Vieux 07/04/2020, 17h42   #16
Mook31
Avatar de Mook31
Pouvoir de réputation: 41
Mook31 has a reputation beyond reputeMook31 has a reputation beyond reputeMook31 has a reputation beyond reputeMook31 has a reputation beyond reputeMook31 has a reputation beyond reputeMook31 has a reputation beyond reputeMook31 has a reputation beyond reputeMook31 has a reputation beyond reputeMook31 has a reputation beyond reputeMook31 has a reputation beyond reputeMook31 has a reputation beyond repute
Voilà bloc 41, un grand merci à toi !
Mook31 est déconnecté   Réponse avec citation
Vieux 07/04/2020, 18h33   #17
brahimlamgarbi
Avatar de brahimlamgarbi
Pouvoir de réputation: 36
brahimlamgarbi has a reputation beyond reputebrahimlamgarbi has a reputation beyond reputebrahimlamgarbi has a reputation beyond reputebrahimlamgarbi has a reputation beyond reputebrahimlamgarbi has a reputation beyond reputebrahimlamgarbi has a reputation beyond reputebrahimlamgarbi has a reputation beyond reputebrahimlamgarbi has a reputation beyond reputebrahimlamgarbi has a reputation beyond reputebrahimlamgarbi has a reputation beyond reputebrahimlamgarbi has a reputation beyond repute
resalut mon ami mook31
le le firmware actuel v069Q8400AM___getriebe_DSG_OVQ8_sw.sgo de bva dsg 7 est une version de 4540 et biensur si tu as monté le nouveau kit d embrayage qui propose par vag donc le resultat que la bva ca marche pas bien .
donc il faut que tu flasher au nouveau la bva dsg7 avec la version récent de 5770 -------) v069Q8700AM___getriebe_DSG_OVQ8_sw.sgo
pour faire mise a jour bva dsg7 il suffit que odis + fichier firmware bva dsg7
pour autre problémes n hésite pas de me pose autre questions
bon courage
Type de fichier : rar v069Q8700AM___getriebe_DSG_OVQ8_sw.rar (1,05 Mo, 7 affichages)
(Avec un peu d'efforts, tu seras capable de trouver tes erreurs)
brahimlamgarbi est déconnecté   Réponse avec citation
The Following 3 Users Say Thank You to brahimlamgarbi For This Useful Post:
calixo22 (27/04/2020), Mook31 (07/04/2020), youcef_trik (27/04/2020)
Vieux 07/04/2020, 19h05   #18
Mook31
Avatar de Mook31
Ah zut il faut ODIS !! Bon bloqué pour l’instant.
Merci mille fois mon ami, à charge de revanche .
Vieux 23/04/2020, 14h36   #19
Mook31
Avatar de Mook31
Bonjour à tous, je me suis rendu auprès de cette Golf pour faire la mise de la boîte qui ne s’est pas passée comme prévu.
Au bout de 4min le flashage s’interrompt et la boîte est bloqué sur P, qui clignote.
Tension de batterie ok (13,6/7)
Voilà le message d’erreur en PJ.
Merci à vous.
m
Vieux 23/04/2020, 15h37   #20
Mook31
Avatar de Mook31
J’ai finalement réussi à flasher mais ça n’a pas débloqué la boîte. Toujours P qui clignote. Une idée ?
Vieux 23/04/2020, 17h14   #21
Mook31
Avatar de Mook31
Les amis, je poursuit mon petit monologue en temps réel :
Sans grande conviction j’ai branché la Launch, fonction en ligne et le flash a été jusqu’au bout.
Le P s’est allumé en fixe et la voiture redémarre.
Elle m’aura bien sorti des orties cette Launch!
Je vais refaire un réglage de base, car le problème des accoups persistes.
The Following 2 Users Say Thank You to Mook31 For This Useful Post:
POCOYO (23/04/2020), youcef_trik (27/04/2020)
Vieux 23/04/2020, 17h22   #22
POCOYO
Avatar de POCOYO
Pouvoir de réputation: 65
Envoyé par Mook31 Voir le message
Salut Mook je me joins à ce monologue pour qu’il devienne un dialogue
Il te reste plus que le point de léchage
D’où les accoups sûrement qu’il n’est pas bon ou ton capteur d’entrée de vitesse de boîte
Nulle pierre ne peut être polie sans friction, nul homme ne peut parfaire son expérience sans épreuve
Mook31 (23/04/2020)
Vieux 23/04/2020, 17h33   #23
Mook31
Avatar de Mook31
Salam POCOYO il est vrai qu’il bien plus agréable d’avoir un interlocuteur : )
Ce qui me semble bizarre c’est que je n’ai pas de température de boîte en lisant le bloc 019 sur VCDS.
