Vieux 22/02/2016, 23h21   #16
pacoaloha
Avatar de pacoaloha
pacoaloha is just really nicepacoaloha is just really nicepacoaloha is just really nicepacoaloha is just really nice
De plus les entrées et sorties en interne du calculateur sont différentes (alims et signaux)
pacoaloha est déconnecté   Réponse avec citation
Vieux 22/02/2016, 23h22   #17
r1lef
V.I.P
Avatar de r1lef
Pouvoir de réputation: 62
r1lef has a reputation beyond reputer1lef has a reputation beyond reputer1lef has a reputation beyond reputer1lef has a reputation beyond reputer1lef has a reputation beyond reputer1lef has a reputation beyond reputer1lef has a reputation beyond reputer1lef has a reputation beyond reputer1lef has a reputation beyond reputer1lef has a reputation beyond reputer1lef has a reputation beyond repute
Bon, bin je sors alors ...
Pas de participation = pas de réponse !!! EP+
r1lef est déconnecté   Réponse avec citation
Vieux 22/02/2016, 23h24   #18
smart057
Avatar de smart057
smart057 has a reputation beyond reputesmart057 has a reputation beyond reputesmart057 has a reputation beyond reputesmart057 has a reputation beyond reputesmart057 has a reputation beyond reputesmart057 has a reputation beyond reputesmart057 has a reputation beyond reputesmart057 has a reputation beyond reputesmart057 has a reputation beyond reputesmart057 has a reputation beyond reputesmart057 has a reputation beyond repute
Envoyé par mmk67 Voir le message
Merci c'est gentil de vous occuper de moi.
Smart 057, serais tu m'aider? Je suis de strasbourg mais originaire de Freyming Merlebach.
Je m'y rend demain.
Dommage demain je ne suis pas chez moi.. A Far
smart057 est déconnecté   Réponse avec citation
Vieux 22/02/2016, 23h25   #19
DrDG
Avatar de DrDG
Pouvoir de réputation: 22
DrDG is a splendid one to beholdDrDG is a splendid one to beholdDrDG is a splendid one to beholdDrDG is a splendid one to beholdDrDG is a splendid one to beholdDrDG is a splendid one to beholdDrDG is a splendid one to behold
Slt,
si tu a réussi a récupérer un calculateur prend le bsi et la clé du véhicule donneur.
et ça repart
DrDG est déconnecté   Réponse avec citation
Vieux 22/02/2016, 23h25   #20
mmk67
Avatar de mmk67
mmk67 is on a distinguished road
r1lef, tu n'est pas obligé de sortir lol. Je te comprends tout à fais! je réagirais de la meme manière en étant membre actif d'un forum et en voyant une personne demandé de l'aide alors que depuis 2003 il à a pensé qu'a lui.
Il n'y a aucun soucis !
Merci pour ta remarque.
mmk67 est déconnecté   Réponse avec citation
Vieux 22/02/2016, 23h28   #21
mmk67
Avatar de mmk67
Smart0057. A oui c'est très dommage. Mais je peux me déplacé à Metz s'il le faut.
Dr diag. Ta solution m'a intéréssé mais cela peux poser un problème au futur acheteur.
En effet , si celui ci perd la clé du véhicule il sera très embété.
De plus , le kilométrage du véhicule donneur était de 324000km. Le miens 160000 cela aurai cosé beaucoup de problème.
Vieux 22/02/2016, 23h28   #22
r1lef
V.I.P
Avatar de r1lef
ce n'était absolument pas méchant mais je m'inquiète pour TE en ce moment ... Ce n'est plus LE TE que j'ai connu ! Bref si je peux aider je le fais quand même mais pas à n'importe qui ! Tu as l'air d'avoir du monde prêt à t'aider alors bonne suite à toi mais reviens plus souvent maintenant que tu es revenu de l'étranger ....
Vieux 22/02/2016, 23h30   #23
mmk67
Avatar de mmk67
r1lef j'en prend note. Et tu as raison de t'inquieter pour ce forum. Il faut le préserver!
Bonne soirée à toi aussi.
