Vieux 22/10/2019, 23h34   #16
Shadows93
Avatar de Shadows93
Shadows93 is a splendid one to beholdShadows93 is a splendid one to beholdShadows93 is a splendid one to beholdShadows93 is a splendid one to beholdShadows93 is a splendid one to beholdShadows93 is a splendid one to beholdShadows93 is a splendid one to beholdShadows93 is a splendid one to behold
Louay a raison, recupere ton ancien bouchon du vase d'expansion cassé et remplace par celui qui est actuellement sur le nouveau et refait un essai pour voir si cela change quelque chose.
Shadows93 est déconnecté   Réponse avec citation
The Following User Says Thank You to Shadows93 For This Useful Post:
loubia69 (23/10/2019)
Vieux 22/10/2019, 23h45   #17
Bigorno91
Avatar de Bigorno91
Pouvoir de réputation: 30
Bigorno91 has a brilliant futureBigorno91 has a brilliant futureBigorno91 has a brilliant futureBigorno91 has a brilliant futureBigorno91 has a brilliant futureBigorno91 has a brilliant futureBigorno91 has a brilliant futureBigorno91 has a brilliant futureBigorno91 has a brilliant futureBigorno91 has a brilliant futureBigorno91 has a brilliant future
Slm
Ss vouloir te sapé le morale je partage l'avis de sadna j'ai déja eu le soucis sur 406 hdi 2l pas de fuite mais pression ds le circuit et sa finit pas degueuler au vase d'expansion.
Debut de joint cucu
Ou radiateur bouché
Vois l'aspect du ldr si marron foncé boueux = eau du robinet donc circuit encrassé par la boue et les depots corrodé du bloc.
D.E.R AUTOMOBILE
Bigorno91 est déconnecté   Réponse avec citation
The Following User Says Thank You to Bigorno91 For This Useful Post:
Vieux 22/10/2019, 23h59   #18
selouan
Avatar de selouan
Pouvoir de réputation: 26
selouan has much to be proud ofselouan has much to be proud ofselouan has much to be proud ofselouan has much to be proud ofselouan has much to be proud ofselouan has much to be proud ofselouan has much to be proud ofselouan has much to be proud ofselouan has much to be proud of
Salut percé ton bouchon avec un petit forêt et roule un moment si pas de problème et que ta de la vapeur qui sort alors ta un début de joint de culasse
selouan est déconnecté   Réponse avec citation
The Following User Says Thank You to selouan For This Useful Post:
Vieux 23/10/2019, 06h30   #19
Envoyé par louay Voir le message
salut durite dure, commence par vérifier la soupape de sécurité du bouchon (1,5 bar) avant toute chose
le bouchon a été changé....
Donc si les symptômes étaient présents avant les travaux, je pense que la fuite sur le boitier d'eau est apparu à cause d'une pression trop importante déjà présente dans le circuit ? Mais je suis pas sur d'avoir bien compris ta réponse concernant les symptômes avant travaux car tu dis aussi " mais le véhicule fonctionnait bien avant la fuite "
Tu peux te fabriquer un bouchon de vase avec manomètre (avec l'ancien) pour mesurer la pression du circuit, tu seras fixé.
Bouchon ouvert les ventilos se déclenchent ?
Lorsque le moteur est à température (ventilos déclenchés au moins une fois) , bouchon ouvert (durites molles) et que tu refermes le bouchons, les durites deviennent dures ?
Le matin à froid quand tu ouvres le bouchon tu as de la pression dans le circuit ?
As tu nettoyé le circuit de ldr au jet d'eau, radiateur y compris (mauvaise circulation si pas assez de débit = pression) ?
Tu as du chauffage dans l'habitacle ?
Quelles sont les vis de purges que tu as trouvées ?
Une PAE HS, le moteur devrait monter en température, ce qui n'est pas le cas apparemment.
loubia69 (23/10/2019), WJon (23/10/2019)
Vieux 23/10/2019, 08h35   #20
loubia69
Avatar de loubia69
loubia69 has a spectacular aura aboutloubia69 has a spectacular aura about
slt a tous
les ventilos ne s enclenche pas car vers 83c ça comment a déborder et je coupe le moteur
c est seulement vers cette température que ça déborde mais doucement sans bulle
Pour visses de purge : une sur thermostat et une sur durite chauffage une autre?
Je n ai pas nettoyé le circuit
J ai du chauffage dans l habitacle
je compte percer le bouchon et voir ce que cela donne et je vais contrôler la pression a froid
loubia69 est déconnecté   Réponse avec citation
Vieux 23/10/2019, 09h01   #21
Ca ressemble quand même à une mauvaise purge, tu n'as pas de vis de purge sur le radiateur (moteur) ??
Le radiateur peut aussi être obstrué, voir si pas OK pour démonter durite entrée/sortie et au jet d'eau voir si ça coule bien.
The Following 3 Users Say Thank You to Nico76 For This Useful Post:
loubia69 (23/10/2019), walter92 (23/10/2019), WJon (23/10/2019)
Vieux 23/10/2019, 10h39   #22
nicoc5
Avatar de nicoc5
nicoc5 is on a distinguished road
bonjour,
je pense aussi à une mauvaise purge,de mémoire la purge ne se fait pas à l'aide d'un cylindre de charge.