Le réglage de base va quand même au bout car je laisse la voiture chauffer.
Le défaut qui ressort est P177D couple trop élevé.
Je continu d’investiguer...
The Following User Says Thank You to Mook31 For This Useful Post:
POCOYO (23/04/2020)
Vieux 23/04/2020, 18h03   #24
POCOYO
Avatar de POCOYO
Salam frère
Si ont fait un peu d’anglais
problem solved , i took out the mechatronic unit and replaced the new TCM with old TCM, car works with no more fault codes, usually changing a new tcm recommends a new clutch for correct adaptation, worn clutch and old tcm will already have adapted clutch travel.
---------- Post added at 15h03 ---------- Previous post was at 14h59 ----------
Salam frère
Mook31 (23/04/2020)
Vieux 23/04/2020, 18h16   #25
Mook31
Avatar de Mook31
Sur ce véhicule seul l’embrayage a été remplacé. Si j’ai bien compris dans ton post précédent cela concerne un remplacement de mechatronic.
Il a remis l’ancien TCM pour refaire l’adaptation.
Je pensais à une mise à jour mais même en mettant le fichier le plus récent, même problème : boîte qui saute direct en 2nd ou qui fais de gros accoups.
neoamtrixe (23/04/2020)
Vieux 23/04/2020, 18h31   #26
POCOYO
Avatar de POCOYO
Salam oui c’est ce qu’il a fait pour adapter en remettant l’ancien TCM
Et c’est les meme symptômes que ton véhicule
Vieux 23/04/2020, 18h32   #27
neoamtrixe
Avatar de neoamtrixe
Pouvoir de réputation: 7
neoamtrixe will become famous soon enough
salut a vous voici la traduction de l' anglais
"problème résolu, j'ai sorti l'unité mécatronique et remplacé le nouveau TCM par un ancien TCM, la voiture fonctionne, sans plus de codes d'erreur, changer généralement un nouveau tcm recommande un nouveau embrayage pour une adaptation correcte, l'embrayage usé et l'ancien tcm auront déjà un débrayage adapté . "
neoamtrixe est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to neoamtrixe For This Useful Post:
Mook31 (23/04/2020), POCOYO (23/04/2020)
Vieux 23/04/2020, 18h35   #28
POCOYO
Avatar de POCOYO
Salam j’ai ça aussi en feed-back
Vérifiez d'abord visuellement si les pistons d'embrayage sortant de l'unité mécatronique sont en place, ils ont également un petit capuchon rond à son extrémité assurez-vous qu'il est monté sur les deux pistons et correctement positionné dans les plaques si tout va bien, retirez l'unité mécatronique, lors du retrait vérifiez si toutes les fourches de changement de vitesse se déplacent assez facilement. Vérifiez également qu'il n'y a pas de jeu libre des fourches s'il y a un risque que le roulement de guidage de la fourche soit défectueux. si tout va bien remplacer l'unité mécatronique ..
Mook31 (23/04/2020)
Vieux 23/04/2020, 18h37   #29
neoamtrixe
la dsg 7 et plus casse berle que la dsg 6 attention au intervention sur le mécatronique moi j' aurais juste changer l' embrayage et regardé après qui a changer l' embrayage il faut, faire hyper attention aux bagues d’épaisseur 4 et 6 sur la page 11 du manuel peut etre une piste par la cordialement.
The Following User Says Thank You to neoamtrixe For This Useful Post:
Mook31 (23/04/2020)
Vieux 23/04/2020, 18h39   #30
Mook31
Avatar de Mook31
J’ai essayé une adaptation à 1100tr/min conformément à ton dernier document mais elle ne se fait pas.
Il y a peut-être une procédure d’adaptation sur route...
rempl uch clio 2 scal Transponder, code pin 16 03/07/2024 13h44
help codage et rempl batterie E60 SERIE 5 tony2552 BMW 8 25/11/2019 16h36
embrayage 107 skikdi13 Automobile en général 2 29/04/2018 14h19
Volant moteur+embrayage golf 5 1.9 tdi 105 turock02 Vw, Audi, Skoda, Seat, Bentley 5 17/07/2016 09h57
Embrayage 307 florence Mécanique générale 45 04/04/2015 21h20
Fuseau horaire GMT +1. Il est actuellement 04h09.
