Vieux 16/01/2016, 20h34   #136
pouettedu76
Avatar de pouettedu76
Pouvoir de réputation: 76
Envoyé par jah83 Voir le message
Ah mince j ai loupeŕ le train... Bon bah je prendrai le suivant. A moins qu il puisse faire pour plus que 5 aussi
Salut Jah83 exceptionnellement pour toi je vais voir sa avec lui et te dis sa par mp Bonne soirée @+
Vieux 17/01/2016, 23h17   #137
RIMKACHIP
Avatar de RIMKACHIP
RIMKACHIP is a name known to allRIMKACHIP is a name known to allRIMKACHIP is a name known to allRIMKACHIP is a name known to allRIMKACHIP is a name known to allRIMKACHIP is a name known to all
qui a testé clear crash airbag clio3 et clio 4 ? ça fonctionne ? merci du retour
RIMKACHIP est déconnecté   Réponse avec citation
Vieux 18/01/2016, 03h42   #138
gabigafu
Avatar de gabigafu
Pouvoir de réputation: 43
gabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond repute
ca marche a moins que Clip te donnes calculateur a changer
gabigafu est déconnecté   Réponse avec citation
Vieux 18/01/2016, 08h02   #139
RIMKACHIP
Avatar de RIMKACHIP
Clip me donne toujours à remplacer après un crash non ?
Vieux 18/01/2016, 08h27   #140
gabigafu
Avatar de gabigafu
Clip ne donne pas toujours calculateur a remplacer. Quand ca arrive, il est possible d'effacer crash data avec Renolink.
Vieux 18/01/2016, 08h49   #141
yvespapou
Avatar de yvespapou
Pouvoir de réputation: 37
yvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond repute
Envoyé par gabigafu Voir le message
salut moi je fais que du VE (vehicule accidentée) sur clio 4 et d'autre renault des qu'un airbag a déclenché quand ont interroge avec le clip il y a toujours inscrit calculateur airbag a remplacer donc si je comprend bien renolink ne sert a rien dans ce cas la????????????????????????????????????????????
yvespapou est déconnecté   Réponse avec citation
Vieux 18/01/2016, 08h52   #142
stephane
Avatar de stephane
Pouvoir de réputation: 120
stephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond repute
Il fait les clear sur clio2 !? ......ptdr
stephane est déconnecté   Réponse avec citation
Vieux 18/01/2016, 09h06   #143
gabigafu
Avatar de gabigafu
non sur clio2
Vieux 18/01/2016, 09h07   #144
pouettedu76
Envoyé par yvespapou Voir le message
Bonjour Yvespapou
Regarde la reponse est sur le poste je viens de relire Nowen et regarde copier coller
Envoyé par nowen Voir le message
petite précision à propos du "airbag reset" si vous avez à la clip ou autre le message "calculateur à remplacer" vous ne pourrez pas faire un reset avec RenOlink d'ailleurs il vous le signalera (comme sur l'image). vous serez obligé d'attaquer l'eeprom.
Merci aNowen pour cette capture d'ecran
@+ l'amis a tres bientot
Vieux 18/01/2016, 09h18   #145
yvespapou
Avatar de yvespapou
oui pouettedu76 prend surtout le temps de lire le mien de message donc je répète pour toi après un choc sur renault le can clip marque toujours calculateur a remplacer donc si il n'est pas a remplacer je ne vois pas l’intérêt de faire un clear merci de prendre le temps de me lire merci pouettedu76
Vieux 18/01/2016, 10h28   #146
RIMKACHIP
Avatar de RIMKACHIP
Pour ma part j'ai pas trop envie de casser qui que ce soit mais j'ai jamais eut de ma vie un crash renault dont le calculo me sort pas calculateur a remplacer c pas du vag lol sinon faut renommer clear crash par clear dtc non ? En fait c un raccourci de certaines fonctions ddt2000 avec un rpe integré c ca ? Et pour le virgin dae j'en fait pas mal faut renommer par clear immo code car c impossible de le remettre en vierge par obd du moins d'apres ce que je sais apres si ya qq1 qui fait ca par obd et clear crash par obd quil me fasse signe jsui preneur direct lol
Vieux 18/01/2016, 10h30   #147
RIMKACHIP
Avatar de RIMKACHIP
Envoyé par stephane Voir le message
Carprog 45€ ca passe lol
Vieux 18/01/2016, 10h32   #148
RIMKACHIP
Avatar de RIMKACHIP
Clio4 par obd ? Stephane timagines ? Spc560 ca viendra peut etre en 2026 lol
Vieux 18/01/2016, 10h39   #149
stephane
Avatar de stephane
Salutation
Je te sent chaud bouillant mon yves...
Bon moi je suis toutes vos infos depuis le début mais ça part dans tous les sens et il n'y a rient de concret qui en ressort
Merci pouettedu76 pour ton travail de comercial mais la ont rentre dans la technique .
Il serait intéressant d avoir les informations sur le programme directement de gaby
A savoir ce qu'il fait exactement et ce qu'il ne fait pas .
Certains menbres n'ont pas forcément l oseilles a investir dans un logiciel qui ne leurs servira a rient .
Ceci dit j ais contacter gaby pour sont programme si réellement il est fonctionnel j en ferait l éloge si ce n est pas le cas je le dirait aussi
En tout cas merci a lui pour sont travail
Stephane
Vieux 18/01/2016, 10h41   #150
stephane
Avatar de stephane
Envoyé par RIMKACHIP Voir le message
Ca fait longtemps que j en fait plus .....c est une relique pour moi ...mdr
Abs/esp calculator diagprog ABS, ESP, DSC 117 20/11/2022 17h30
Abs esp calculator kevin22 Immobilizer dumps/solutions 1 05/06/2015 15h09
PSA pin calculator diagnosis29 Transponder, code pin 12 27/06/2014 13h11
psa calculator nacerweb Transponder, code pin 0 18/01/2013 22h34
Fuseau horaire GMT +1. Il est actuellement 13h08.