-placer le cylindre de charge sur le vase
-remplir le circuit tranquillement (environ 1 litre de + que prévu)
-ouvrir les vis de purge
-fermer les vis après écoulement correct sans bulle
-mettre en route maintenir un régime moteur 1500/2000 tr/min jusqu'à enclenchement du ventillo au moins une fois.
-arrêter le véhicule
-attendre le refroidissement complet du moteur,faire le niveau.
ps: pour le cylindre j'utilise un bouteille d'Oassis juste un petit coup de lime tous le tour du goulot et ça rentre en force dans le vase
nicoc5 est déconnecté   Réponse avec citation
The Following 3 Users Say Thank You to nicoc5 For This Useful Post:
loubia69 (23/10/2019), malabar969 (23/10/2019), walter92 (23/10/2019)
Vieux 23/10/2019, 14h33   #23
malabar969
Avatar de malabar969
Pouvoir de réputation: 9
malabar969 will become famous soon enoughmalabar969 will become famous soon enough
Il y a deux possibilités:
- soit une purge incomplète. En théorie, les liquides sont incompressible, mais pas les gaz donc en chauffant le volume de gaz non purgé augmente et chasse le liquide de refroidissement par le vase d'expansion ouvert.
- soit un apport de gaz (fuites minime ou porosité du joint de culasse essentiellement lors de la compression, d'un cylindre vers le circuit de refroidissement).
Maintenant, il faut trouver la cause de ce phénomène.. Personnellement, je testerai la non-contamination ou la contamination du liquide de refroidissement par du CO2.
malabar969 est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to malabar969 For This Useful Post:
Vieux 23/10/2019, 16h31   #24
walter92
Avatar de walter92
walter92 is an unknown quantity at this point
Il met arriver le même problème sur une super 5, il y a de ça 10 ans et le résultat était que le radiateur était mort donc mauvaise circulation des fluides.
Avant que je m'en rende compte j'avais exploser mon radiateur de chauffage, et bien sure j'avais changé carlostat pompe a eau qui avait commencé a fuire....
Donc si le radiateur este d'origine c'est une piste qui mérite que l'on s'y intéresse.
walter92 est déconnecté   Réponse avec citation
The Following User Says Thank You to walter92 For This Useful Post:
Vieux 23/10/2019, 17h12   #25
loubia69
Avatar de loubia69
je viens de faire le test de percer le bouchon du vase:
tous c est bien passé durite molle normale je voyais le liquide monté mais rien ne sort du trou le seul souci c est la température au tableau de bord indique 75 environ alors qu au diag je suis allé jusqu a 93c mais le ventilo ne c est pas enclenché mais normal vous me direz
j avais déjà testé la sonde en la chauffant et tous fonctionnait même ventilo
je vais essayé la méthode de nicoc5 ou si quelq un avait la procédure exacte et le nombre de vise de purge et faire le test co2
Vieux 24/10/2019, 08h45   #26
fedge
Avatar de fedge
fedge has much to be proud offedge has much to be proud offedge has much to be proud offedge has much to be proud offedge has much to be proud offedge has much to be proud offedge has much to be proud offedge has much to be proud offedge has much to be proud offedge has much to be proud of
Salut.
Pour la purge, le plus simple c est de rouler 3 ou 4 km avec la voiture moteur chaud et ça se purge tout seul.
J ai un mauvais pressentiment pour ton joint de culasse. C est peut être la surpression qui a fait péter ton boitier a eau.
fedge est déconnecté   Réponse avec citation
The Following User Says Thank You to fedge For This Useful Post:
loubia69 (25/10/2019)
Vieux 24/10/2019, 09h28   #27
loubia69
Avatar de loubia69
slt se que je comprend pas c est que j ai roulé avec le véhicule 7km avec le boitier cassé bien sur en faisant attention et ca montait bien a 90c et depuis changement plus possible
Vieux 24/10/2019, 09h35   #28
dans ce cas tous les symptômes n'étaient pas présent avant les travaux, donc problème de thermostat qui reste ouvert.
Pour le reste, dans un premier temps, revoir la purge une fois le boitier changé.
Vieux 24/10/2019, 10h10   #29
Je dirai même revoir une bonne purge avant de rechanger le boitier d'eau
Vieux 25/10/2019, 01h44   #30
loubia69
Avatar de loubia69
slt a tous verdict joint de culasse après test co2 mais je comprends toujours pas pourquoi ça ne monte pas en température au compteur
The Following 6 Users Say Thank You to loubia69 For This Useful Post:
electronico (25/10/2019), malabar969 (25/10/2019), Nico76 (26/10/2019), Rallyeman (11/11/2019), sadna (25/10/2019), WJon (25/10/2019)
Bsi xsara 2 soustourou programmation & synchronisation de clé 8 26/04/2019 06h24
Bsi xsara cn2 DIAGSYSTEM25 Réparation & Programmation des calculateurs 0 09/04/2019 18h28
Bsi xsara cn2 DIAGSYSTEM25 Réparation & Programmation des calculateurs 18 09/11/2018 09h19
Bsi cn1 xsara 1,9d Moulay Réparation & Programmation des calculateurs 4 12/04/2018 07h36
xsara hdi abderr16 Flasheur de calculateur 1 16/05/2010 17h25
Fuseau horaire GMT +1. Il est actuellement 15h25.
