Précédent   Tlemcen Car electronics > Réparation & Reprogrammation > Réparation & Programmation des calculateurs > Pinout calculateurs et bootmode
Vieux 28/03/2020, 17h56   #91
Pouvoir de réputation: 276
Non c'est vrai pourtant je lit en boot mais j'arrive pas l écrire le fumier lol..
Pourtant lecture ok mais veut pas écrire
Dernière modification par akasa67 ; 28/03/2020 à 17h59.
WJon (28/03/2020)
Vieux 28/03/2020, 18h01   #92
bel27
Avatar de bel27
Pouvoir de réputation: 36
bel27 has a reputation beyond reputebel27 has a reputation beyond reputebel27 has a reputation beyond reputebel27 has a reputation beyond reputebel27 has a reputation beyond reputebel27 has a reputation beyond reputebel27 has a reputation beyond reputebel27 has a reputation beyond reputebel27 has a reputation beyond reputebel27 has a reputation beyond reputebel27 has a reputation beyond repute
je te conseil de passer par galetto
bel27 est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to bel27 For This Useful Post:
akasa67 (28/03/2020), autodiagauto (30/03/2020)
Vieux 28/03/2020, 18h10   #93
WJon
Avatar de WJon
Pouvoir de réputation: 58
WJon has a reputation beyond reputeWJon has a reputation beyond reputeWJon has a reputation beyond reputeWJon has a reputation beyond reputeWJon has a reputation beyond reputeWJon has a reputation beyond reputeWJon has a reputation beyond reputeWJon has a reputation beyond reputeWJon has a reputation beyond reputeWJon has a reputation beyond reputeWJon has a reputation beyond repute
Pareil que bel , si tu as essaie avec galletto, le trois broche passe très bien , j'en ai déjà fais plusieurs. ;)
https://diagrepaauto.fr
WJon est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to WJon For This Useful Post:
akasa67 (28/03/2020), Mook31 (28/03/2020)
Vieux 28/03/2020, 18h32   #94
Je suis un bouffon...
Dernière modification par akasa67 ; 28/03/2020 à 18h38.
Vieux 28/03/2020, 18h34   #95
Mook31
Avatar de Mook31
Pouvoir de réputation: 41
Mook31 has a reputation beyond reputeMook31 has a reputation beyond reputeMook31 has a reputation beyond reputeMook31 has a reputation beyond reputeMook31 has a reputation beyond reputeMook31 has a reputation beyond reputeMook31 has a reputation beyond reputeMook31 has a reputation beyond reputeMook31 has a reputation beyond reputeMook31 has a reputation beyond reputeMook31 has a reputation beyond repute
Lol qu’est-ce qui t’arrive l’ami ?
Mook31 est connecté maintenant   Réponse avec citation
The Following 2 Users Say Thank You to Mook31 For This Useful Post:
akasa67 (28/03/2020), WJon (28/03/2020)
Vieux 28/03/2020, 18h36   #96
WJon
Avatar de WJon
MDR pk tu dis ca greg?
The Following User Says Thank You to WJon For This Useful Post:
Vieux 28/03/2020, 18h55   #97
WJon
Avatar de WJon
Les amis petit retour !
Franchement merci pour votre aide vraiment ! Merci à tous!
Le client vient de m'appeler et la voiture a démarré au premier coup de clé.
Je l'ai senti vraiment ému et heureux.
Ont a refait son weekend !
Encore un énorme merci à vous tous , comme quoi l'union fait vraiment la force.
RESOLU!
Envoyé de mon Trekker-X4 en utilisant Tapatalk
The Following 6 Users Say Thank You to WJon For This Useful Post:
akasa67 (28/03/2020), DAVID02620 (28/03/2020), Mook31 (28/03/2020), Pelican (28/03/2020), rapou30 (29/03/2020), Y.B tec (28/03/2020)
Vieux 28/03/2020, 18h56   #98
bel27
Avatar de bel27
Talking
t avais pas choisi le bon ecu hhh
---------- Post added at 18h56 ---------- Previous post was at 18h55 ----------
Envoyé par bel27 Voir le message
pour akasa
Vieux 28/03/2020, 20h29   #99
Ben un grosse boulette ensuite je comprend pas j'ai changer la flash etc OK mais sur table pas de off et ce normal regarder les dégâts
WJon (28/03/2020)
Vieux 28/03/2020, 20h39   #100
WJon
Avatar de WJon
C'est moi ou la pin 24 a pris un vilain coup?
Vieux 28/03/2020, 20h41   #101
Pelican
Avatar de Pelican
Pouvoir de réputation: 29
je suis pas un spécialiste des écus mais il me semble qu'il te manque une patte et de mémoire ça serais celle qui sert pour le boot mode !!
The Following User Says Thank You to Pelican For This Useful Post:
Vieux 28/03/2020, 20h44   #102
WJon
Avatar de WJon
Envoyé par JulienP Voir le message
Salut ,
Oui c'est la pin 24, c'est ce que j'ai remarqué aussi.
Vieux 28/03/2020, 20h46   #103
yann3
Avatar de yann3
Pouvoir de réputation: 74
yes ca va,je galere avec la putain de 607 v6 hdi,pour mon fils
j'ai refait le moteur et au demarrage fuite de ldr et fuite d'huile,forcement sur le banc arriere,en faite le cache culbu pourtant avec joint neuf
au remontage du tout fuite de gasoil,les pinoches des retour resté collé dans les injos et cassé
pffff plus qu'a commander l'araigné
ca fait 4 jour que je suis sur toute ces merde,y'en a marre,l'electronique est moins fatiguante
http://www.armoreprog.fr
WJon (28/03/2020)
Vieux 28/03/2020, 20h46   #104
Boutbout
Avatar de Boutbout
Boutbout is a splendid one to beholdBoutbout is a splendid one to beholdBoutbout is a splendid one to beholdBoutbout is a splendid one to beholdBoutbout is a splendid one to beholdBoutbout is a splendid one to beholdBoutbout is a splendid one to behold
Salut , La pin a prit un sacrer coup est encore la mais enfoncer , comment sa a pu se passer ,a voir si y a encore continuité avec la soudure et pin ...
Boutbout est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to Boutbout For This Useful Post:
Vieux 28/03/2020, 20h47   #105
Mook31
Avatar de Mook31
Yes, on vois mal mais j’ai l’impression qu’il reste un bout de la pin 24 qui est encore visible sur le boitier de la flash.
Ça vaut peut-être le coup de tenter une réparation en ressoudant un fil dessus.
EDC15C2 PinOut et branchement nounour10 Pinout calculateurs et bootmode 11 01/02/2019 13h52
Peugeot 406 RHZ edc15 1broche immo off DaniPeugeot Immobilizer dumps/solutions 4 22/03/2018 22h31
Pinout edc15c2 3plug (2.2hdi 4hx) 406dany Pinout calculateurs et bootmode 0 31/07/2016 16h53
Edc15c2 1broche bootmode soustourou Immobilizer dumps/solutions 9 30/11/2015 19h29
Confirmation defap 307 hdi 2l 110 edc15c2 Teddy02 Chiptuning 3 20/07/2014 01h39
Fuseau horaire GMT +1. Il est actuellement 11h40.
