Vieux 10/02/2020, 12h31   #16
car83
Avatar de car83
car83 has much to be proud ofcar83 has much to be proud ofcar83 has much to be proud ofcar83 has much to be proud ofcar83 has much to be proud ofcar83 has much to be proud ofcar83 has much to be proud ofcar83 has much to be proud of
Avant de lui acheter les émulateurs qui a voler sur un autre site, allez faire un tour ici:
https://www.tlemcen-electronic.com/f...t=88945&page=4
Vous verrez sont vrai visage...
Cordialement
car83 est déconnecté   Réponse avec citation
The Following User Says Thank You to car83 For This Useful Post:
S-keys (10/02/2020)
Vieux 10/02/2020, 12h37   #17
kmtech
V.I.P
Avatar de kmtech
Pouvoir de réputation: 64
kmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond repute
Envoyé par car83 Voir le message
Cordialement
Sur quel site ai-je voler cela ?
>> RocketDump << Logiciel Immo OFF/Immo vierge/Airbag reset/extraction code PIN, ...
kmtech est déconnecté   Réponse avec citation
Vieux 10/02/2020, 12h51   #18
MB-Racing
Avatar de MB-Racing
MB-Racing is just really niceMB-Racing is just really niceMB-Racing is just really niceMB-Racing is just really niceMB-Racing is just really nice
salut kmtech et bravo pour cette émulateur
tien nous informer quand ils seront dispo
[URL=https://matchnow.life]Authentic Ladies[/URL]
MB-Racing est déconnecté   Réponse avec citation
The Following User Says Thank You to MB-Racing For This Useful Post:
Jimbo (10/02/2020)
Vieux 10/02/2020, 13h36   #19
ggvaniou
Avatar de ggvaniou
Pouvoir de réputation: 87
Car83 tu te trompe c est le premier emulateur ou tu peux inserré le pin par usb.
Ca a l air interessant,mais j ai demandé la liste des ecu pour delphi et pas reponse???
The Following 2 Users Say Thank You to ggvaniou For This Useful Post:
diagnosis29 (10/02/2020), Y.B tec (11/02/2020)
Vieux 10/02/2020, 13h42   #20
diagnosis29
Avatar de diagnosis29
Pouvoir de réputation: 185
Bonjour ,
En tous cas si c'est copié je veux bien voir l'original !
cet émulateur , je l'ai testé et c'est une merveille et c'est pas pour faire de la pub , je m'en fou j'ai rien a gagner , tu injecte l'ISK par USB tu branche n'importe ou sur le CAN et merci au revoir , c'est pas comme julie ou il faut couper le CAN et perdre des fonctions comme le compte tour ou T° d'eau
The Following 11 Users Say Thank You to diagnosis29 For This Useful Post:
2CVkatia (19/02/2020), akasa67 (10/02/2020), Drogo (10/02/2020), electronico (10/02/2020), ggvaniou (10/02/2020), jah83 (10/02/2020), Jimbo (10/02/2020), nasisamy (28/12/2020), pouettedu76 (11/02/2020), progdebutant (10/02/2020), Y.B tec (11/02/2020)
Vieux 10/02/2020, 14h02   #21
Pouvoir de réputation: 277
Envoyé par diagnosis29 Voir le message
Bonjour ,
Slt L ami jamais fais de can tu perd les tours minute et la température avec Julie etc donc sa dans leurs doc il le dise pas..
Vieux 10/02/2020, 15h24   #22
jah83
Avatar de jah83
Pouvoir de réputation: 245
oui edc16 par ecemple, tu peux resoudre ce probleme avec une petit pcb qui fait passerelle mais emu julie , passerele pas rentable et faut quand meme ouvrir et modif du dump.
The Following 4 Users Say Thank You to jah83 For This Useful Post:
akasa67 (10/02/2020), ggvaniou (10/02/2020), pouettedu76 (11/02/2020), Y.B tec (29/12/2020)
Vieux 10/02/2020, 15h26   #23
Envoyé par jah83 Voir le message
Slt L ami d'accord j'ai des emul polonais apparament pas eu le temps d essayer ce que sa donnait en can mais en K-Line sa fonctionnais nickel..
ggvaniou (10/02/2020), Y.B tec (29/12/2020)
Vieux 10/02/2020, 16h16   #24
rapou30
Avatar de rapou30
rapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud of
Bonjour, est ce que cet émulateur fonctionnera sans dessouder eeprom sur un siemens ems3134 CAN de kangoo 1.6 16 v 4x4 sachant que j'ai deja récupéré le code pin du vehicule ? Ceci etant pour un 2eme ecu modifié pour rouler au E85
Lors de l'envoi , aurez vous un schema de cablage et la methode pour inserer le pin ?
Le piment c'est comme l'autoroute , ca se paye a la sortie
rapou30 est déconnecté   Réponse avec citation
The Following 3 Users Say Thank You to rapou30 For This Useful Post:
akasa67 (28/12/2020), ggvaniou (10/02/2020), Y.B tec (11/02/2020)
Vieux 28/12/2020, 21h03   #25
Slt mon ami rapou je revient pas qui et pas eu de réponse a ta question normalement l emulateur et justement fais expret si pas bon demande a notre amis kmteck la procédure manuel et non automatique il mais arrivé de faire 2 off avec cet emulateur a 2 personne du fofo j'ai du chercher la vitesse etc manuellement
... bon courage l ami j'espère que depuis février on ta donner la réponse dont tu avais besoin..
Dernière modification par akasa67 ; 28/12/2020 à 21h07.
rapou30 (28/12/2020), Y.B tec (29/12/2020)
Vieux 28/12/2020, 22h55   #26
rapou30
Avatar de rapou30
Bonsoir mon ami , c'est sympa de faire remonter le post. Depuis mars j'ai pas eu trop le temps de m'occuper de mon kangoo mais des choses ont avancées.
Kmtech m'a contacté et m'a fourni un autre émulateur que j'ai pu programmer avec mon PIN.
dans ce calculateur j'ai aussi injecté une carto ethanol faite ici par un membre .
A la mise du contact la led antidémarrage s'eteint , le moteur se lance mais pas de démarrage. Pendant quelques secondes j'entends comme un bruit de pompe qui tourne ou de relais que je n'ai pas avec le calculo d'origine.
J'ai ensuite demandé a la personne qui m'a fait la carto E85 de me corriger le cks que je n'ai pas su faire sans plus de résultats.
Je vais m'y remettre prochainement en reprenant tout depuis le début a commencer par cloner mon ecu d'occasion pour être sur que le problème ne vient pas de lui .
The Following 2 Users Say Thank You to rapou30 For This Useful Post:
WJon (29/12/2020), Y.B tec (29/12/2020)
Emulateurs Renault K Line français ! kmtech Vente, Achat, Echange 84 08/03/2020 22h10
Renault ECU Tool en promo sur shop KMTECH kmtech Vente, Achat, Echange 12 27/10/2019 10h55
rocketstart sur MSA15.5 clio dti NORDAX Immobilizer dumps/solutions 9 24/04/2018 21h00
émulateurs k line + CAN RGS Vente, Achat, Echange 4 04/08/2016 22h39
ou acheter les emulateurs foulques Immobilizer dumps/solutions 19 21/12/2015 15h53
Fuseau horaire GMT +1. Il est actuellement 02h58.
