Vieux 20/09/2015, 08h44   #31
Simple
Avatar de Simple
Pouvoir de réputation: 22
Simple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud of
I have just come across a detailed (in French) hardware upgrade to the Lexia interface by devildante007 which you may with to consider.
http://www.tlemcen-electronic.com/fo...ad.php?t=43964
Simple est déconnecté   Réponse avec citation
Vieux 20/09/2015, 19h12   #32
inventeur67
Avatar de inventeur67
inventeur67 is on a distinguished road
Today I did a test on a Peugeot 206 and nothing, I think the cable is out of order.
I will re-contact the seller to see with him
inventeur67 est déconnecté   Réponse avec citation
Vieux 20/09/2015, 19h50   #33
Simple
Avatar de Simple
This is the same as mine:
http://www.aliexpress.com/item/Facto...74_75,201409_1
Lexia 3 Diagnostic Tool Description: (taken from the site)
1.It is compatible with Citroen cars including: C1, C2, C3, C4, C5, C6, C8, CCROSSER, NEMO, BERLINGO, JUMPY, JUMPER, AX, SAXO, BX and so on.
2.It is compatible with most Peugeot cars from 1995.
3.Diagnostics is performed via OBD-II connector (which is located near steering wheel) or via manufacturer-specific connector (only older cars, pre-2001).
4.lexia 3 Full Chip Firmware Serial Reference Number: 921815C/
Vieux 21/09/2015, 18h52   #34
inventeur67
This is mine:
http://www.ebay.fr/itm/PP2000-Lexia-...item54079d626b
I see with the seller for warranty before doing anything.
Vieux 21/09/2015, 18h53   #35
inventeur67
PP2000 Lexia 3 Diagnostic Interface Scan Tool For Peugeot Citroen V7 V48 V25
Brand New!!!
- Lexia 3 Interface Supplied With Diagbox V7.33 Stable Full Version,Interface works on Peugeot 307 and Citreon C5.
Vieux 21/09/2015, 22h59   #36
Simple
Avatar de Simple
If they confirm the C5 and 307, it is good, also it has a couple of extra connectors.
Good Luck.
Calculateurs alexio Vente, Achat, Echange 0 23/04/2014 12h14
programmation des calculateurs mahiou Réparation & Programmation des calculateurs 3 14/01/2014 01h37
calculateurs neuf zaouibachir Vente, Achat, Echange 0 10/10/2013 23h45
Fuseau horaire GMT +1. Il est actuellement 04h05.
