Vieux 29/04/2021, 11h19   #16
jpeto
Avatar de jpeto
Pouvoir de réputation: 5
jpeto will become famous soon enough
Donc aujourd hui plus de ralenti!
Je sais plus trop quoi penser..
jpeto est déconnecté   Réponse avec citation
Vieux 29/04/2021, 13h46   #17
baccaraboss
Avatar de baccaraboss
baccaraboss has a spectacular aura aboutbaccaraboss has a spectacular aura about
as tu essayer le RAZ apprentissage que t'a recommandé zav_ze_best ?
baccaraboss est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to baccaraboss For This Useful Post:
ozilmlk (29/04/2021), zav_ze_best (29/04/2021)
Vieux 29/04/2021, 17h51   #18
jpeto
Avatar de jpeto
oui apprentissage refait!
Vieux 29/04/2021, 18h05   #19
zav_ze_best
Avatar de zav_ze_best
zav_ze_best has much to be proud ofzav_ze_best has much to be proud ofzav_ze_best has much to be proud ofzav_ze_best has much to be proud ofzav_ze_best has much to be proud ofzav_ze_best has much to be proud ofzav_ze_best has much to be proud ofzav_ze_best has much to be proud of
Prend du nettoyant fréon et bombarde en vers l'admission voir si tu as pas une prise d'air, tu auras un changement de régime si c'est le cas
zav_ze_best est déconnecté   Réponse avec citation
The Following User Says Thank You to zav_ze_best For This Useful Post:
baccaraboss (30/04/2021)
Vieux 29/04/2021, 18h19   #20
nastradini
Avatar de nastradini
Pouvoir de réputation: 24
nastradini has much to be proud ofnastradini has much to be proud ofnastradini has much to be proud ofnastradini has much to be proud ofnastradini has much to be proud ofnastradini has much to be proud ofnastradini has much to be proud ofnastradini has much to be proud ofnastradini has much to be proud of
si le moteur aspire de l'air derrière le boite papillon ,,, le régime du moteur augmente au-dessus de 2000 rpm
nastradini est déconnecté   Réponse avec citation
Vieux 30/04/2021, 00h29   #21
baccaraboss
Quand tu dis que tu retires la durite du master-vac, la voiture accélère a 1200T/min, tu as quoi comme donnée a la valise?
Il se peut que ton capteur de pression absolu soit mal taré et donne une fausse valeur même si elle est neuve, regarde si tu as pas une perte sur le faisceau entre le capteur et le calculateur de même pour le débitmètre
Tes bougies ont combien de Km?
The Following User Says Thank You to baccaraboss For This Useful Post:
zav_ze_best (30/04/2021)
Vieux 30/04/2021, 10h20   #22
jpay2
Avatar de jpay2
jpay2 has a brilliant futurejpay2 has a brilliant futurejpay2 has a brilliant futurejpay2 has a brilliant futurejpay2 has a brilliant futurejpay2 has a brilliant futurejpay2 has a brilliant futurejpay2 has a brilliant futurejpay2 has a brilliant futurejpay2 has a brilliant futurejpay2 has a brilliant future
salut ,
qiuand elle fait la panne de ralenti ,
1er
essaye de la coller a 2000tr/m a l'arret durant 10/15s , puis laisse la tomber au ralenti , voir si ensuite elle cale ou pas (poulie dephaseur se coince , a voir au diag ....)
2eme ,
fait attention niveau de carburant, si haut reservoir ou pas ( canister en cause )
3eme,
aucun dtc n'est en memoire ( capteur aac, vilo, dephaseur ?)
4eme ,
regarde bien tes bougies, 600mb, peut sous entendre ratee cylindre et la pression tubulure remonte , d'ou le ralentie cale
ce phenomene est tres frequent sur 1.6 16s , et pleins de chose possibles ....courage !
jpay2 est déconnecté   Réponse avec citation
The Following User Says Thank You to jpay2 For This Useful Post:
Vieux 30/04/2021, 13h17   #23
jpeto
Avatar de jpeto
Bonjour et encore merci a tous!
Du coup, ce w-e je vais pouvoir m y remettre en prenant compte des differents posts.
Ce qui est sur c est que quand elle bien bien chaude (apres les grosse accelerations ou roulage assez long), plus de probleme!!
Pour la poulie dephaseur et son capteur aac, le def remonte episodiquement, mais j ai tellement eu ce genre de motorisation avec ce def quasi" normal" qui l accompagne que j ai vraiment de la peine a croire qu il puisse provoquer cette panne..? En tout cas ce serait bien la 1ere fois.
The Following User Says Thank You to jpeto For This Useful Post:
Vieux 30/04/2021, 15h16   #24
zav_ze_best
Salut jpeto,
Si a chaud elle disparaît cela fait vraiment penser à une prise d'air qui s'en va lorsque le métal et les matières se sont bien dilatées et comblent la prise...
Essaye avec nettoyant frein sur l'admission, papillon etc...
Vieux 30/04/2021, 17h28   #25
zav_ze_best
Envoyé par baccaraboss Voir le message
Salut baccara,
Un moyen simple pour voir si ton capteur est viable, c'est de voir sous contact s'il donne la même valeur que le capteur de Patmo. Déjà tu as un signe.
Il n'y a pas de débitmètre la dessus me semble, si ?
Vieux 30/04/2021, 20h39   #26
jphp
Avatar de jphp
Pouvoir de réputation: 250
salut essaye une sonde temperature d"eau gestion moteur
Vieux 30/04/2021, 20h46   #27
zav_ze_best
Salut jp,
Ç'est vrai que dit comme ça cela me semble évident, mais vu le premier post je me suis dis qu' il a contrôlé ça... Si c'est bien ça chapeau !
jphp (30/04/2021)
Vieux 30/04/2021, 20h53   #28
jphp
Avatar de jphp
il faut essayer possible que sa sonde deconne ca coute pas cher c'est remplacé en 2 mn pas de codage faudrait pas passer a coté
attention temperature d'eau gestion moteur il y a surement une autre sonde de temperature d'eau celle pour le voyant et l'aiguille pas celle là
Dernière modification par jphp ; 30/04/2021 à 20h59.
Vieux 30/04/2021, 21h31   #29
zav_ze_best
Sur k4m c'est la même qui fait les deux elle est sur le boîtier d'eau. L'injection transmet l'info au tdb. Peut être déjà regarder la valeur à froid le matin, ça doit a peu près correspondre à la temp ambiante à 2 3 degrés près.
Vieux 01/05/2021, 11h02   #30
jpeto
Avatar de jpeto
Bonjour, deja pour l instant il pleut et j ai pas d abri donc les tests seront certainement demain..
Pour la t° de l eau, le diag me la donne et elle est tres coherente!
Plus haut, il etait question aussi de la pression et idem a l arret, elle est proche de l atmo!
D ailleurs, pour etre sur, j ai remplacé capteur pression/t° air/electrovanne canister/boitier papillon.. j ai un scenic2 avec la meme motorisation et je peux facilement intervertir les pieces!
Ralenti JOSEF Automobile en général 8 23/11/2020 06h11
Problème Ralenti a4 1.9 tdi 130 Mac-Gyver Vw, Audi, Skoda, Seat, Bentley 9 22/02/2017 19h31
1.6 tdi ne tien plus le ralenti dump974 Mécanique générale 40 09/08/2016 18h21
Ralenti 607 2.2 hdi 136 chaoui05 Peugeot, Citroën 24 31/08/2014 14h22
ralenti 308 hdi toomax Mécanique générale 10 03/06/2013 18h41
Fuseau horaire GMT +1. Il est actuellement 13h43.