Vieux 22/02/2016, 23h50   #24
DrDG
Avatar de DrDG
en plus R1lef viens de te donner ton premier thank's ...
Vieux 22/02/2016, 23h58   #25
mmk67
Avatar de mmk67
C'est gentil. Demain je vais acheter un bdm100 parce que je ne sais toujours pas quoi faire.
Vieux 22/02/2016, 23h59   #26
garageducentre
Avatar de garageducentre
Pouvoir de réputation: 32
garageducentre has a brilliant futuregarageducentre has a brilliant futuregarageducentre has a brilliant futuregarageducentre has a brilliant futuregarageducentre has a brilliant futuregarageducentre has a brilliant futuregarageducentre has a brilliant futuregarageducentre has a brilliant futuregarageducentre has a brilliant futuregarageducentre has a brilliant futuregarageducentre has a brilliant future
Dans tes paramètres a tu des valeurs correcte ou pas
Passer pour un idiot au yeux d un imbécile est une volupté de fin gourmet
garageducentre est déconnecté   Réponse avec citation
Vieux 23/02/2016, 00h06   #27
mmk67
Avatar de mmk67
garageducentre De quels paramètres parle tu?
Tout est nikel au niveau du diagnostic. Injecteur temperature admission etc.... par contre niveau sonde de refroidissement la temperature est a 99°C. jai changer plusieurs fois la sonde de température et le débimetre mais rien y fais. Vérifier les fusibles.. pareil. C'est le calculateur. A mon avis quand le faisceaux était hs, les fils ont du se toucher et créer des court circuits qui ont endommagés le calculateur.
Vieux 23/02/2016, 08h31   #28
garageducentre
Slt quand tu debranche la sonde quel valeur a tu et controle la tension et la continuité
Vieux 28/02/2016, 03h03   #29
mmk67
Avatar de mmk67
Bonjour tous le monde,
Comme convenu, j'ai commandé le bdm 100 et j'ai copié avec succes mon calculateur.
Cependant , même avec le nouveau calculo, toujours le même souci.
Sonde de temperature non reconnu et debimetre idem.
Je ne sais plus quoi faire. Maintenant mon diagnostic s'oriente vers le bsi!
Merci pour votre aide
Vieux 10/03/2016, 21h58   #30
mmk67
Avatar de mmk67
Je reviens vers vous et suite à vos conseils, j'ai acheter un calculateur edc16c3 47 0281 010 390 ou j'ai copié dedans les données de mon calculateur au BDM ( Merci à ce forum pour les tutos).
Mais cependant , le problème est toujours présent.
Sonde de température non reconnu malgrès la sonde changé et le faisceau controlé cable par cable. Tous les fusibles sont ok. Le calculateur remplacé.
La bonne choses , c'est que le débimètre est reconnu et il fonctionne.
Mais j'ai toujours ce problème de sonde de température. Une foi la voiture démarré elle monte a 100°C avec le message temperature moteur excessive.
Donc maintenant d'après la logique mon diagnostic s'oriente sur le bsi.
C'est pour cela que je souhaiterais faire un immo off sur le calculateur que je viens d'acheter pour que je puisse mettre un bsi d'occasion.
Je vous transmet le full bdm que j'ai .
Merci de m'avoir lu.
Mehdi.
Type de fichier : rar edc16c3 47 0281 010 390 casse.rar (264,8 Ko, 3 affichages)
besoin d'aide sur calculateur bmw 320D E92 2007 taxi300 Immobilizer dumps/solutions 2 01/02/2015 22h10
Besoin Aide remplacement Calculateur PSA warrio Réparation & Programmation des calculateurs 6 16/09/2014 00h18
besoin d'aide clonage calclateur edc16c3 mika607 Réparation & Programmation des calculateurs 14 23/10/2013 16h35
besoin immo off calculateur renault mascot edc16C3 95160 electroauto Immobilizer dumps/solutions 8 10/10/2013 20h40
Besoin d'aide calculateur MM 1AP.81 ptitom33 Réparation & Programmation des calculateurs 17 26/11/2010 14h59
Fuseau horaire GMT +1. Il est actuellement 12h47.
