megneti marelli
sw;V04
HW;H1.2
AGD
008VWZ5Z0H1181770
code pin : 05914
diagprog est déconnecté   Réponse avec citation
The Following 3 Users Say Thank You to diagprog For This Useful Post:
alinjadii (23/11/2018), Drogo (01/12/2018), electro_bordeaux1 (23/11/2018)
Vieux 24/11/2018, 12h38   #8
FuTuR
Avatar de FuTuR
FuTuR is on a distinguished road
Une idée sur comment vous avez pu trouver le code svp.?
Cordialement
Akram
FuTuR est déconnecté   Réponse avec citation
magnetti marelli 59F.m3 benazze38 Pinout calculateurs et bootmode 2 21/06/2017 09h23
Code pin BSI Jumper ou Boxer Magnetti Marelli matt1781 Transponder, code pin 11 01/11/2015 18h50
Magnetti marelli IAW 8P.11 hassini Immobilizer dumps/solutions 2 24/11/2014 15h41
Code Pin sur calculateur Magnetti Marelli IAW matt1781 Transponder, code pin 5 18/11/2014 20h58
Code pin Ecu moteur Magnetti marelli MrCissou Transponder, code pin 0 30/04/2013 08h47
Fuseau horaire GMT +1. Il est actuellement 13h28.
