Vieux 10/02/2025, 16h22   #1
simonpbmeca49
Avatar de simonpbmeca49
Pouvoir de réputation: 3
Par défaut Interpretation erreur vcds
Bonjour. J'ai un VW Atlas de 2020 avec cette DTC qui apparait sur vcd :
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 085 CC HW: 5Q0 937 085 BG
Component: BCM MQBAB HNA H40 0312
Serial number: 0242035001ÿÿÿÿ Dataset Number: V03935335UV 0001
Coding: 00000000000000000000000000000000000000000000000000 0000000000
Shop #: WSC 06050 062 00200
ASAM Dataset: EV_BCMMQB 020001
ROD: EV_BCMBOSCH_020_VW41.rod
VCID: 7CA1F4ED5668993A0BB-8028
Rain/Light Recognition Sensor:
Subsystem 1 - Part No SW: 5Q0 955 555 A HW: 5Q0 955 555 A
Component: RLHSS 054 0207
Serial number: S6Y20M07D01H15M23S00
Coding: 0018DD
Steering Column Switch:
Subsystem 2 - Part No SW: 5Q1 953 521 AC HW: 5Q1 953 569 B
Component: Lenks.Modul H23 0170
Serial number: 0300040920200C200990
Blower 1 for left front backrest:
Subsystem 3 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Component: SysNameFanLin 014 0102
Serial number: ESE1706485
Blower 1 for left front seat cushion:
Subsystem 4 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE1680411
Blower 1 for right front backrest:
Subsystem 5 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE1706379
Blower 1 for right front seat cushion:
Subsystem 6 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE1680575
1 Fault Found
535060 - Databus
U1123 00 [00001001] - Received Error Message
[FLA_01 Datenbus empfangener Fehlerwert]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 82
Mileage: 60254 km
Date: 2025.02.09
Time: 0521
Terminal 15 status: On
Terminal 50 status: OFF
CAN-Bus_aktiv: On
Status Bremslichtschalter (HW): OFF
Status Bremslichtschalter (CAN): OFF
OFF: operated
Position lamps: Not operated
Automatic high beam assist: Not operated
Low beam: Not operated
Parking light left: Not operated
Parking light right: Not operated
last_wakeup: no cause for fault protection
Voltage: 12.1 V
Outside temperature: 35.0 °C
Comment savoir quel module à envoyé un message erroné ?
---------- Post added at 17h22 ---------- Previous post was at 17h20 ----------
Au cas où, J519 = BCM
[B]Un thanks encourage à participer[/B]
Vieux 10/02/2025, 17h17   #2
POCOYO
Avatar de POCOYO
Pouvoir de réputation: 65
Salut a priori c’est ça
L’erreur indiquée dans le rapport est 535060 - Bus de données (U1123 00 [00001001] - Message d’erreur reçu), avec la description suivante en allemand :
”[FLA_01 Datenbus empfangener Fehlerwert]”
Analyse de l’erreur :
•“FLA_01” fait référence au module d’assistant de feux de route (FLA - Fernlichtassistent), qui est responsable de la gestion des feux de route automatiques.
•Le message d’erreur signifie que le bus de données a reçu une valeur erronée de ce module.
•L’erreur est confirmée et s’est produite 3 fois depuis le dernier effacement des défauts.
Conclusion :
Le module qui envoie un message erroné est l’assistant de feux de route automatique (FLA - Automatic High Beam Assist).
Cela peut être dû à :
•Un dysfonctionnement du capteur de caméra utilisé pour la gestion des feux de route.
•Un problème de communication sur le bus CAN.
•Un problème logiciel nécessitant une mise à jour ou un recodage du module.
Que faire ?
1.Vérifier si l’assistant feux de route fonctionne correctement en testant son activation manuelle.
2.Vérifier le câblage et les connecteurs du capteur/caméra du FLA.
3.Si le problème persiste, une mise à jour du logiciel du module peut être nécessaire via VCDS ou un outil de diagnostic constructeur (ODIS).
The Following 3 Users Say Thank You to POCOYO For This Useful Post:
autodiagauto (10/02/2025), mahfoud lichani (10/02/2025), simonpbmeca49 (10/02/2025)
Vieux 10/02/2025, 19h03   #3
simonpbmeca49
Merci beaucoup POCOYO, on ne peut pas etre plus clair, bien compris !
Mais comment as-tu trouvé la correspondance à FLA ?
J'ai chercher sur le net, mais aucune info sur les feux de route
Vieux 10/02/2025, 19h49   #4
POCOYO
Avatar de POCOYO
Dans ma cuisine au fond d’une marmite [emoji1787]
Vieux 10/02/2025, 23h12   #5
simonpbmeca49
mdr !
Je vais essayer d'apprendre à cuisiner alors, mais pas sur que je le fasse aussi bien que toi ;)
Vieux 10/02/2025, 23h25   #6
POCOYO
Avatar de POCOYO
Je t’ai envoyé un MP à consulter
En retour envoi un bon fufu et du gâteau keke[emoji1787]
simonpbmeca49 (11/02/2025)
3g0, component, operated, serial, subsystem
Interpretation diag simonpbmeca49 Mécanique générale 1 16/06/2024 01h50
Erreur checksum VCDS Zozoouf Vw, Audi, Skoda, Seat, Bentley 21 30/06/2021 14h49
interprétation markko Café du forum 7 17/09/2019 07h22
VCDS erreur canal non desponible hichemok Vw, Audi, Skoda, Seat, Bentley 3 31/07/2016 12h48
Interprétation des données BSI looping8910 Electronique 11 06/04/2015 14h05
Fuseau horaire GMT +1. Il est actuellement 08h00.
