Vieux 16/09/2015, 17h56   #16
bbert90
Avatar de bbert90
Pouvoir de réputation: 22
bbert90 is a splendid one to beholdbbert90 is a splendid one to beholdbbert90 is a splendid one to beholdbbert90 is a splendid one to beholdbbert90 is a splendid one to beholdbbert90 is a splendid one to beholdbbert90 is a splendid one to behold
mince j avais pas vu tes en 4.3.3 c est des anciennes mais fonctionne avec moi
bbert90 est déconnecté   Réponse avec citation
Vieux 16/09/2015, 18h33   #17
inventeur67
Avatar de inventeur67
inventeur67 is on a distinguished road
J'ai déjà effectué la 4.2.9db mais ça ne change rien. Comment désactiver la mise à jour automatique car j'étais en 4.3.3 et là je me retrouve de nouveau avec la 4.2.9db?
inventeur67 est déconnecté   Réponse avec citation
Vieux 16/09/2015, 18h48   #18
inventeur67
I Uninstall UMDF from device manager, now I have USB Com board evolution driver (Multi-instance) and when I connect to my car I can't do nothing ( don't recognize my VCI, Don't connects to calculators).
Vieux 16/09/2015, 19h14   #19
soustourou
Avatar de soustourou
Pouvoir de réputation: 27
soustourou has much to be proud ofsoustourou has much to be proud ofsoustourou has much to be proud ofsoustourou has much to be proud ofsoustourou has much to be proud ofsoustourou has much to be proud ofsoustourou has much to be proud ofsoustourou has much to be proud ofsoustourou has much to be proud ofsoustourou has much to be proud of
bonsoir j'ai eu le meme problème aucun ecu de reconnu j'e n'ai deux comme ça dans le tiroirs j'attends une solution
On a souvent besoin d'un plus petit que soi
soustourou est déconnecté   Réponse avec citation
Vieux 16/09/2015, 23h40   #20
Simple
Avatar de Simple
Simple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud of
@inventeur67, Your problem is not difficult, if your device is not faulty, you should be able to fix it...
But, you still did not answer all the questions I asked you... Are you using VirtualBox or VMware or installation directly on the computer?
I cannot guess what is the problem if you do not help me.. try this!
http://cartechnology.co.uk/showthrea...83650#pid83650
Simple est déconnecté   Réponse avec citation
Vieux 16/09/2015, 23h47   #21
MOUS25
Avatar de MOUS25
Pouvoir de réputation: 24
MOUS25 has much to be proud ofMOUS25 has much to be proud ofMOUS25 has much to be proud ofMOUS25 has much to be proud ofMOUS25 has much to be proud ofMOUS25 has much to be proud ofMOUS25 has much to be proud ofMOUS25 has much to be proud of
Slt
Question bete as tu essayé ton interface sur un autre vehicule?
Car la mienne ne fait pas certaine 307 hdi
MOUS25 est déconnecté   Réponse avec citation
Vieux 17/09/2015, 00h27   #22
Simple
Avatar de Simple
Don't worry about the 4.3.x firmware, DiagBox will upgrade and downgrade automatically. All you need is to insert the device in the USB, then start DiagBox. The first thing it will do is to check the firmware and upload the proper firmware if needed.
Please be aware that some Lexia clones DO NOT work on Peugeot 307 and C-ziro / Ion and Citroen C5 !!! So if you can see the green LED blinking when you start DiagBox, then try it on another car to see if the problem is with the device.
In my device a 10k resistor missing and C57 capacitor were missing (Picture Lex1). Also, some devices have components missing... Lets hope yours is working..
Type de fichier : jpg Lex1.jpg (61,5 Ko, 28 affichages)
Type de fichier : jpg Lex2.jpg (82,9 Ko, 32 affichages)
Vieux 17/09/2015, 09h32   #23
inventeur67
Non malheureusement je n'ai pas d'autres véhicule que ma c4 et il n'y a personne dans mon entourage qui a peugeot ou citroën.
Vieux 17/09/2015, 09h54   #24
inventeur67
I'm sorry Iused Deamon Tools to install diagbox v7.02.
In my device just a 10k resistor missing and not the C57 capacitor.
Type de fichier : jpg IMG_2560.jpg (96,1 Ko, 16 affichages)
Type de fichier : jpg IMG_2558.jpg (95,0 Ko, 15 affichages)
Vieux 17/09/2015, 20h04   #25
Simple
Avatar de Simple
The 10K resistor is pull-up for the CAN-BUS. I would say, you can safely solder and check if it works...
Vieux 17/09/2015, 20h17   #26
Simple
Avatar de Simple
You did not say if you have the full set of optocouplers as shown in my second photo?
Anyway, you can try your device on a different Peugeot or Citroen to see if it works with them first.
Vieux 17/09/2015, 22h59   #27
inventeur67
No I can't Try it over vehicle because I have juste an old Peugeot 306.
Type de fichier : jpg image.jpg (92,4 Ko, 9 affichages)
Vieux 18/09/2015, 12h20   #28
Simple
Avatar de Simple
Obviously you don't have the Full Chip device, I don't know if your interface works with 306/7 - C5 or not, I would advice you to try it on a different Peugeot or Citroen car first. Also, I don't know if adding the resistance would help, but you can try...
If it works with other PSA models but it still does not work with yours, even after adding the resistance, you could try adding all the missing parts. If you search the forums, you will find that some people bought the missing parts and soldered them on their boards.
Failing all that, you could sell it and buy a full chip device.
Vieux 18/09/2015, 15h06   #29
inventeur67
I will try this weekend on a Peugeot 307 ( 2002 ) not CAN and I will keep you informed , thank you very much for your help.
If it works, I try the resistance 10k.
Vieux 18/09/2015, 20h21   #30
Simple
Avatar de Simple
I would advise to try on something other than 307 or C5!! these cars are reported to have a problem with some clones....
Calculateurs alexio Vente, Achat, Echange 0 23/04/2014 12h14
programmation des calculateurs mahiou Réparation & Programmation des calculateurs 3 14/01/2014 01h37
calculateurs neuf zaouibachir Vente, Achat, Echange 0 10/10/2013 23h45
Fuseau horaire GMT +1. Il est actuellement 13h16.
