Vieux 04/04/2020, 10h02   #1
danyparis
Avatar de danyparis
Pouvoir de réputation: 26
danyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud of
Par défaut Immo off IAW 48P2.76 pour 206 1.1i
Bonjour, j'ai besoin d'un OFF pour un ECu de 206 1.1i
Ref IAW 48P2.76
Je joint le dump lu
A savoir que IMMODEC et autre soft ne fonctionne pas
Type de fichier : bin ecu 2 ori.bin (512,0 Ko, 33 affichages)
ZA KRALJA I OTADZBINU, SLOBODA ILI SMRT
danyparis est déconnecté   Réponse avec citation
Vieux 04/04/2020, 10h47   #2
verbatime
Avatar de verbatime
verbatime is a name known to allverbatime is a name known to allverbatime is a name known to allverbatime is a name known to allverbatime is a name known to allverbatime is a name known to all
testez ça doit marcher
Type de fichier : rar 206 .rar (120,7 Ko, 14 affichages)
verbatime est déconnecté   Réponse avec citation
The Following 3 Users Say Thank You to verbatime For This Useful Post:
amrougafsa (04/04/2020), danyparis (06/04/2020), Y.B tec (06/04/2020)
Vieux 04/04/2020, 12h39   #3
amrougafsa
Avatar de amrougafsa
amrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond repute
voici pour toi 100% ok
dans ta boite
bonne journée .
Type de fichier : rar immo off iaw 48p2.76 teste ok 100%.rar (122,6 Ko, 68 affichages)
donnes un poisson à un homme tu le nourris un jour apprends lui à pêcher tu le nourris pour la vie
amrougafsa est déconnecté   Réponse avec citation
The Following 9 Users Say Thank You to amrougafsa For This Useful Post:
ala1987 (18/04/2023), danyparis (06/04/2020), helmi reguig (15/04/2020), jean-marc 10 (04/04/2020), Modidacte (20/05/2025), redou28 (04/04/2020), Tof02770 (04/04/2020), verbatime (04/04/2020), Y.B tec (06/04/2020)
Vieux 04/04/2020, 16h09   #4
redou28
Avatar de redou28
redou28 is a splendid one to beholdredou28 is a splendid one to beholdredou28 is a splendid one to beholdredou28 is a splendid one to beholdredou28 is a splendid one to beholdredou28 is a splendid one to beholdredou28 is a splendid one to behold
Envoyé par amrougafsa Voir le message
dans ta boite
bonne journée .
salut amrou
la clim ca fonction avec ton off ??
redou28 est déconnecté   Réponse avec citation
The Following User Says Thank You to redou28 For This Useful Post:
Drogo (04/04/2020)
Vieux 04/04/2020, 16h30   #5
amrougafsa
Envoyé par redou28 Voir le message
salut amrou
Pas sûrement mais je pense qu'il fonctionne.
Envoyé de mon JKM-LX1 en utilisant Tapatalk
The Following 2 Users Say Thank You to amrougafsa For This Useful Post:
Vieux 04/04/2020, 16h57   #6
redou28
Avatar de redou28
c'est le probleme de off mm 48p2xx
pas de clim sur les 206 avec preostat lineare (capteur pression clim avec 3 fil)
The Following 2 Users Say Thank You to redou28 For This Useful Post:
amrougafsa (04/04/2020), Tof02770 (04/04/2020)
Vieux 04/04/2020, 19h03   #7
repcles
Avatar de repcles
repcles is a name known to allrepcles is a name known to allrepcles is a name known to allrepcles is a name known to allrepcles is a name known to allrepcles is a name known to all
slt si tu veux clim fonctionne mettre emulateur.
repcles est déconnecté   Réponse avec citation
Vieux 04/04/2020, 19h15   #8
amrougafsa
J'ai pa vérifié le clim avec ce off pourtant je l'ai injecté plusieurs fois.
Mais malheureusement pas de telecodage 48p2 en diagbox...
Vieux 04/04/2020, 20h11   #9
Tof02770
Avatar de Tof02770
Slt les ami ce off sur eeprom ou sur flash moi je pense sur flash
Vieux 04/04/2020, 22h45   #10
redou28
Avatar de redou28
oui pas de telecodage apre le off
mais avec la flash originale le telecodage est possible
le probleme je pense que tous les fichies off est 48p2.70 (identifie avec titanium)
---------- Post added at 09:45 PM ---------- Previous post was at 09:35 PM ----------
Envoyé par Tof02770 Voir le message
pas d'eprom sur iaw 48p2.xx (flash 29f400)
Aflou-diag (05/04/2020), amrougafsa (05/04/2020)
Vieux 05/04/2020, 10h45   #11
amrougafsa
Un bon projet de confinement pour passer le temps [emoji4] j'ai un 48p2.7F en stock et une 206 d'un cousin je vais essayer de crée un off avec clim en marche et je poste résultat...
The Following 5 Users Say Thank You to amrougafsa For This Useful Post:
DAVID02620 (05/04/2020), Drogo (05/04/2020), reda75 (06/04/2020), redou28 (05/04/2020), yoyomartin2003 (06/04/2020)
Vieux 06/04/2020, 17h27   #12
danyparis
Avatar de danyparis
la voiture n'a pas de clim
mais j'ai démarrer avec un autre off que j'ai trouvé dans mes archives
elle a démarré au quart de tour
merci quand meme
The Following User Says Thank You to danyparis For This Useful Post:
Tof02770 (07/04/2020)
Vieux 07/04/2020, 10h59   #13
redou28
Avatar de redou28
slm amrou
pas de news ????
Vieux 07/04/2020, 11h06   #14
amrougafsa
slm amrou
pas de news ????
Pas encore j'attends l'accord de mon cousin car je pense a telecoder son calculateur or sans clim et comparer les deux fichiers de son calculateur original (avec et sans clim) pour connaître les lignes à modifiés.
The Following User Says Thank You to amrougafsa For This Useful Post:
redou28 (07/04/2020)
Immo off IAW 48P2.36 bel27 Immobilizer dumps/solutions 1 26/01/2020 20h45
Aide pour boot pin et immo off IAW 48P2.80 de Saxo TU5J4 j-sky Immobilizer dumps/solutions 41 08/07/2019 17h06
off pour 48P2 1.4L bbatman Immobilizer dumps/solutions 13 25/05/2019 10h31
immo off teste pour iaw 48p2.34 labase Immobilizer dumps/solutions 4 02/02/2017 13h21
cherche damos pour IWP 48p2 pour saxo vts mampita Chiptuning 0 26/10/2016 18h16
Fuseau horaire GMT +1. Il est actuellement 08h20.
