Vieux 24/12/2019, 18h54   #31
allthe77man
Avatar de allthe77man
allthe77man has a spectacular aura aboutallthe77man has a spectacular aura aboutallthe77man has a spectacular aura about
C'est la merde j ai la remonté de ces deux code defaut p0405 entree basse circuit A capteur recyclage des GAZ échappement et p2143 soupape egr signal trop faible.
Vous en pensez quoi merci à tous pour votre participation
allthe77man est déconnecté   Réponse avec citation
Vieux 24/12/2019, 19h12   #32
WJon
Avatar de WJon
Pouvoir de réputation: 58
WJon has a reputation beyond reputeWJon has a reputation beyond reputeWJon has a reputation beyond reputeWJon has a reputation beyond reputeWJon has a reputation beyond reputeWJon has a reputation beyond reputeWJon has a reputation beyond reputeWJon has a reputation beyond reputeWJon has a reputation beyond reputeWJon has a reputation beyond reputeWJon has a reputation beyond repute
Envoyé par allthe77man Voir le message
J'en pense que ton mod n'est pas bon l'ami. Écris le miens qui s'appelle dpf+ egr+p1351off.
Envoyé de mon Trekker-X4 en utilisant Tapatalk
https://diagrepaauto.fr
WJon est déconnecté   Réponse avec citation
The Following User Says Thank You to WJon For This Useful Post:
allthe77man (24/12/2019)
Vieux 24/12/2019, 21h20   #33
allthe77man
Ok je vais essayé ça merci l ami
Vieux 25/12/2019, 01h57   #34
allthe77man
Je n'arrive pas a ouvrir ton fichier... restriction du forum je ne comprend pas...
Vieux 25/12/2019, 02h46   #35
abdel93
Avatar de abdel93
Pouvoir de réputation: 31
abdel93 has a reputation beyond reputeabdel93 has a reputation beyond reputeabdel93 has a reputation beyond reputeabdel93 has a reputation beyond reputeabdel93 has a reputation beyond reputeabdel93 has a reputation beyond reputeabdel93 has a reputation beyond reputeabdel93 has a reputation beyond reputeabdel93 has a reputation beyond reputeabdel93 has a reputation beyond reputeabdel93 has a reputation beyond repute
slt ta essayer de faire une adaptation de vanne egr avec diagbox?
---------- Post added at 02h46 ---------- Previous post was at 02h41 ----------
Envoyé par abdel93 Voir le message
je vient de voir que tu a fait un egr off donc oublie ce que je vient de te dire ,tu devrait tester le fichier a wjon et ca devrait être bon
un petit thank ca fait pas de mal
abdel93 est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to abdel93 For This Useful Post:
allthe77man (25/12/2019), WJon (25/12/2019)
Vieux 25/12/2019, 09h23   #36
WJon
Avatar de WJon
Voila pour toi, je t'envoie la clé de déchiffrement en MP.
https://mega.nz/#!KDQyHSjK
Vieux 26/12/2019, 01h57   #37
allthe77man
Merci wjon, j'ai injecté ton fichier aujourd'hui et toujours le le voyant qui revient sauf que cette fois le défaut est le p0401. Help les amis quelqu'un aurait il une solution?
Vieux 26/12/2019, 08h34   #38
WJon
Avatar de WJon
P0401 c'est débit EGR insuffisant. C'est vraiment étrange car j'ai vérifié plusieurs fois mon fichier... regarde les données en temps réelle au diag pour voir la consigne et la position EGR stp.
---------- Post added at 08h29 ---------- Previous post was at 08h27 ----------
La voiture est en mode dégradé?
---------- Post added at 08h31 ---------- Previous post was at 08h29 ----------
tu as bouché ton egr?
---------- Post added at 08h34 ---------- Previous post was at 08h31 ----------
Ta vanne est elle toujours branchée?
allthe77man (26/12/2019)
Vieux 26/12/2019, 11h56   #39
allthe77man
J'ai essayé avec la vanne branché et débranché, oui elle est bouché avec une plaque, jai même essayé avec d'autres fichier modé avec aes egr remover en passant en peugeot en sélectionnant tous les modèles de edc16c34 proposé et toujours pareil. Le pire cest que jai regardé les differents fichier dans dtc remover et les codes erreur qui remontent sont d'après lui désactivés dans les fichiers chargés
---------- Post added at 11h55 ---------- Previous post was at 11h54 ----------
Je fais une mesure paramètre ce soir je te dirai si elle la position et la consigne sont à 0
---------- Post added at 11h56 ---------- Previous post was at 11h55 ----------
Non jai pas essayé abdel
Wjon tu pense que ça peut aider?
Vieux 26/12/2019, 12h08   #40
WJon
Avatar de WJon
Avec un EGR off ou close l'adaptation ne servira à rien je pense, mais tu ne risque à mon avis pas grand chose à essayer.
Concernant Le P0401 dans mon fichier il n'est pas supprimé.
Ton véhicule est il en mode dégradé ou a-t-il toute sa puissance?
Vieux 26/12/2019, 13h57   #41
allthe77man
Il a toute sa puissance
Vieux 26/12/2019, 14h22   #42
WJon
Avatar de WJon
Tu as donc juste le voyant OBD allumé, le P0401 , mais sinon il roule très bien?
Vieux 26/12/2019, 18h47   #43
allthe77man
Talking
Oui il roule très tres bien
---------- Post added at 18h47 ---------- Previous post was at 18h45 ----------
C'est sur que sans vanne egr, sans fap et avec la pipe entièrement nettoyé il respire le pépère ! ! :DD
The Following User Says Thank You to allthe77man For This Useful Post:
WJon (26/12/2019)
Vieux 26/12/2019, 18h56   #44
WJon
Avatar de WJon
Tiens écris ça:
https://mega.nz/#!KeIjUQzR
je t'envoie la clé en MP.
Vieux 26/12/2019, 19h00   #45
allthe77man
Je vais essayé ça et je te tiens au courant merci l ami
WJon (26/12/2019)
egr off EDC16C34 C4 picasso azwa44 Chiptuning 23 31/03/2021 09h36
EGR off EDC16C34 C4 picasso azwa44 Chiptuning 5 07/10/2018 16h18
Dpf et egr off edc16c34 c4 picasso Xav Chiptuning 3 26/07/2017 22h58
Egr off edc16c34 c4 picasso svp Bigorno91 Peugeot, Citroën 4 02/05/2017 06h21
EDC16C34 picasso 1.6 hdi nani90 Immobilizer dumps/solutions 63 01/02/2014 12h33
Fuseau horaire GMT +1. Il est actuellement 09h29.
