Vieux 10/12/2021, 14h09   #16
boris93600
Avatar de boris93600
Ajoute un fusible 20A à cet emplacement, ou remonte d'un cran celui du dessous (placé actuellement en bobines allumage essence).
Si c ok, il faudra vérifier la config soft UPC (essence/diesel).
boris93600 est connecté maintenant   Réponse avec citation
Shadows93 (10/12/2021), zav_ze_best (10/12/2021)
Vieux 10/12/2021, 14h16   #17
Shadows93
Avatar de Shadows93
Shadows93 is a splendid one to beholdShadows93 is a splendid one to beholdShadows93 is a splendid one to beholdShadows93 is a splendid one to beholdShadows93 is a splendid one to beholdShadows93 is a splendid one to beholdShadows93 is a splendid one to beholdShadows93 is a splendid one to behold
Pièce jointe 92209
Salut boris93600,
merci pour l'info, je test ça et je vous tien au courant.
Shadows93 est déconnecté   Réponse avec citation
The Following User Says Thank You to Shadows93 For This Useful Post:
boris93600 (10/12/2021)
Vieux 10/12/2021, 14h38   #18
zav_ze_best
Avatar de zav_ze_best
zav_ze_best has much to be proud ofzav_ze_best has much to be proud ofzav_ze_best has much to be proud ofzav_ze_best has much to be proud ofzav_ze_best has much to be proud ofzav_ze_best has much to be proud ofzav_ze_best has much to be proud ofzav_ze_best has much to be proud of
Bien vu Boris, ce 20A délivré effectivement l'alim au calculo injection via la liaison 3fb1 si je ne dit pas de bêtise...
Nice!
zav_ze_best est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to zav_ze_best For This Useful Post:
boris93600 (10/12/2021), Shadows93 (10/12/2021)
Vieux 10/12/2021, 15h24   #19
nowen
Avatar de nowen
Pouvoir de réputation: 65
nowen has a reputation beyond reputenowen has a reputation beyond reputenowen has a reputation beyond reputenowen has a reputation beyond reputenowen has a reputation beyond reputenowen has a reputation beyond reputenowen has a reputation beyond reputenowen has a reputation beyond reputenowen has a reputation beyond reputenowen has a reputation beyond reputenowen has a reputation beyond repute
cherches pas trop, ton calculateur moteur est hs
il a cramé et ne pilote plus son réveil, ton upc est en court circuit et envois du 12V en permanence. c'est pour ça que tu démarre avec ton upc ori et calculo ori.
remplaces UPC et DCM 1.2
nowen est déconnecté   Réponse avec citation
The Following 3 Users Say Thank You to nowen For This Useful Post:
angels59 (10/12/2021), Rallyeman (12/12/2021), Shadows93 (10/12/2021)
Vieux 10/12/2021, 15h34   #20
boris93600
Envoyé par nowen Voir le message
J'ai cru comprendre que l'état initial permettait le démarrage et présentait uniquement un "+APC injection" qui ne se coupait pas jusqu'au vidage de la batterie.
Shadow, tu peux confirmer ?
Vieux 10/12/2021, 18h30   #21
angels59
Avatar de angels59
Pouvoir de réputation: 66
Salut shadows
Au pire donne moi ton vin en MP et je t’envoies les schémas afin que tu puisses faire des contrôles.
Connaissant Nowen que je salut et que j'ai toujours plaisir à lire :) Prends son post au sérieux car il ne dit jamais n'importe quoi ;)
PS : pour les contrôles je te guiderais avec le peut de temps que j'ai par contre :(
Rudy
The Following 3 Users Say Thank You to angels59 For This Useful Post:
nowen (11/12/2021), sam27000 (11/12/2021), Shadows93 (10/12/2021)
Vieux 10/12/2021, 18h37   #22
boris93600
Tu as quel code moteur exactement ? K9Kxxx
Vieux 10/12/2021, 20h41   #23
Shadows93
Avatar de Shadows93
Salut nowen,
Merci pour l'info, je m'oriente de plus en plus vers cela mais je veut etre sure avant tout que c'est pas l'UPC qui fait des caprices.
sur les lignes 3FB1 & 3FB2 j'ai de la continuité alors que d'apres le schema electrique sa devrais etre des alims séparer.
et sur c'est 2 alims j'ai du 12 permanant alors que je ne devrais plus en avoir apres coupure contact du moins plus rien après endormissement.
Quelle est la ligne de l'ECU qui pilote le reveil UPC pour que je teste ca stp ?
