Vieux 10/04/2020, 00h55   #46
calixo22
Avatar de calixo22
calixo22 is a glorious beacon of lightcalixo22 is a glorious beacon of lightcalixo22 is a glorious beacon of lightcalixo22 is a glorious beacon of lightcalixo22 is a glorious beacon of lightcalixo22 is a glorious beacon of light
tu veux dire dessouder l eprom de l ancien et la ressouder sur le 2e bsi ?
cest chaud a dessouder les 2 pistes ! merci de ton aide
calixo22 est déconnecté   Réponse avec citation
Vieux 10/04/2020, 01h02   #47
bel27
Avatar de bel27
Pouvoir de réputation: 36
bel27 has a reputation beyond reputebel27 has a reputation beyond reputebel27 has a reputation beyond reputebel27 has a reputation beyond reputebel27 has a reputation beyond reputebel27 has a reputation beyond reputebel27 has a reputation beyond reputebel27 has a reputation beyond reputebel27 has a reputation beyond reputebel27 has a reputation beyond reputebel27 has a reputation beyond repute
Envoyé par calixo22 Voir le message
Oui cest sa
bel27 est déconnecté   Réponse avec citation
The Following User Says Thank You to bel27 For This Useful Post:
calixo22 (10/04/2020)
Vieux 10/04/2020, 01h17   #48
calixo22
Avatar de calixo22
ok je vais tenter ca il reste plus que ca merci
Vieux 10/04/2020, 01h44   #49
amrougafsa
Avatar de amrougafsa
amrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond reputeamrougafsa has a reputation beyond repute
pour commencer le bon pin code est : SWGH
bon le dump bsi est corrompu mauvaise écriture et malheureusement même le swap eeprom ne vais pas résoudre ton soucis désolé. donc ne prends pas de risque et dessouder les deux étages de nouvel bsi.
voici la solution a 100% mais tu sera obliger de chercher diagbox (chercher un membre TE prés de chez toi pour une heure de diagbox)
car faut recoder les clés et tous telecoder et pas besoin de passer par service psa la version 7.57 fait l'affaire hors ligne.
bon voici pour toi vierge fonctionnel pour le type de ton bsi injecter le et relit ton bsi pour comparer que t'as fait une bonne écriture.
bien-sure tu aura pas même le contact sur tableau de bord que après telecoder bsi avec cle et carte .
sinon commence par écrire le vierge et relit et si tu aura des difficultés avec diagbox contacter moi je te fait sa a travers teamviewer .
bon courage l'ami et @+
dans ta boite
Type de fichier : rar 95256_vierge 208.rar (5,5 Ko, 14 affichages)
donnes un poisson à un homme tu le nourris un jour apprends lui à pêcher tu le nourris pour la vie
amrougafsa est déconnecté   Réponse avec citation
The Following 6 Users Say Thank You to amrougafsa For This Useful Post:
adlen22 (16/04/2020), bel27 (10/04/2020), calixo22 (10/04/2020), DAVID02620 (10/04/2020), jean-marc 10 (10/04/2020), mawoussiboris (04/01/2021)
Vieux 10/04/2020, 02h39   #50
bel27
Avatar de bel27
mince je voulais dire de dessouder que l ancien bsi lire l eeprom sur soic8 puis Ecrire sur le nouveau sans dessouder
mais suis les conseils de amrougasfa avant si tu veu
The Following 2 Users Say Thank You to bel27 For This Useful Post:
amrougafsa (10/04/2020), calixo22 (10/04/2020)
Vieux 10/04/2020, 02h45   #51
amrougafsa
Envoyé par bel27 Voir le message
oui pourquoi pas c'est une bonne idée si ya pas de tentative d’écriture sur l’ancien bsi
The Following User Says Thank You to amrougafsa For This Useful Post:
bel27 (10/04/2020)
Vieux 10/04/2020, 03h05   #52
bel27
Avatar de bel27
Cool
Envoyé par amrougafsa Voir le message
moi je connais pas mieu que toi frero vivement que tu vienne en france si dieu le veut
bien le nouveau avatar
amrougafsa (10/04/2020), DAVID02620 (10/04/2020)
Vieux 10/04/2020, 03h49   #53
calixo22
Avatar de calixo22
Merci les amis de vos conseils.
Je vais essayer ça demain si tout va bien ou samedi
---------- Post added at 01h49 ---------- Previous post was at 01h46 ----------
J’ai Diag box mais il y a tellement de telecodage possible que je veux passer par service et télécoder en ligne le bsi.
The Following 2 Users Say Thank You to calixo22 For This Useful Post:
amrougafsa (10/04/2020), jean-marc 10 (10/04/2020)
Vieux 10/04/2020, 11h10   #54
amrougafsa
Bien que t'as diagbox mais en parallèle je doute que gq4x fait une bonne lecture et écriture, je n'ai pas cette appareil mais elle ressemble a minipro et labtool.
