Vieux 02/06/2015, 17h56   #91
ecutech
Avatar de ecutech
Pouvoir de réputation: 84
ecutech has a reputation beyond reputeecutech has a reputation beyond reputeecutech has a reputation beyond reputeecutech has a reputation beyond reputeecutech has a reputation beyond reputeecutech has a reputation beyond reputeecutech has a reputation beyond reputeecutech has a reputation beyond reputeecutech has a reputation beyond reputeecutech has a reputation beyond reputeecutech has a reputation beyond repute
307 said :)))))
pas de politesse pas d'aide , Pas de retour pas d'aide ! EP+
ecutech est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to ecutech For This Useful Post:
S-keys (02/06/2015), soustourou (02/06/2015)
Vieux 02/06/2015, 18h14   #92
soustourou
Avatar de soustourou
Pouvoir de réputation: 27
soustourou has much to be proud ofsoustourou has much to be proud ofsoustourou has much to be proud ofsoustourou has much to be proud ofsoustourou has much to be proud ofsoustourou has much to be proud ofsoustourou has much to be proud ofsoustourou has much to be proud ofsoustourou has much to be proud ofsoustourou has much to be proud of
oui une 307 HDI 110
On a souvent besoin d'un plus petit que soi
soustourou est déconnecté   Réponse avec citation
Vieux 02/06/2015, 18h21   #93
soustourou
l'ecu que j'ai recupere provient d'une xsara ça fait pas l'affaire?
Vieux 02/06/2015, 18h21   #94
ecutech
Avatar de ecutech
Le numero bosh please
The Following User Says Thank You to ecutech For This Useful Post:
Vieux 02/06/2015, 18h25   #95
soustourou
c 'est pas ça ?
Vieux 02/06/2015, 18h28   #96
soustourou
0281010766 c'est pas ça ?
The Following User Says Thank You to soustourou For This Useful Post:
ecutech (02/06/2015)
Vieux 02/06/2015, 18h32   #97
ecutech
Avatar de ecutech
Oui mais celle de la xsara ca m'étonne quel est le meme numero que la 307 regarde les 2 ref et marque moi les
Vieux 02/06/2015, 18h41   #98
soustourou
ok 0281010766 EDC15C2 9643526080 97 01050228FM0326 7046 0110 18502 voila j'ai tout marqué
Vieux 02/06/2015, 18h50   #99
S-keys
V.I.P
Avatar de S-keys
Pouvoir de réputation: 140
ton numero que tu as poste c'est xsara, c'est pour ça j'ai rien compris.
il te dit de poste le numero du calculo origine!!!!!!!!!!!!!
pour voir s'ils sont compatible!!!
S-keys est déconnecté   Réponse avec citation
The Following User Says Thank You to S-keys For This Useful Post:
Vieux 02/06/2015, 19h00   #100
soustourou
AH OK le num 0281010779 EDC15C2 9644606180
Vieux 02/06/2015, 19h21   #101
S-keys
V.I.P
Avatar de S-keys
pas compatible!!!!
cherche plutot sur 2.2hdi
il est unique sur 2.0hdi
Vieux 02/06/2015, 19h59   #102
ecutech
Avatar de ecutech
Du coup si tu as ca sous main fait un vierge et re codage si tu doit l'acheter je lai en stock je peu te depanner . Mais normalement tu peu peux rattraper les pistes la decu cest assez simple.
Vieux 02/06/2015, 21h50   #103
soustourou
mais la 5p08 est griée
Vieux 02/06/2015, 22h38   #104
ecutech
Avatar de ecutech
tu peu en remettre une autre mais tu va galéré car leeprom contient la partie boot ducoup tu peu pas mettre n'importe quoi a part un vierge apres tu peu en mettre une autre et si ta besoin j'ai les donné des celle des mes sauvegarde
Vieux 02/06/2015, 22h40   #105
r1lef
V.I.P
Avatar de r1lef
Pouvoir de réputation: 62
r1lef has a reputation beyond reputer1lef has a reputation beyond reputer1lef has a reputation beyond reputer1lef has a reputation beyond reputer1lef has a reputation beyond reputer1lef has a reputation beyond reputer1lef has a reputation beyond reputer1lef has a reputation beyond reputer1lef has a reputation beyond reputer1lef has a reputation beyond reputer1lef has a reputation beyond repute
Envoyé par said31 Voir le message
pas compatible!!!!
comment savoir la compatibilité à partir des références ? tu as un logiciel pour ça ???
r1lef est déconnecté   Réponse avec citation
aide aide immo off ecu inconnu... arnaud77 Immobilizer dumps/solutions 5 31/05/2012 03h48
Fuseau horaire GMT +1. Il est actuellement 22h04.
