Vieux 18/01/2016, 17h54   #181
RIMKACHIP
Avatar de RIMKACHIP
RIMKACHIP is a name known to allRIMKACHIP is a name known to allRIMKACHIP is a name known to allRIMKACHIP is a name known to allRIMKACHIP is a name known to allRIMKACHIP is a name known to all
Tu as mis clio2 ca le fait sur lesquels stp ? Dci non car c ddcr ! Essence 5nr ?
RIMKACHIP est déconnecté   Réponse avec citation
Vieux 18/01/2016, 18h02   #182
yvespapou
Avatar de yvespapou
Pouvoir de réputation: 37
yvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond repute
Envoyé par gabigafu Voir le message
salut yvespapou, je viens de telecharger et de voir tes photos. As-tu appuye sur le bouton verte au fleche pour te connecter a l'ecu? Ca semble comme si tu n'avais pas appuye ce bouton, c'est a dire pas de connection. A gauche de ce bouton il y a aussi un autre bouton comme un escalier, ca fait play continuement ou une fois, c'est a dire ca apporte les donnees de maniere continue ou une seule fois, c'est comme ca en DDT2000, il faut essayer et jouer avec ca. Si tu as d'autres questions liees aux renolink, n'hesite pas.
ok j'essai demain
yvespapou est déconnecté   Réponse avec citation
Vieux 18/01/2016, 19h27   #183
gabigafu
Avatar de gabigafu
Pouvoir de réputation: 43
gabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond repute
Envoyé par RIMKACHIP Voir le message
Sur la meme voiture, il peut clear immo code dans l'injection, n'importe quelle injection, ca se connecte a uch
gabigafu est déconnecté   Réponse avec citation
Vieux 18/01/2016, 19h28   #184
RIMKACHIP
Avatar de RIMKACHIP
Pas bien compris si j'ai une clio2 sur lequel je change le ddcr c possible ? Merci
Vieux 18/01/2016, 19h33   #185
gabigafu
Avatar de gabigafu
donc il faut que l'injection et l'uch soient deja paires,renolink se connecte a uch donne une commande, au premier apc l'injection est vierge, puis au deuxieme contacte se recode, valable pour clio2 et laguna2
Vieux 18/01/2016, 19h37   #186
RIMKACHIP
Avatar de RIMKACHIP
Ok g pigé pas très utile alors s'il faut qu'il soit déjà appairé ! C dommage mais en gros si je prends une clio2 je fais cette manip et avant le 2eme apc je démonte le ddcr je le mets dans une autre c bon mais bon fo toujours que la première soit appairé c dommage !!!
Vieux 18/01/2016, 20h19   #187
yvespapou
Avatar de yvespapou
salut j'ai un calculateur d'occasion un sid306 a monter sur un duster 2014 je peux enlever l'anti démarrage ou l"adapter
Vieux 18/01/2016, 20h21   #188
gabigafu
Avatar de gabigafu
non, desole
Vieux 18/01/2016, 20h22   #189
gabigafu
Avatar de gabigafu
il s'agissait de clio2 et laguna2 pas de duster
Vieux 18/01/2016, 20h54   #190
stephane
Avatar de stephane
Pouvoir de réputation: 120
stephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond reputestephane has a reputation beyond repute
Ha ok ....bon bas laisse tombé pour moi gaby si c est pour faire que des vielles dob ca m intéresse plus ,la clio2 et la megane2 ça fait belle lurette que j en fait plus.
Dommage plein d espoirs réduit a néant
C est sans moi!!!
Bonne continuation
Stephane
stephane est déconnecté   Réponse avec citation
Vieux 19/01/2016, 06h57   #191
jah83
Avatar de jah83
Pouvoir de réputation: 243
J avoue qu' avec tous ca je suis un peu paumé sur ce que renolink peut.ou ne peut pas.faire et sous quelle conditions. Pas de possibilité d avoir un petit fichier Excel récapitulant tout ça ?
Vieux 19/01/2016, 07h14   #192
gabigafu
Avatar de gabigafu
- donc tu peux faire diag comme en DDT2000 pour toutes les voitures, y compris Talisman et Megane4, test d'actionneurs, changer le numero vin, etc...
- puis tu peux retrouver le code pin (apv) pour les uch jusqu'a Clio3 y compris;
- pour ces uch renolink peut effacer antidemarrage et aussi pour megane3 et laguna3;
- tu peux aussi effacer le code immo dans les dae de clio3/modus et megane3/scenic3;
- pour les clio2 et laguna2 pour les uch et les injections deja appairees, tu peux effacer le code immo de l'injection.
Vieux 19/01/2016, 07h28   #193
gabigafu
Avatar de gabigafu
je veux eclairer qqchose, quand je dis faire diag comme en DDT2000, ca peut faire aussi des adaptations, comme par exemple, activer/desactiver cruise control dans l'injection, activer/desactiver hill start assistance en abs, etc..., c'est a dire au niveau d'usine.
Vieux 19/01/2016, 07h53   #194
jah83
Avatar de jah83
Ok merci. je suppose qu' il gère sans soucis l apprentissage de carte sur laguna 2 et Scenic 2 ph1 etph2 ?
Vieux 19/01/2016, 08h06   #195
gabigafu
Avatar de gabigafu
oui, ca va marcher
Abs/esp calculator diagprog ABS, ESP, DSC 117 20/11/2022 17h30
Abs esp calculator kevin22 Immobilizer dumps/solutions 1 05/06/2015 15h09
PSA pin calculator diagnosis29 Transponder, code pin 12 27/06/2014 13h11
psa calculator nacerweb Transponder, code pin 0 18/01/2013 22h34
Fuseau horaire GMT +1. Il est actuellement 00h47.