Pour moi j'interviens sur ce type du bsi avec xprog et je pense sue upa-usb peut faire l'affaire aussi.
Bon sur mon message précédent ya une faute de frappe et pour corriger tu aura pas du contacte sur le tableau de bord faut d'abord telecoder vehicule avec cle et non avec carte car avec un vierge et par défaut vehicule avec carte et peut-être ça empêche le recodage cle et l'écriture de pin code.
Sinon avant d'injecter le mien vierge essayer d'obtenir le + apres cotacte avec le telecodage diagbox et essayer de recoder les clés.
Envoyé de mon JKM-LX1 en utilisant Tapatalk
The Following 2 Users Say Thank You to amrougafsa For This Useful Post:
calixo22 (10/04/2020), jean-marc 10 (10/04/2020)
Vieux 10/04/2020, 14h17   #55
jean-marc 10
Avatar de jean-marc 10
Pouvoir de réputation: 23
jean-marc 10 has much to be proud ofjean-marc 10 has much to be proud ofjean-marc 10 has much to be proud ofjean-marc 10 has much to be proud ofjean-marc 10 has much to be proud ofjean-marc 10 has much to be proud ofjean-marc 10 has much to be proud ofjean-marc 10 has much to be proud ofjean-marc 10 has much to be proud of
calixo c'est dommage que l'on soit confiné , je serrai passer chez toi avec Io terminal 10s pour écrire ton eprom sans rien démonté , car nous ne sommes pas très loin l'un de l'autre !
jean-marc 10 est déconnecté   Réponse avec citation
The Following 4 Users Say Thank You to jean-marc 10 For This Useful Post:
amrougafsa (10/04/2020), calixo22 (10/04/2020), INVICTUS (10/04/2020), Y.B tec (11/04/2020)
Vieux 10/04/2020, 14h27   #56
calixo22
Avatar de calixo22
Salut jm,
Merci de ton aide !
J ai hésité à investir pour io Terminal mais j ai pense que c’était une eeprom classique comme sur les Peugeot anciennes génération 95p08 par exemple , mais là je pense que c’est plus complexe que le code pin doit être et sur eeprom et sur la flash cest peut être le problème checksum différent.
Merci à tous
The Following User Says Thank You to calixo22 For This Useful Post:
Vieux 10/04/2020, 16h24   #57
saadaoui frere
Avatar de saadaoui frere
saadaoui frere has a spectacular aura aboutsaadaoui frere has a spectacular aura aboutsaadaoui frere has a spectacular aura about
SALUT T MONDE slamalikom une simple aide pour faire l apprentissage de la cle il faut d abrd faire :
1-l appairage bsi + calculateur
2- telecodage
il faut debrancher compteur avant cette operation Sur PSA en principe BSI et compteur . Si tu changes un des deux, le compteur prendra les kilométrages le plus élevé .
pour moi fvdi peut faire apprentissage cle aussi diagbox hor ligne
(si t aide ou non)
saadaoui frere est déconnecté   Réponse avec citation
The Following User Says Thank You to saadaoui frere For This Useful Post:
Vieux 10/04/2020, 22h18   #58
calixo22
Avatar de calixo22
salut les amis ,
en injectant un vierge et en prenant 1 jeton sur service box tout est revenu en ordre avec un telecodage automatique et une adaptation de clef ..
merci a tous pour vos messages et votre aide j espere que mon post pourra aider d autres personnes
The Following 3 Users Say Thank You to calixo22 For This Useful Post:
amrougafsa (11/04/2020), INVICTUS (10/04/2020), jean-marc 10 (11/04/2020)
Vieux 10/04/2020, 22h40   #59
Tof02770
Avatar de Tof02770
Tof02770 is a splendid one to beholdTof02770 is a splendid one to beholdTof02770 is a splendid one to beholdTof02770 is a splendid one to beholdTof02770 is a splendid one to beholdTof02770 is a splendid one to beholdTof02770 is a splendid one to behold
code pin comme en dit HGWS ben ts monde attends la paye patron lol
Tof02770 est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to Tof02770 For This Useful Post:
INVICTUS (10/04/2020), kjzhm (13/05/2020)
Vieux 11/04/2020, 00h11   #60
calixo22
Avatar de calixo22
le code etait SWGH
amrougafsa (11/04/2020), komorovskij (26/11/2020)
Citroen refuse de me fournir le code pin de la clé (code confidentiel BSI) redmou Peugeot, Citroën 27 07/01/2020 22h51
code injection immobilizer renault dacia code antidémarrage yahia1908 Transponder, code pin 0 19/10/2017 16h04
demande modification dump pour eliminer code code off ziamo Autoradio et Navigateur GPS 3 19/01/2013 01h07
jumpy code defaut p1613 code injecteur rrguillaume Peugeot, Citroën 6 30/12/2012 12h59
Fuseau horaire GMT +1. Il est actuellement 18h16.