---------- Post added at 20h37 ---------- Previous post was at 20h33 ----------
Envoyé par angels59 Voir le message
Salut shadows
Rudy
Merci Rudy,
J'ai deja le schema electrique pour le vehicule, mais la j'ai mis le vehicule de coté sinon je vais perdre trop de temps dessus je vais voir ca plus en details lundi les amis.
---------- Post added at 20h38 ---------- Previous post was at 20h37 ----------
Re boris,
Le code moteur c'est le K9K766
---------- Post added at 20h41 ---------- Previous post was at 20h38 ----------
Desolé j'ai sauté ce message sans faire expres, oui c'est bien ca boris +APC injection qui c'est transformer en +Permanant mais avec ECU d'origine elle démarre mais le lendemain batterie a plat alors quelle a été changer par le client.
The Following 2 Users Say Thank You to Shadows93 For This Useful Post:
angels59 (10/12/2021), boris93600 (10/12/2021)
Vieux 10/12/2021, 21h16   #24
Pouvoir de réputation: 277
Re alors tu prend ecu origine tu copie eeprom sur nouvelle ecu ... et vroom
Vieux 10/12/2021, 21h40   #25
boris93600
"sur les lignes 3FB1 & 3FB2 j'ai de la continuité"
Tu as testé avec UPC débranché ?
Shadows93 (13/12/2021), zav_ze_best (10/12/2021)
Vieux 11/12/2021, 10h36   #26
multi290
Avatar de multi290
multi290 is a name known to allmulti290 is a name known to allmulti290 is a name known to allmulti290 is a name known to allmulti290 is a name known to allmulti290 is a name known to all
je viens d'avoir un cas le témoin antidem reste fixe sur clio 3
1.5, suite a une panne batterie,
au diagnostic de conformité UCH code cle reçu et bon, l'apprentissage code antidémarrage de l'injection c'est efface tu retrouve également cette l'info dans UCH
a voir si c'est la même chose
multi290 est déconnecté   Réponse avec citation
The Following User Says Thank You to multi290 For This Useful Post:
Vieux 11/12/2021, 12h13   #27
sam27000
Avatar de sam27000
Pouvoir de réputation: 5
sam27000 will become famous soon enough
salut essaie de regarder ton uch et pour un chan,gement de UPC pas besoin de code
Quand chacun s'aide, personne ne se tue.
sam27000 est déconnecté   Réponse avec citation
The Following User Says Thank You to sam27000 For This Useful Post:
Vieux 12/12/2021, 08h57   #28
Rallyeman
Avatar de Rallyeman
Rallyeman is a jewel in the roughRallyeman is a jewel in the roughRallyeman is a jewel in the roughRallyeman is a jewel in the rough
Je suis du même avis que Nowen et Tech-auto pour le calculo moteur. Un rouge fixe qui reste allumé, ca sent le relais verrou injection qui est est pas piloté par l’ecu. Tu shunt le verrou est tu vois s’il s’éteint a la mise sous contact.
Un DCM1.2 vierge, un apprentissage code anti démarrage, les numéros injecteurs, le vin, et des configs et c’est reparti.
Rallyeman est déconnecté   Réponse avec citation
The Following User Says Thank You to Rallyeman For This Useful Post:
Vieux 13/12/2021, 00h57   #29
Shadows93
Avatar de Shadows93
Salut boris,
Oui meme UPC débrancher et batterie debrancher j'ai de la continuité entre c'est ligne ce qui ne correspond pas dutout a ce que je vois sur le schéma électrique.
Finalement sa pue le faisceau cette affaire.
---------- Post added at 00h57 ---------- Previous post was at 00h53 ----------
Envoyé par Rallyeman Voir le message
Salut Rallyeman,
Je suis d'accord, j'ai juste 2 trois doute a écarter sur le faisceau et je vais suivre l'idée de Nowen et Tech-auto.
Merci les amis
Rallyeman (13/12/2021)
Vieux 13/12/2021, 02h26   #30
boris93600
Ok, tu peux poster une photo de ton emplacement relais (proche batterie) ?
Tu es sûr du code moteur K9K766 ?
Dae modus BELL Réparation & Programmation des calculateurs 23 21/10/2021 16h37
Remplacement silent bloc sur bv modus oursbrun Mécanique générale 21 25/07/2021 17h17
Suite a remplacement DAE sur Modus zingilingiling Immobilizer dumps/solutions 30 11/11/2018 16h04
Remplacement deplhi 1.2 de modus 8200398934 rrguillaume Renault, Dacia, Nissan 0 23/02/2013 14h54
Fuseau horaire GMT +1. Il est actuellement 17h49.
