Précédent   Tlemcen Car electronics > Outils & Diag > Outils de diagnostique > Renault clip, DDT2000, Nissan consult
Vieux 13/04/2019, 11h37   #31
MrRorry
Avatar de MrRorry
Pouvoir de réputation: 77
MrRorry has a reputation beyond reputeMrRorry has a reputation beyond reputeMrRorry has a reputation beyond reputeMrRorry has a reputation beyond reputeMrRorry has a reputation beyond reputeMrRorry has a reputation beyond reputeMrRorry has a reputation beyond reputeMrRorry has a reputation beyond reputeMrRorry has a reputation beyond reputeMrRorry has a reputation beyond reputeMrRorry has a reputation beyond repute
Envoyé par sami55 Voir le message
Toutes les commandes disponibles ne sont pas intégrées dans l'interface utilisateur graphique dans les fichiers ddt-ecu.
Existe-t-il un outil dans ddt2000 ou renolink qui utilise également les commandes cachées?
Sur ddt4all....
Je parle de ddt2000 et non de ddt4all.
ddt4all est un ( remarquable ) projet de cedric qui vise a "imiter" ddt2000 avec un simple elm327.
On parle de ddt2000 et son pouvoir (en commande manuelle)
donc comme on dit aux antilles "il faut pas melanger coco-abricot" lol
MrRorry est déconnecté   Réponse avec citation
The Following 7 Users Say Thank You to MrRorry For This Useful Post:
aronicky (02/09/2022), jeremy72 (13/04/2019), klif26 (13/04/2019), progdebutant (05/01/2020), tico (13/04/2019), vortex (13/04/2019), zouaoui mohamed (13/04/2019)
Vieux 13/04/2019, 11h42   #32
progdebutant
Avatar de progdebutant
progdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond reputeprogdebutant has a reputation beyond repute
Envoyé par MrRorry Voir le message
Alors je dirais que si tu ne sais pas a quoi sert DDT2000 c'est que tu n'en a pas besoin,
renolink n'est qu'un echantillon de DDT2000, l'avantage de renolink c'est que tu cliques sur un bouton et tout est automatisé (concernant les fonctions prevues par renolink)
Tu peux comparer une fonction renolink a un script de commandes envoyées au calculateur concerné qui s'execute en exploitant le pouvoir de DDT2000 si ca peut t'aider a mieux comprendre. Je trouve ca un peu exageré de comparer les 2 mais bon
Exemple:
Tu veux extraire le pin d'un UCH.
il n'existe pas de commande magique pour ce la, il faut dumper la partie de la memoire concernée pour recuperer l'ISK puis appliquer le decodage pour toruver le pin
avec ddt2000,
Disons qu'il faut envoyer a l'uch (commandes fictives bein entendu)
AA BB CC DD EE 00 12 34 puis 88 55 22 11 66 00 DD
Si tout les conditions sont bien respectées et que tout s'est bien deroulé, l'uch te renvoi les octets qui t'interressent
de la tu decodes et voila ton pin
avec renolink,
tu cliques et il se charge de tout
Donc renolink te fais le boulot en 1 clic mais seulement pour les calculos pour lesquels il a été prevu pour ca, mais avec ddt2000 tu n'as pas de limites si tu connais les commandes qu'il faut et les algos de decodage.
Voila
Salut mrrorry
En fait ma demande de base sur le fait que mon père ancien cotech renault est frustré du manque de possibilité de clip concernant ce qui est reprogrammation de calculateur sous Bornéo 3
Avec ddt2000 on peut aller plus loin à ce niveau si j'ai bien compris par contre commande manuel comme tu dis donc ca doit pas être simple du tout il n'existe pas une sorte de guide concernant ces commandes manuelles ?
Sans connaissance niveau ingénieur renault inutile de se lancer dedans selon toi ?
progdebutant est déconnecté   Réponse avec citation
The Following User Says Thank You to progdebutant For This Useful Post:
klif26 (13/04/2019)
Vieux 13/04/2019, 12h14   #33
sami55
Avatar de sami55
sami55 is a splendid one to beholdsami55 is a splendid one to beholdsami55 is a splendid one to beholdsami55 is a splendid one to beholdsami55 is a splendid one to beholdsami55 is a splendid one to behold
lol
J'avais espéré que vous puissiez me répondre à cette question détaillée.
sami55 est déconnecté   Réponse avec citation
Vieux 13/04/2019, 18h05   #34
MrRorry
Avatar de MrRorry
Envoyé par progdebutant Voir le message
Salut mrrorry
Absolument, c'est bien si tu veux developper un outil, tu n'as pas de limites tant que tu sais ce qu'il faut envoyer comme commandes, il faudra aussi des codes (mot de passe) pour certaines operations...
Je pense que si une bible existe sur le sujet, elle n'a jamais ete rendue publique (a ma connaissance)
Clip c'est pour les ateliers, tout est deja predefini donc tu ne fais pas ce que tu veux avec, c'est different de ddt2000 mais le principe est le meme, envois de commandes et interrogations (pour le diag et la maintenance des vehicules)
apres, si ton pere est frustré et il sait quoi en faire alors oui, ca pourra etre interressant pour lui, mais seul lui connait ses capacités et ce qu'il veut faire donc c'est tres subjectif comme question.
---------- Post added at 18h05 ---------- Previous post was at 18h01 ----------
le "lol" etait pour l'anecdote du proverbe antillais.
Pour ta question, je pourrais pas dire si il y a des fonctions cachées,
ddt4all est open-source donc tu peux eplucher le code pour voir comment ca se presente, ou mem contacter cedric qui se fera un plaisir de partager avec vous son savoir dans ce domaine
The Following 6 Users Say Thank You to MrRorry For This Useful Post:
Binbin (13/08/2019), jah83 (13/04/2019), jeremy72 (14/04/2019), klif26 (13/04/2019), sami55 (13/04/2019), vortex (13/04/2019)
Vieux 13/04/2019, 18h29   #35
progdebutant
Merci pour l'argumentation lol
Sa frustration concerne ( entre autre ) la reprogrammation des ecu injection qui est faite d'habitude Avec clip et DVD reprog mais impossible pour certaines voitures
Mais Ca a vraiment pas l'air simple
klif26 (13/04/2019)
Renolink ( DDT2000 et RPE3) ses possibiliter et fonctions pouettedu76 Renault clip, DDT2000, Nissan consult 3852 20/01/2025 07h00
Ecutool 2.77 tony60 Programmeur de clé 0 15/12/2018 13h46
DDT2000 vs renault CAN clip progdebutant Renault, Dacia, Nissan 20 15/07/2017 00h12
Immo off clio 2001 renolink , clip. matt0013 Immobilizer dumps/solutions 15 22/01/2017 11h43
renolink et can clip mexicain Renault clip, DDT2000, Nissan consult 5 10/12/2016 21h40
Fuseau horaire GMT +1. Il est actuellement 12h49.
